Question about Water Heaters
Off peak hot water not heating!!! :(
Hi all, I have a problem, not sure what to do about it / who to call! I've just bought a new flat, and with absolutely NO information left by the previous tenants / landlord, have managed to figure out with a bit of googling how to work the hot water system. So it appears to be on one of these Economy 7 systems so it should automatically heat the water during the night off peak, and the control panel also gives the options to boost in the daytime (either manual or timed). When I use the boost functions during peak hours (I tried both manual and timed), the water heats up fine. But, overnight, I see that the off-peak light is lit up as though it's heating, however it doesn't heat as the water is still cold in the morning. Heating with "boost" during the day is obviously much more expensive. I tried doing a "timed boost" during overnight hours but the "off-peak" cycle overrides the boost and I still end up with no hot water. Not really sure what the issue can be as the water CAN be heated in some way, but somehow not the offpeak part. Don't know anything about the system or water heaters in general so I have no idea of the inner workings of these things. Can anyone help?? THANKS. Shaz
  • Water Heaters Master
  • 5,245 Answers
The Economy 7 can control different types heater. Some heaters do not have off-peak ... but you can solve problem..
Copy following link:
http://waterheatertimer.org/pdf/QE7-INSTRUCTION.pdf
If timer is wired to two different elements, then the night rate element or off-peak element might be burned out. Test element with multimeter.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Also this timer is wired so either Off-peak is getting power or Boost is getting power, but not both at same time.
If heater has off-peak element, then there will be a wire connected to terminal 5, going to heating unit.
If there is no wire on terminal 5, then there is no off-peak element, or wiring has not been connected. However you can change the timer function by moving wire on terminal 4 to terminal 5. Then only the off-peak timer function will operate, and not the boost.
You can also fool the timer, by setting time clock differently. Instead of setting timer for current time, rotate the dial and fudge current time by 10-12 hours so water heater thinks it's time for boost, but the actual time is during off-peak hours.
If terminals 4 and 5 both have wires, then either the element is burned out, or the timer has malfunctioned. Again, you can fool the timer by setting current time differently, and solve problem.
Posted on Apr 26, 2013
2 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: Water heater not heating water.
Hi, W/D here.
You'll need an electrical test meter to find what ails ya. The reset button was a good idea, and it may help. If not:
1. Disconnect the power to the water heater (Trip the breaker to "Off").
2. Check the electrodes where they screw into the tank. There are two terminals. Test for continuity. If either electrode tests open, replace it.
3. With power on the heater, test for power through each thermostat to the electrode and back. Replace any defective thermostats.
Hope that this helps you, --W/D--
Posted on Aug 07, 2009
Does off peak only heat up at night??? Will it automatically heat up when it cools???
yes only when the load from the power station is low at night, the water tank has a thermostat that turns the power off when hot . it does not heat during the day. Get the biggest tank you can if you use a lot of hot water in the day. We have a lot of sun so have a sola hot water system with a gas back up.
Oct 20, 2014 | Water Heaters
Hi, I've a fagor feb20e Eco plus combi boiler in
There is a flow sensor in the circuit and it is not sensing the lower flow from just the hot water. When you put it on heat though it does.
May 31, 2013 | Water Heaters
How to troubleshoot a water heater
1) If water flow stops when tap is off, then Sound of water running: could be factory-installed heat trap inserts or nipples: These things cause noise.
http://waterheatertimer.org/Low-hot-water-pressure.html#trap
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#heat-trap
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
2) If sound of water continues when tap is off, then there is a broken pipe or leak somewhere in plumbing system.
Feb 17, 2013 | Reliance 606 Series 40 Gallon Natural Gas...
They worked on our city water and now i'm getting no hot water... before that it worked but i don't think to capacity.. it wouldn't fill the tub before getting cold.... it is a rheem 50...
As long as the water heater is not leaking or not big enough that would be the only reason to replace heater. If you are running out of hot water or it's cold, check the power source first to make sure you have power to heater. Then check the reset button on the top thermostat and make sure it's not tripped if it is it wil not heat. If so press red button aloow it a little time check for hot water.
Next step woul dbe to turn power off and drain water to replace both elements out. Once changed out turn water back on and open a faucet to remove air out of the wtare lines. Once you get water flowing out of water lines now you are ready to turn power back on. allow about 30 to 40 monutes and you should have hot water.
Jul 09, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Gas works fine -gets hot water. But electric will not give hot water, only cold. How do you remove the heating element? It is on the inside of trailer in a black box? Model GC6AA-10E Atwood.
I'm thinking when you say black box, that you also have a wall switch with a symbol like a lightning bolt and you switch that on as well as checked breaker panel to make sure breaker is on as well.
With that said, you'll have 2 of 3/8" nuts holding that black cover on. Remove top one and loosen bottom one and pull cover off. ( Be sure power is off to unit while doing this.) You'll find the element in behind it. Put a voltmeter on black to element (red probe or alligator clip) and (black probe) to ground where you see green wire connected to tank. Turn breaker on then switch at wall. You should hear a relay click and 120 Volts should show at black wire ( red probe) . If you've got 120 volts there, shut off all power, drain water heater and replace element.
Jul 04, 2011 | RTO Atwood Water Heater - 6 Gal LP
Rheem 50 Gal two 4500W heating element - not enough hot water
one element is off peak and one is boost could be thermostat or ripple controller in fuse box or one dead element
Apr 19, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Water Heaters Logo
104 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
