Question about Philips 37PFL5332D 37 in. LCD Television
37PFL5322D/37 PROBLEM
I JUST BOUGHT MY LCD PHILIPS TV YESTERDAY AND HAVE HAD 3 DIFFERENT PROBLEMS SO FAR. THE SCREEN WILL START BLINKING (NOT THE GREEN LIGHT TO RED OR THE OTHER WAY AROUND) BUT THE WHOLE TV SCREEN. THE PICTURE STAYS THE SAME BUT THERE IS THIS BRIGHT BLINKING OF THE WHOLE SCREEN OVER THE PICTURE. THAT HAPPENED ABOUT AN HOUR AFTER TURNING IT ON FOR THE FIRST TIME. IT HASN'T DONE IT BUT ONCE SINCE. THE SCREEN HAS A DARK 4 INCH THICK BAR OR DARKNESS IN THE MIDDLE OF THE SCREEN FROM THE TOP TO BOTTOM OF THE TV. THE COLORS ARE DARKER ALL IN THE 4 INCH BLOCK OR LINE. IF THE COLOR IS SUPOSSED TO BE WHITE IS SHOWS UP JUST IN THAT AREA AS A DEEP YELLOW. I WENT OUT FOR AN HOUR OR SO AND TURNED IT BACK ON AND THE SPEAKERS WERE SCREECHING AND THEN STOPPED. I HAVE FOLLOWED THE SET UP DIRECTIONS TO A T. SO, I AM FREAKING OUT. ANY SUGGESTIONS WOULD BE GREAT. THE COLOR WAS NOT DISTORTED WHEN I FIRST TURNED IT ON AND SET IT UP. THANKS SOOO MUCH!!
  • Anonymous May 09, 2008
    Mine will not respond to the remote control to turn it on. It seems to get stuck in standby mode and won't wake up.
  • no15 Dec 22, 2008
    same here! keep trying different repair centers!
6ya staff
SOURCE:
IrishDruid
Swilin Sampson
  • 2712 Answers
SOURCE: 5 different colored vertical lines on black and white picture.
Hello wisportsfan2,
Try the following first:
If you are using a direct cable connection from the wall outlet;
  1. Check the incoming cable or antenna signal connection to ensure that it is properly secured to the TV's antenna input.
  2. If the connection is good, perform the auto program and ensure that the Installation mode (Antenna or Cable) is selected correctly.
If you are using a coaxial connection from the Cable or Satellite box to the TV;
  1. Set the TV to the channel specified by the service provider.
  2. Change the channels at the Cable or Satellite box to view the program.
If you are using a video connection (CVBS, S-Video, YPbPr, HDMI) from the source (DVD, Cable or Satellite box) to the TV;
  1. You do not need to perform auto program to search for the channels.
  2. Press the 'SOURCE' button on the remote control repeatedly to select the correct input source.
If you are using an HDMI connection from the source (DVD, Cable or Satellite box) to the TV;
  1. Reset the TV and source by unplugging it from the power outlet for 30 seconds.
  2. Press the play button on your source device. If the source is HDMI CEC compliant, the TV will automatically switch to the HDMI input.
  3. If your source is not HDMI CEC compliant, turn on the TV and switch to the HDMI input.
  4. Turn on your source.
If you are sure you have selected the correct input or channel but still have no picture and sound;
  1. Try resetting the TV by unplugging it from the power outlet for 30 seconds.
  2. Press the 'SOURCE' button to select the correct input source.
You can try the "Whack" method first though..Just smack or whack the set with your hand or fist around the cabinet to see if that will either aggravate or restore the picture. If so, it means there is a loose connection or cold solder joint of some kind, which you may be able to repair yourself if you have the soldering skills.
If it still does not work, it looks like there is a problem with the vertical blanking due to faulty ribbon connectors, although there are several things that can cause it.
But in my honest opinion, it is best to have an expert technician come in and do some tests on it in order to diagnose the root cause of the issue. It is not easy to fix this yourself, if you have no experience, as there are a lot of parts that have to be removed before you can reach the components. It could be as simple as a loose connector ribbon or a bust capacitor, but it could also be more complicated. Hence, in my honest opinion, better get a qualified technician.
