I have troubles with a printer eSutudio4511. Code
f100 is a hard drive formatting error
[F100] HDD format error
(1) Check if the HDD is mounted.
(2) Check if the specified HDD is mounted.
(3) Check if the connector pins of the HDD are bent.
(4) Check if the connectors CN116, CN132 on the SYS board is disconnected.
(5) Replace the harness.
(6) Format the HDD. (Key in "2" at 08-690.)
(7) Replace the HDD.
(8) Replace the SYS board.
step 6 is turning the copier on while holding 0 and 8 til it beeps type 690 and hit start, this will format your hard drive, more than likely it is bad physically but you may get lucky
