Question about ECS Elitegroup P6stp-fl Motherboard Cpu 512mb Ram Memory Small Complete
Set up HARD DISK - ECS Elitegroup P6stp-fl Motherboard Cpu 512mb Ram Memory Small Complete
  • 5,660 Answers
Http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=106&MenuID=24&LanID=0
The ECS P6STP-FL motherboard uses IDE (PATA) harddrives, and optical drives. (CD/DVD drive)
IDE 1 is for the Harddrive.
IDE 1 is the 40-pin connector that is closest to the Ram Memory slots.
(Only 39-pin are used, however)
IDE 2 is used for the optical drive/s.
IDE 2 is next to IDE 1, and is further away from the Ram Memory slots.
The IDE connectors on the motherboard, have a Cut-Out on one side. A small square cut-out.
This is for the Locating Lug, on the flat IDE ribbon cable's, connector.
This makes sure that Pin 1 in the motherboard connector, is lined up with Wire 1 in the flat IDE ribbon cable.
http://en.wikipedia.org/wiki/File:PATA-cable.jpg
The Locating Lug shown in this example, is two 'ridges' that are separated. Some designs just use one solid block.
IF, there is no Locating Lug;
Look for the faint Red stripe, on the side of the flat IDE ribbon cable,
http://en.wikipedia.org/wiki/File:Nappe.svg
This stripe denotes the side, that number 1 wire is on.
Motherboard installed in computer case, the red stripe on that flat IDE ribbon cable, goes DOWN.
Down towards the Bottom of the motherboard.
When connecting to the Harddrive, and there is no Locating Lug on flat IDE ribbon cable, the Red stripe goes towards the power cable connection.
This applies to the optical drive (CD/DVD drive), and Floppy Disk Drive.
(34-pins for a Floppy Disk Drive. Cable is smaller in width)
Now, there is a different method of connecting a Harddrive, or optical drive, in relation to the flat IDE ribbon cable.
Depends on if the flat IDE ribbon cable is a 40-wire cable, or an 80-wire cable. You can use Cable Select setting on Harddrive/Optical drive; OR you can just connect the Harddrive, or Optical drive the correct way,
http://mikeshardware.com/howtos/howto_connect_ide_hd.html
Is the Harddrive recognized in BIOS Setup?
If your question relates that the Harddrive is not recognized, post back in a Comment.
Also post the manufacturer ID information off of the Harddrive's label.
Example for one type of Western Digital harddrive;
WD800AAJB
Western Digital 80 GB harddrive, and IDE (PATA)
With this information I can find the Cylinders, Heads, and Sectors.
Then guide you in entering it in BIOS Setup, IF needed.
"Press DEL to run Setup"
Press the Delete key to enter BIOS Setup.
AS SOON AS you press the Power On button, start tapping on the DELete key.
Tap in 2 second intervals.
You will hear beeps. These are Stuck Key Error Code beeps, and it is YOU that is doing it. Ignore the beeps.
Best method for entering BIO Setup.
(The window of opportunity for entering BIOS Setup, goes by F-A-S-T! The above method will get you in)
Your problem statement leaves a hole in the time/space continuum.
Does not exactly state what your problem is
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Apr 27, 2013
NEED JUMPER SETTINGS FOR MASTER HARD DRIVE
Set The Jumper Setting On Your Hard Disk Drive
The hard disk drive will be detected as 32 GB if the jumper is set to the 32 GB clip pin setting. The common jumper settings for Samsung hard disk drives are listed below. Please check the label on your hard disk drive for the correct jumper setting.
Important: Use the alternate jumper setting listed below under General Pin Setting. After changing the jumper, partition and format your hard disk drive.
Configuring your Hard Disk Drive (Master, Slave, or Cable Select) - Setting the Jumper
If this is the only HDD in your computer, set the pin setting to Master.
If this is the second HDD in your computer, set the pin setting to Slave.
If this is the second HDD in your computer, and the first drive is set to Cable Select, set the pin setting to Cable Select.
If you are replacing the HDD in your computer, set the jumper setting to match that of the drive you are replacing.
Cable Select:
This setting is the default setting for PATA/IDE hard disk drives. With the Cable Select jumper setting, the BIOS determines whether a hard disk drive is Set as Master or Set as Slave by it's position on the UDMA cable.
If the hard disk drive jumper is set to Cable Select and is connected to the black connector on the end of the UDMA cable, it is recognized as Set as Master for that PATA controller.
If the hard disk drive jumper is set to Cable Select and is connected to the grey connector on the middle of the UDMA cable, it is recognized as Set as Slave for that PATA controller.
Note: When using Cable Select, your system must meet the following conditions:
Your systems host controller must support Cable Select.
Your hard drives must support Cable Select.
Your cable must support Cable Select.
Set as Master:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Slave, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
Use this setting if you are installing an additional hard disk drive to a single UDMA cable and the Cable Select setting is not recognized.
Set as Slave:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Master, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
32 GB Clip Pin Setting:
Use this on computers manufactured before November 1998 when either you start up your computer and see the message, "Hard disk drive controller failure", or your system stops responding during the boot process after installing a new drive. This occurs when the hard disk drive is too large for the BIOS to support.
If after performing the troubleshooting procedure listed above, the full capacity of your hard disk drive is not recognized, click here for information about obtaining a system BIOS update. If you are unable to update your BIOS, another option would be to create a second partition with the remaining unallocated disk space.
Aug 18, 2012 | Computers & Internet
"Error loading operating system"
This issue is caused by any of the below reasons.
The computer's BIOS does not support the computer hard disk drive's size or settings.
