Question about SMC Barricade 7004 Router
Epson Scanner connection onto SMC7004ABR router
I've connected an Epson Stylus SX600FW into my home network. The printer works fine. The scanner doesn't. The scanner driver loads OK but testing the scanner connection shows no scanner.
The scanner works OK by direct USB coinnection. My question is;
is there such a thing as a Channel number setting on the router which would be blocking the bi-directional data flow?
Epson scanner cannot communicate
My solution was that Epson Scan was set to connect via network instead of local. (All was working fine, then it quit-something changed this setting) Try this, go to start, choose all programs, choose Epson folder, choose Epson Scan, choose Epson Scan Setting. In the pop up box set the connection to local or network, whichever is appropriate. Close the window and open photoshop and all works fine. It could be that your problem is the opposite of mine- I try switching this to the other setting even if the change is wrong, then switch it back to see if that works too.
Good Luck.
Jan 05, 2013 | Epson WorkForce WF-7520 Wide Format...
Laptop running vista will not print wirelessly
check the cable connections, unplug replug the cable.......then turn it on
Sep 09, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson CX4700 printer/scanner won't connect to my apple network
maybe the twin setting chick to twin settings
go to start and you can find the twin setting try it
Jul 06, 2009 | Epson Stylus CX4700 All-In-One InkJet...
INSTALLATION OF EPSON SX600FW
http://support.epson-europe.com/onlineguides/en/sx600series/html_z/p03.htm
this is the web site that explains how to connect to the network. i hope this helps.
please rate good.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 01, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Setting bluetooth on a Epson stylus SX600FW
the bluetooth dongle for your printer is sold separately. call epson store to get one.
Jan 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Connecting wi-fi on Epson SX600FW
I hada the same problem. I used the settings on the actual printer rather than through the software to input the information it needed and It works fine now. I was able to set it up on my husbands laptop without any problems, I just added his laptop through installing the software on his laptops as it had picked up the signal and was showing in the Network and sharing centre on Windows Vista premium. Hope this helps. I think you need to take the wire out now and now load it as wireless. You need to use the wire first to connect then take it out to connect to the wirelss network. My router is a Sky router.
Tiptap
Jan 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
My computor does not recognise my scanner
Hi
Pls check for updated driver for scanner on support.epson.com, because i believe that this printer doesn't have a wireless scanner server so the scanner will not work wirelessly.
Hope this helps
Nov 28, 2008 | Epson Stylus Multifunction Inkjet Printer/...
SMC Barricade 7004 Router Logo
145 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
