Question about T-Mobile MDA
Mda mobile pm10b resetting softreset - T-Mobile MDA
Password
Hi Dawn, checkout this site. http://www.hard-reset.com/t-mobile-mda-iii-hard-reset.html
Hope it helps.
Steve
Oct 12, 2013 | T-Mobile MDA
Smashed my screen on my mda vario got a new phone now want to active sync in but cant remember my pssword is there a work around?
Yes, you need to perform a hard reset.
To perform a hard reset
1. Press and hold the Comm Manager button and Voice Command
button on the device. At the same time, use the stylus to lightly
press the RESET button.
T-Mobile MDA Vario hard reset soft reset hardreset softreset
2. Keep the Comm Manager button and Voice Command button
pressed, and the following message will appear on the screen:
3. Release the two buttons, and press the Send button to perform a
hard reset
Feb 05, 2011 | T-Mobile MDA Vario Smartphone
How to change MDA T mobile language from Dutch to English
You can try doing a hard reset and it will probably give you the option once you do that:
To hard reset the device, perform the following steps:1. Tap Start. 2. Tap Settings. 3. Tap the System tab.
4. Tap the Clear Storage icon. 5. Type the indicated word or numbers, and tap Yes. The device resets and powers on.
Jun 30, 2010 | T-Mobile MDA
Window in not starting
Findout from MDA site what is the 'reset to factory default settings' is. Remove the memory card and reset. It will do away with the new SW that you installed. You will loose all settings that you made and the SW that you installed. But your phone will be as good as brand new. In case of Nokia the code is *#7370#. Yours may be different.
Aug 06, 2009 | T-Mobile MDA Vario Smartphone
MDA acting funny
try a soft reset. start/settings/clear storage. enter 1234 when asked and the phone will guide you through the proccess. make sure you have a good charge before starting.
Feb 23, 2009 | T-Mobile MDA
MDA II
do a hard reset. go to start/ settings choose the system tab then select clear storage. the phone will guide you through the rest
Jul 25, 2008 | T-Mobile MDA II
T-Mobile MDA won't hold a charge
if you insurance on your phone I recommend using it, I had a MDA for a couple years and had about every problem in the book, but not that one. It sounds like you've done everything possible, the only other thing i could think of is a hard-reset. Anything beyond that would tinkering with the internal hardware.
I think you can get a MDA pretty cheap on ebay these days
Jul 19, 2008 | T-Mobile MDA
MDA PRO
i have the same unit helps to reset it on a daily basis
Oct 31, 2007 | T-Mobile MDA Pro Smartphone
T Mobile MDA Speaker control
Update teh firmware from tmobiles website. Download the latest firmware and upload it to your mda... Should fix it.
Aug 01, 2007 | T-Mobile MDA
T-Mobile MDA Logo
Top T-Mobile Computers & Internet Experts
Marvin
Marvin
markpain
Level 1 Expert
matt
matt
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
