Target home theatre system TT-1000i FM-UM review
Connection
Vivekt1000
  • 35 Answers
SOURCE: connecting home theatre system to tv
you need http://z.about.com/d/hometheater/1/7/E/9/stereoaudiocablesnew.JPG Stereo Audio Cables Cables
Posted on Aug 11, 2007
homemender
  • 158 Answers
SOURCE: TT Home does not recognise connection
You definitely need software and maps on an SD card. The TOMTOM will not work without a card inserted. The card will contain MAPS , Map authorisation codes ( to show they are genuine TOMTOM maps bought and paid for ) , POI ( points of interest ), GPS fix data , voices ( for spoken navigation ) etc etc etc. ....................
PLEASE NOTE , TRYING A CARD FROM ANOTHER TOMTOM is very unlikely to work. Each card has an authorisation code that is generated via an algorithm inside each TOMTOM and is device specific.
However , trying a card from another tomtom might produce a diferrent result but still not work , at least this might prove that the tomtom is working OK before you rush out and buy a tomtom card.
Posted on Feb 05, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony DVD Home theatre system
lets perform special reset function in your home theater.
1= set to stand-by mode
2= press three buttons of "Stand-by, Function & Volume- " all togather.
3= you will see "Cold Reset" message on front display of set.
4= power up and enjoy ;)
Posted on May 28, 2008
peeface
  • 180 Answers
SOURCE: connection of laptop to 5.1 home theatre
to hook to stereo you have to have one of these types of cables. you hook the rca ends to the back of stereo and the other end in the computer
http://www.bestbuy.com/site/olspage.jsp?skuId=7220777&type=product&id=1114639085343
Posted on Feb 27, 2009
  • 11800 Answers
SOURCE: We have a SONY DVD Home Theatre system
Each device has its own normal level for the signal. Usually they are set at the standardised value - 500mV - but sometimes some devices don't follow the standard. The only thing you can do is to check the connectors and use another cable - bad cables or connector can cause a big drop in signal level. If even after using a new, good quality cable that is a tight fit in the plugs - and these plugs themselves don't move around - then the only thing you can do is to set the maximum volume level higher to partially compensate for  that. You can find this option in the HDMI setup section in the MENU, labeled VOLUME LIMIT..
Posted on Aug 16, 2010
I have S5350 model mobile, how can i transfer photos from mobile to my laptop?
Try to connect it in bluetooth connection. (Wireless connection.). Or try to connect your phone in USB connection. (Wired connection) For wireless connection:
-open your first your bluetooth connection. (phone and laptop) -send the the files/photos via bluetooth connection. -accept the files from your laptop.
For wired connection: -connect your usb to your phone -set your phone connection to mass storage -connect to your laptop, if your laptop detect your phone, search your files, then copy it.. =)
May 21, 2011 | Cameras
Tip
Set up and Use Internet Connection Sharing
To enable Internet Connection Sharing on a network connection
You must be logged on to your computer with an owner account in order to complete this procedure.
Open Network Connections. (Click Start, click Control Panel, and then double–click Network Connections.)
Click the dial–up, local area network, PPPoE, or VPN connection you want to share, and then, under Network Tasks, click Change settings of this connection.
On the Advanced tab, select the Allow other network users to connect through this computer's Internet connection check box.
If you want this connection to dial automatically when another computer on your home or small office network attempts to access external resources, select the Establish a dial–up connection whenever a computer on my network attempts to access the Internet check box.
If you want other network users to enable or disable the shared Internet connection, select the Allow other network users to control or disable the shared Internet connection check box.
Under Internet Connection Sharing, in Home networking connection, select any adapter that connects the computer sharing its Internet connection to the other computers on your network. The Home networking connection is only present when two or more network adapters are installed on the computer.
To configure Internet options on your client computers for Internet Connection Sharing
Open Internet Explorer. Click Start, point to All Programs, and then click Internet Explorer.)
On the Tools menu, click Internet Options.
On the Connections tab, click Never dial a connection, and then click LAN Settings.
In Automatic configuration, clear the Automatically detect settings and Use automatic configuration script check boxes.
In Proxy Server, clear the Use a proxy server check box.
Bhautesh.
on Feb 24, 2010 | Computers & Internet
I have a 2000 taurus can you show me how do I change the thermostat on my car
3.0L OHV Engine
Fig. Exploded view of the water hose connection and the thermostat assembly - 3.0L OHV engines (click over pic for zoom)
  1. Drain the coolant until the level of the coolant is below the level of the thermostat.
  2. Disconnect the upper radiator hose from the water hose connection.
  3. Unfasten the three water inlet connection retaining bolts and remove the water hose connection.
  4. Remove the gasket and thermostat from the water hose connection. Discard the gasket.
To install:
  1. Clean the water inlet connection mating surfaces.
    NOTE The jiggle valve on the thermostat must be in the up position.
