LAUNDRY PURE BY ECOQUEST
RECALIBRATION PROBLEMS
2 Suggested Answers
SOURCE: Ecoquest fresh air. The display is hard to read part of the message has blanked out . Also the fan works but it doesn't have that pure smell
please give more info
Posted on Sep 19, 2012
What is the max load for an indesit 1234T washing machine please x
  • From the manual
    Maximum dry laundry
    load
    heavy fabrics
    maximum 5 kg
    delicate fabrics
    maximum 2 kg
    pure new wool
    maximum 1 kg
    mixed loads
    maximum 2,5 kg
    How heavy is your
    laundry?
    1 sheet 400-500 g
    1 pillow case 150-200 g
    1 table cloth 400-500 g
    1 bathrobe 900-1200 g
    1 bathroom towel150-250 g
Sep 14, 2014 | Indesit W 123 Front Load Washer
880 alpine air (2) on upper level one in kitchen and one in laundry room. Question: I clean the purifiers about once per month and the problem is that there is no clean air smell any longer. They are...
The transformer may be burned out. This supplies the power to the contact points which send current through the plates. You can try ordering new plates, just to see if yours are just plain worn out! You're doing the right thing, by using ammonia/water, but they aren't made to last forever! Call Vollara (new name for EcoQuest) at 800-989-2299. Use #16618 if you're no longer in touch with the registered distributor who sold you the machines. If you still detect no clean air amell, the machines need a part which the company no longer handles. And they no longer manufacture the 880 or Breeze, which was its upgrade. Customer service will explain your options.
Jan 21, 2011 | Ecoquest Living Air Classic Air Purifier
I just cleaned my air purifier; "Fresh Air" by EcoQuest model # SFA2714546 . How do I reassemble it?
How far did you dissemble? Cleaning is done with four screws on fan cover and two screws back panel and two screws on top. Reverse the order. Any more problems Doctorpc@gmail.com
Jan 13, 2011 | Ecoquest Fresh Air Air Purifier
I went to ( www.ecoquest.com (click on the DOWNLOADS tab, then on OTHER on the green bar. The Breeze AT is in the Owner's Manuals list) as suggested by Guru but the page is not active. I have searched...
jenirod: EcoQuest is now Vollara. The Breeze is no longer available in our product line, but it sounds like your problem is an easy fix. We've been with the company for 20+ years (Alpine/EcoQuest/Vollara). You can contact us at fredandmb@frontier.com.
Jan 12, 2011 | Ecoquest Breeze AT Living Air Purifier
I have an ecoquest fresh air purifier and the end of a red wire was corroded so I replaced the end with a new one, but the unit doesnt seem to be producing any ozone smell or sanitizing. It seems as if...
That corrosion is oxidation for the lug connecting the grid plate.Metal contact fingers make contact on the plates metal grids.The same corrosion exists on those metal contact fingers and the plate itself. Clean the fingers,ensure good connections as the other wire connector spade for the other contact finger is probably compromised. You might de-oxidize the plate by soaking in pure white ammonia.At any rate,I agree about the quality of the machines and you might be faced with a small parts order from eco-quest.Do include the plate, a bulb and the bulb starter. I run 5 of these in a commercial setting and they are fairly enjoyable to work on.
Jul 25, 2009 | Ecoquest Fresh Air Living Air Purifier
Noise
The first Fresh Airs were almost silent, then Jackson switched to a noisier fan. Everyone complained, but... now Jackson's out. He also switched to cheaper LED equip- hence THOSE problems! The Tech people know the problem, they should be able to help. 800-989-2299
Mar 04, 2009 | Ecoquest Fresh Air Air Purifier
THE WET DOG SMELL
try soaking the grid plate in ammonia
Jan 11, 2009 | Ecoquest Flair Air Purifier
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
