Question about GPS
Tomtom gps 1ex00
How do I get to the Longitude and Latitude icon to be able to enter co-ordinates into the TomTom
SOURCE: TomTom One 3rd Edition - Latitute Longitude are Wrong
Are you sure that you have set the latitude and longitude units correctly? Under Preferences go to Set Units, press done until you come to latitudes and longitudes. You have three choices, Degrees in decimal form, Minutes, or Minutes and Seconds. Printed maps might use any of these forms of latitude and longitude. Avation maps are usually different than ground maps. Hiking maps also use either of the three forms.
Posted on Dec 31, 2008
oblivion2k
  • 150 Answers
SOURCE: Tomtom One 130 shows pic of Tomtom, flashing x, pie chart icon on left .
TomTom Home must have corrupted the TomTom's operating system. That is what that symbol means. Contact TomTom support and tell them what model you have and they will walk you through getting the correct version installed.
Posted on Feb 27, 2009
Harleyknut
  • 83 Answers
SOURCE: Garmin GPS 12 seems to be a few hundred yards out!
Go into your device and pull up the setup section. There should be a selection that needs to be checked called WAAS. When that is selected your accuracy should be +- 3 meters if I remember correctly. At any rate it will be much more accurate.
Posted on Apr 02, 2009
ZJLimited
  • 17970 Answers
SOURCE: how can i find latitude and longitude on my tomtom
In the Preferences area tap the Set Units icon on the fourth screen. Run through the options until you get to the "How should Lat and Long be displayed" and set Seconds (d,m,s)
Then when tapping lat/long while browsing the map or navigating you enter the lat first as S 22 (Degree symbol) 06' 20 and repeat for Long, E 149 (Deg Symbol) 31' 35 and it will work. The letters and symbols are available on the on screen keyboard that TomTom provides.
Hope this helps; keep us updated.
Posted on Dec 17, 2010
nashsaint
  • 172 Answers
SOURCE: how do i change from
Tap on
1. Menu
2. Change Preferences
3. Preferences
4. Set Units
from here you can change the units to kilometers.
hope this helps.
Posted on May 05, 2011
Tomtom 1EX00 UPDATES
join TOMTOMHOME, plug in satnav for free updates.!
Jun 30, 2014 | Tomtom One XL GPS Receiver
How to put in cordinance
Navigating to latitude and logitude is not supported on all devices. If it is supported on your GPS model, from the main MENU, tap CHANGE PREFERENCES, then tap SET UNIT, select the Latitude and longitude format in the Coordinate display screen and tap DONE.
Then from the MENU - tap Navigate TO ... select Latitude and Longitude, enter the coordinates and tap OK
Aug 14, 2013 | Tomtom GPS
Can gps coordinates be used with TomTom go live 750
If you mean, can you enter latitude and longitude coordinates on your GO 750 LIVE GPS device .... yes.
First you'll want to set your unit to accept coordinates. From the main menu, tap Change Preference, then select "Set Units" and select a Latitude and Longitude format in the "Coordinate display" screen, and then tap Done.
To navigate to a location using latitude and longitude coordinates, follow the steps below:
  1. From the Main menu, tap Navigate to...
  2. Tap Latitude Longitude.
  3. Enter the coordinates and tap OK.
May 09, 2013 | Tomtom GO 750 LIVE GPS Receiver
Can I set the TomTom to "go to" a longitude/latitude location?
Yes.
Feb 08, 2012 | Tomtom GO GPS
How to find the place by using cordinates?
Select "Navigate To". Then select the "Arrow" for the next page.. Then select "Latitude Longitude". Then enter the Latitude info and press "OK". Then enter the Longitude info and press "OK". Hope this helps you. If it does please vote!!
Jun 26, 2011 | Tomtom One XL GPS Receiver
I have a Garmin 250W. Is it possible to search and target a location by latitude and longitude rather than post code in France
You can definitely route using co-ordinates, this search option can found under "Where To?" it may be located a couple of pages down so go through the pages to see "Co-Ordinates" from here you would be able to enter your latitude and longitude.
Hope this helps!
Apr 26, 2011 | Garmin nuvi 250W GPS Receiver
Does aby know if my Garmin 1310 can use OS grd references instead of longditute and latitude? If so how is it set up?
Unfortunately Garmin satnavs do not allow OS Grid References instead of Longitude and Latitude. However if you need to find the Longitude and Latitude of a point it can be done by going to http://www.gorissen.info/Pierre/maps/googleMapLocationv3.php Zoom in on the location you want and left click on it. The longitude and latitude will appear in a box to the right of the map. You need to set the co-ordinate system of the satnav to match the longitude and latitude format of the satnav. To do this touch Where to, Co-Ordinates, Format. Enter the co-ordinates and touch next. It's not an ideal solution but it might help you out if you're stuck.
Aug 09, 2010 | Garmin GPS
Can my TomTom XXL 540-S be used with GPS coordinates?
If you are referring to Latitude and Longitude , yes. You can use those co-ordinates to navigate to a destination. This especially works fine in countries where the Avenue and street information is not available. Google maps can give you the latitude and longitude coordinates. You can fed those into the GPS and navigate. Please note, you will need the maps of the region involved. Click (Tap) on the main screen. Tap on: navigate to Tap on : arrow Tap on: Latitude longitude Enter latitude and longitude using keyboard, Latitude first and longitude next. Be careful while you do this and do not forget to enter the directions North, West etc.
Apr 27, 2010 | Tomtom XXL 540S GPS Receiver
How do I use coordinates? I entered map coordinates and it took us to the wrong place.
Some Tomtoms can use latitude and longitude coordinates. They refer, of course, to points on the map.
To use coordinates on some tomtoms you tap the Browse Map option. A general Map of the route is displayed. The screen has three buttons at the bottom
  1. Options
  2. Find
  3. an icon for the point on the map.
  4. Done
Tap the Options button: The Map detail Preferences appears, offering the choice to put a check mark in POI, Favorites, images. At the bottom of screen you have 3 buttons : POI, Advanced, Done.
Tap Advanced: In thsi screen you can put a checl mar on Names, Markers, and Coordinates.
Put a Check mark on Coordinates and press Done, Then Done again until you exit all those options.
Now your tomtom is configured to display coordinates. Be aware that GPS technology was created for military purposes and its civilian uses cannot be expected to offer pin point accuracy. It took an act of the US president to allow its use for civilian localization.
When you plan a route you can use longitude and latitude. Here is the icon you should like for.
Dec 30, 2009 | Tomtom ONE XL GPS
Aug 20, 2008 | Tomtom ONE GPS Receiver
GPS Logo
54 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
