Question about Garden
How to assemble the cutter deck on lawnflite 704 belt routing
  • 246 Answers
SOURCE: I need instructions for the assembly of the cutter deck components etc for this machine.
Hello:
A Breakdown should Assist you in Assembling the Deck Components.
The Following Site Addy has a Breakdown of this Unit. Simply use the Site as if you are Looking for a Part for the Mower and then go to the Breakdown for the Deck.
http://www.partstree.com/parts/
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
  • 66 Answers
SOURCE: my 603 lawnflite ran over a man hole cover and
Should be just behind the dash
Posted on May 30, 2010
Testimonial: "Hi thanks will check it today,i also need a workshop manual for the 603 lawnflite 30" cut,would a manual from another lawnflite model be the same?,also has anybody else heard of the lawnflite 603 model or others, sucking manhole covers into its cutter deck,beware all lawnflite owners,this has happened to me on its second cut from new,i have cut our lawn with a westwood tractor for the last 26 years,and never had any trouble with manhole covers!!!!!!!!"
The GR8 1
  • 7 Answers
SOURCE: Craftsman 42 inch deck mower.
That model number des not show up as a good number on the http://www.searspartsdirect.com site. Are you sure you have the belts on correctly? If it has 2 belts on the deck & 1 is not installed correctly they work against each other. Safely make sure that each blade will turn by hand. did you take the blades off? If they are too long by just a fraction, they will hit ach other, but that usually makes quiet a noise. Get your book out & systematically go over everything you touched or changed. It sounds like something really simple you have overlooked. you can go to http://www.searspartsdirect.com & enter a good model number & view all of the parts diagrams. Sometimes they are a big help, & at other times they just confuse you more:). Let me know what you find!!
Posted on Aug 13, 2010
SOURCE: Where can I find the
Hi go onto the powerhouse site below, put in your mower details and you will see the plans for the deck.
Geoff
www.powertoolspares.com/...lawnflite.../906-13af765n611-1998-576/
Posted on Oct 24, 2010
bahama_mama0
  • 7 Answers
SOURCE: deck belt route for a Model #91725160 Craftsman Sears 14/6 garden tractor
i figured it out the pully beside the motor has 2 pully's side by side that i was missing but now i need a 9503H spring that is not made,thank's for all reply's
Posted on Oct 06, 2012
How to replace cutter belt Lawnflite ride on mower 903 auto drive , it came off and don't have operator manual for configuration
There are idler and tensioner pulley's, you sould maybe go to a dealer they could maybe help with the proper routing.
Apr 18, 2015 | Garden
Belt diagram for toro416 42 inch rear discharge cutter deck
diagram for belt routing should be visible under tractor at running board area
Apr 01, 2015 | Garden
I need a diagram on how to fit a cutter deck belt for a murray sentinel 15.5/ 106. Belt number 037 x 88 Keith
The routing is usually pictured on the belt cover such as in your picture. If you send me the model no. to the rider, I will verify proper routing.
Feb 11, 2011 | Murray 38 Lawn Mower Blade Belt '90'96...
I have a MTD 0675 g Ride on mower, with a 18hp Briggs IC engine. I have recently re bearing'd the cutter deck and fitted a new belt. I cant work out how to adjust the belt-tighten it a little as it slips...
check to see if the belt is in the correct routing, most belt tensioners are able to be fitted with a factory belt in a couple of different routing methods, however only one is right to keep the belt from slipping, look for a belt routing diagram on the mower deck they are the best source fot this information.
Jan 07, 2011 | Garden
Where can I find the diagram for the cutting deck belt routing for an MTD Lawnflite tractor mower 13AA478E678
Geoff
Oct 19, 2010 | Garden
Craftsman 42 inch deck mower. Model 917.277611 (2007). LT1000. 16.5hp Briggs & Stratton. Springs on cutter deck assembly broke. Had to re-assemble cutter deck. Re-attached springs and tension arms....
Aug 12, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My 603 lawnflite ran over a man hole cover and
May 29, 2010 | Garden
Garden Logo
99 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