Computer Hard disk drive is not properly setup in CMOS.
Issue with drive's partitions.
Verify that the computer's hard disk drive is properly setup in CMOS setup.
Once in CMOS, verify the below hard disk drive settings.
Verify the hard disk drive is detected.
Try changing the "Access mode" on the hard disk drive to Large or LBA. This setting may vary depending on the BIOS.
Use a system utility tool like ReginOut to avoid such type of errors in future.
Jan 04, 2012 | Dell Inspiron E1405 Notebook
Internal hdd none in bios set up
If the BIOS cannot detect the hard disk, this usually indicates that the hard disk has failed.
To get the Lenovo operating again, replace the hard disk and install Windows in the new hard disk plus
the Lenovo's device drivers and your programs.
Apr 09, 2011 | Lenovo 3000 C200 8922 - Celeron M 420 1.6...
My HP 4710s had a weird message that pops up after the logo screen. Then it says non disk or disk error strike any key to continue...I do that and the same message pops up...plz help.
the HP cannot boot up because it cannot find the hard disk to boot up from.
You could have a faulty hard drive or the hard drive needs re-seating.
If the HP still does not boot up after re-seating the hard drive go into the BIOS setting and see if the hard disk is detected. If not the most likely the hard disk is faulty.
To get the laptop working again. replace the hard disk, install Windows on the new hard disk plus the HP Laptop's device drivers and your programs.
Mar 20, 2011 | HP Computers & Internet
How can I install my hard drive without the cd?
HI jamarrfinney
If you only want to install on your hard drive as backup, cd is not needed. just set the hard disk jumper to slave for IDE hard disk. If you are using SATA hard disk, no need to set jumpers, just insert the cable and then set the bios setup hard disk as a second hard drive (if necessary)
regards
Jan 11, 2011 | Computers & Internet
Screen goes blank after a few minutes
POWER OPTION
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
POWER OPTION
-set display to never
Restart pc
Jul 14, 2010 | Dell Inspiron 1318 Notebook
Acer T-180 hangs at "Verifying DMI Data"
The cause of this problems is a corrupt boot files, Settings for hard disk drive are not correct,Floppy diskette or CD in computer causing issue, Boot devices not set properly, BIOS corrupt or misc. hard disk jumper setting not set properly, Connections loose or disconnected, Bad Hard disk drive or other bad hardware.
Note: Try this first. Check the cable setting of your hard disk in the BIOS. try swithching it to IDE, SATA, RAID. save your seetings and restart your computer.
if problem still exist... Follow this steps..
Step 1: If you have a USB stick with capacity of 4Gb and up or another hard disk... try installing a fresh Operating System in the USB stick or in the extra hard disk that you have.. after you install.. boot to bios and set the Primary boot in the extra hard disk or Removable Device (USB) save your settings and restart.. your computer will start normally booting the windows in your newly installed extra hard disk or USB stick. when you are in the Desktop, now try accessing your old hard disk and copy your files.. after you backup your files to the new installed hard disk. go to step 2.
Step 2: Turn off your computer... uninstalled the newly installed hard disk or USB.. after you uninstalled the hardware.. turn on your computer and reinstall your Operating System again. if the problem still exist go to step 3.
Step 3: if the problem stil exist. i think ther is something wrong with your hard disk.. try installing the OS again in second partitioned of your hard disk.. create first partition, then second partition. then installed your OS in second partition... if the problem still exist and you cannot go to windows desktop.. maybe your hard disk drive is damaged...
Hope I Can Help
CLCTECH
Apr 23, 2009 | Acer Aspire™ T180 PC Desktop
Samsung Hard Disk MP0804H
maybe your HDD are not compatible in your laptop. try to look it in your manual if it is compatible or not.
Jan 29, 2009 | Samsung (MP0804H) 80 GB Hard Drive
External disk is not been detected
Check the BIOS setting, make sure the hard disk is set to Auto (detect) or change the settings to default settings (your BOS may not have this option) then save and reboot laptop.
If the hard disk has not been detected and/or Unable to find the operating system, it means you may have a faulty hard disk or a faulty hard disk controller or the hard disk may not be making proper electrical connection.
To reseat the hard drive, remove the hard drive and reinsert it into the laptop a few times and see if it boots up..
If it still does not see the hard drive then the fault is probably the hard disk. To test if the hard disk is faulty, remove the hard disk and insert it into a hard drive USB adapter and connect it into the USB port of a working computer. If you don't see this drive as an external drive then you will know its faulty. Then you will need to purchase a hard drive, insert it into your laptop then install the Windows operating system and all your device drivers and programs to get your laptop operational again.
If the hard drive is OK the the fault is with the disk controller, and it is near impossible/expensive to repair the motherboard. Put your money towards a new laptop and put the hard disk into a USB hard disk adapter case and use it as as a portable external hard drive.
Best of luck.
Dec 12, 2008 | Toshiba Satellite M45-S351 Notebook
Dell M60
what you mean hard drive?
did you mean hard disk ok!
theres a jumper at the back of the hard disk
so a mother board can recognized if one your hard disk
may set into master or slave
set the jumper one of your hard disk into slave
and then try to connect
or email me ronaldsuboc@yahoo.com
Sep 18, 2008 | Dell Precision M60 Notebook
ECS Elitegroup P6stp-fl Motherboard Cpu 512mb Ram Memory Small Complete Logo
57 people viewed this question
Top ECS Computers & Internet Experts
David
David
WTF Chuck.....
WTF Chuck.....
Coss
Are you an ECS Computer and Internet Expert? Answer questions, earn points and help others