If you wish to contact Philips customer support to arrange for a service, please call 1-888-744-5477 Monday - Saturday 7:00 am - 11:00 pm EST Sunday 8:00 am - 11:00 pm EST Excluding major holidays
When you contact Philips please have available:
  • The exact model number
  • Your date of purchasing
  • The serial number of your product
Send an e-mail
Hope that helps! If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides helpful information that helps solve the problem.
  • "Thanks for Trying" - The solution provides some help but does not solve the problem.
  • "Inappropriate" - The solution has nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 04, 2008
skelp
SOURCE: philips 37' lcd tv 37mf231d/37
It is the low voltage power supply. I just had my set repaired and it had the same symptoms. My set is out of warranty. The repair cost is around $200.00.
Posted on May 30, 2008
Anonymous
  • 52 Answers
SOURCE: Philips 42PF5321D/37 Error Codes
replacing ssb for 4 blink error was correct as error is communication failure specific to micro processor on ssb. getting an alternate error after replacing ssb would suggest either wrong ssb or defective ssb. verify vendor number on ssb tuner on original and new ssb and if same reorder that board and if not order per original board
Posted on Aug 14, 2008
Anonymous
  • 138 Answers
SOURCE: Philips 42 inch Plasma television
I habve seen this issue with this sets and if the vertical lines are in the menu as well and there are more than one line the panel would need to be replace. Contact a tech in your area to see if then can put the set in white screen mode and leave it there for a couple of hours and see if the lines go away. If not then the set would need a panel.
Posted on Aug 20, 2008
Anonymous
  • 90 Answers
SOURCE: Have a Magnavox 37 inch lcd hd tv When I turn the
sounds like the audio / digital board is going bad ---- they are about 130 refurbished and 300 new ----- look for one online before you pay an overpriced service tech who really doesnt know how to fix these tv's ----
I called the service support and they gave me three companies in Nevada --- each one of them had no idea what the codes meant, but would look at the TV for 225.00 - sounds like they need new companies to do their repairs on warranty
Posted on Feb 24, 2009
Model 37PFL5322D/37 phillips tv has a chirping sound, no picture
Your TV is exhibiting a symptom of power supply trouble but repair is not a casual task.
Dec 20, 2013 | Philips 37PFL5332D 37 in. LCD Television
No sound on my philips 37pfl5322d/37
Check and replace damaged components at its audio output stage circuit. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Nov 22, 2013 | Philips 37PFL5332D 37 in. LCD Television
Philips lcd tv dont turn on, blinking green light
Just fixed that exact problem on mine and made a video on what part and how to replace it. I also added a link below for the part I bought. L5973D STMicroelectronics Mouser
Oct 04, 2012 | Philips 37MF321D 37 in. LCD Television
Philips 37PFL5322D
Your remote control need cleaning. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 750 posts to different brand TVs now.
Pull up older posts there. have all details about how to clean a remote control.
Sep 12, 2012 | Philips new universal remote control...
Model 37PFL5322D/37 phillips tv has a fast clicking sound in the power supply, what will cause this.
possible the main relay in the power supply board may need soldring or you could have a stickey relay
Jul 13, 2012 | Philips 37PFL5332D 37 in. LCD Television
Phillips model 37PFL5322D/37 was watching unit and just shut off--no click or pop, just shut off....unplugged power for 1 minute and tried to power up--nothing--will not power on...checked power...
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Apr 16, 2011 | Philips 37PFL5332D 37 in. LCD Television
My 37PFL5322D 37" LCD has no picture and no
If the set is responding to the remote or set-top buttons, this means only that the always-on low voltage supply for the remote section is working and that the main power supply has probably died. You might try pulling the AC plug overnight to see if there is simply a 'lockup' of an IC causing the non-response. Our modern sets are very complex and it isn't uncommon for them to have a glitch while operating.
Mar 08, 2011 | Philips 37PFL5332D 37 in. LCD Television
My tv keeps reverting to the Philips TV Menu
If that TV has a 'menu' button on the front of the set, make sure nothing like coca-cola has spilled into where that switch is located. I would try a different remote in case the remote is getting flaky....
Oct 21, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips LCD TV - Red blinking lights
I would check the capacitors on the power pack for failed or blown ones. doing this work will require soldering skills
FYI
Mar 21, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37 flat screen
U better have it checked by a qaulified tech
Sep 09, 2007 | Initial HDTV-322 32 in. LCD Television
Philips 37PFL5332D 37 in. LCD Television Logo
208 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