  2. Place the thermostat in the water hose connection making sure the thermostat jiggle valve is facing up.
  3. Install the new gasket and place the water hose connection assembly into position.
  4. Install the water hose connection assembly retainers and tighten them to 89-124 inch lbs. (10-14 Nm).
  5. Connect the upper radiator hose to the water hose connection.
  6. Fill the engine with coolant, start the engine and check for leaks.
  7. Stop the engine and top off the coolant recovery reservoir as necessary.
3.0L DOHC Engine
Fig. Exploded view of the water inlet connection and the thermostat assembly-3.0L DOHC engines (click over pic for zoom)
  2. Raise the vehicle and support it with jackstands.
  3. Disconnect the lower radiator hose from the water inlet connection.
  4. Unfasten the two water inlet connection retaining bolts and remove the water inlet connection.
  5. Remove the O-ring seal and thermostat from the water inlet connection. Inspect the O-ring for damage and replace as necessary.
To install:
  2. Install the O-ring, thermostat and the water inlet connection. Refer to the accompanying illustration If you can-t remember how the O-ring and thermostat are positioned.
  3. Install the water inlet connection assembly retainers and tighten them to 71-106 inch lbs. (8-12 Nm).
  4. Connect the lower radiator hose to the water inlet connection.
  5. Fill the engine with coolant, start the engine and check for leaks.
  6. Stop the engine and top off the coolant recovery reservoir as necessary.
Good luck (remember to rate this answer).
Apr 27, 2011 | 2000 Ford Taurus
A need help
you can set your playstation 3 online by two ways, 1- by a wired connection, and 2- Wireless,
1-Wired Connection: Plug an ethernet cable from your highspeed modem to the back ethernet input on your ps3 system, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wired Connection. and follow steps
2- Wireless Connection: You must have a Router connecting ethernet cable from your intenet modem to the router, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wireless Connection and follow steps,
hope this helped you on setting up your ps3 connection :)
Apr 13, 2010 | Sony Playstation 3 (PS3) Console
Error code: 80072efd
If you can't sign in to MSN Messenger, the connection settings in MSN Messenger might be preventing you from connecting to the Microsoft® .NET Passport or Microsoft® .NET Messenger Service. The MSN Messenger Connection Troubleshooter can often find and fix these problems. The Connection Troubleshooter starts automatically if MSN Messenger encounters a connection problem. If you choose not to use the Connection Troubleshooter, or it does not solve your connection problem, try the following:
1. Click the Tools menu, and then click Options.
2. In the left pane, click Connection.
3. Under Connection Settings, click Test Connection.
If you agree to allow the Connection Troubleshooter to examine your system, it will test for connection problems and report steps you can take to correct them.
4. Optional: Perform advanced troubleshooting
To troubleshoot your specific type of connection, click Advanced Settings. On the Advanced Connection Options dialog box, check that the settings for your particular connection type are correct. To test your connection, click the Test button. Click OK, and then click OK.
5. Click OK.
When you choose these settings, MSN Messenger will use the Microsoft® Internet Explorer connection settings if possible.
6. Try signing in to MSN Messenger again.
Hope I helped MSN expert Dr Reed
Oct 25, 2009 | Microsoft Windows Live Messanger
Olve error code 80072ed quickly and easily
5. Click OK.
Sep 25, 2009 | Microsoft Windows Live Messanger
Cant sign in to wlm
5. Click OK.
Sep 16, 2009 | Microsoft Windows Live Messanger
Edimax BR-6574n wifi VPN connection problem
I have reseted the router configuration back to Factory Default, and set it up again from the beginning. I think the problem was at the firewall settings.
Aug 24, 2009 | Edimax PRI-682 Router (PRI682)
Instructions how to connect ps3 to internet
THERE 2 MANY WAYS YOU CAN CONNECT THE PS3 TO INTERNET:
1) WIRED CONNECTION
2) WIRELESS CONNECTION
1) WIRED CONNECTION
JUST CONNECT THE ADSL WIRE TO THE PS3. GO TO NETWORK SETTINGS AND CREATE A CONNECTION. THEN TEST CONNECTION.
2) WIRELESS CONNECTION ( THE BEST WAY TO CONNECT TO THE INTERNET)
IF YOU HAVE A WIRELESS ROUTER YOU CAN CONNECT YOUR PS3 TO THE INTERNET. GO TO NETWORK SETTINGS AND CREATE A CONNECTION. THEN TEST CONNECTION.
Jul 11, 2009 | Sony PlayStation Portable (PSP) Console
Can't connect to 3Com Office connect wireless from Apple Mac Pro
PPPoE connection is set up
1. Control Panel, double-click Network Connections. 2. Click the PPPoE connection under the Broadband group that you want to share, and then click Change settings of this connection under Network Tasks. 3. On the Advanced tab, click to select the Allow other network users to connect through this computer's Internet connection check box. 4. PPPoE connections behave in a similar way as do dial-up networking (DUN) connections, and you may want the connection to be automatically dialed when another computer on your network attempts to connect to the Internet. To do this, click to select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box. 5. If you want to allow other network users to enable or disable the shared Internet connection, click to select the Allow other network users to control or disable the shared Internet connection check box. 6. Under Internet Connection Sharing, in Home networking connection, click the LAN (Local Area Network) connection that connects the computer that is sharing its PPPoE Internet connection to the other computers on your network.
Feb 07, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
61 people viewed this question
 Grubhead
Grubhead
