Question about Microsoft Windows 98 for PC
Starting problem i was at work forgotten to turn lights off on my 98 ford explorer xlt battery was dead so i gotten a boost made it home let it run for a few turn off about an hr latr try to start it lights came on but heard a click didnt crank up what should i do?
  • 3,799 Answers
Ford explorers do not have an operating system. Try asking in the CArs & Trucks section.
Posted on Apr 26, 2013
2003 ford explorer xlt battery good but engine will not turn over
Keep in mind that the engine takes a lot more Amps to turn then it takes to light lights and open windows.
If it is as cold outside by you as it is here, a weak battery may not turn over an engine even with lights lighting and windows opening. First thing... clean connections at the battery
Jan 05, 2016 | 2003 Ford Explorer
Why my power windows,dome lights,dont work plus car wont start
ok a lot not said here trouble shooting time. does the battery have a full charge "no" put a charge on it. battery wont charge and still wont do a thing dead battery get another one. ok battery charged and all works undo the positive cable on battery, if it still runs "good" if not alternator is bad. hope this helps not much to go on
Sep 09, 2014 | 2004 Ford Explorer XLT
As soon as I shut off my truck it wont restart like the battery is dead
TRY CLEANING YOUR BATTERY POST. IF YOU HAVE SIDE POST YOU MIGHT NOT SEE THE BUILD UP. PULL BACK THE RUBBER AROUND THE CABLE END AN CLEEN OR GET NEW CABLES. o GO TO YOUR PARTS STORE AN THEY WILL CHECK THE BAT AN ALT FOR FREE.
Nov 30, 2013 | 2003 Ford Explorer Sport
2004 Ford Explore won't turn over
whilst you are trying to jump start it check if you jump leads are good and powerful enough to sent the power to your battery,check if your battery terminals are clean enough to accept the power given,or is your battery not completely dead and even you are boosting has not the power to increase the needing one to start and is just for lights only?
Sep 17, 2012 | 2004 Ford Explorer
Battery light flashing
The battery light on, is an indication of alternator failure. If your battery is more than 3 years old it needs replacement . A bad battery can damage a new alternator (full field condition). The age of your truck warrants inspection of the charging system. It requires at Least 20 amps output, from the alternator to run the engine.
May 19, 2017 | 2004 Ford Explorer
98 Ford Explorer timing chain and engine trouble
sure you an, but make sure you swap all the electronics to fit the 98
Jul 20, 2010 | Ford Explorer Sport Cars & Trucks
My truck had been running fine, got up this
it sounds like your starter relay its located inside the engine compartment fuse and relay box .good luck
Oct 23, 2009 | 2006 Ford Explorer
Does 98 ford explorer has a microchip in the key
Yes it does have a microchip did they replace it with the right key switch and try unplugging the negative battery cable for about a minute to reset the computer
Aug 01, 2009 | 1998 Ford Explorer
1998 Ford Explorer. Won't start, just clicks, with new battery.
check that the cabling going to the starter is ok. and the ground to the frame and the engine block.the other thing is that it is possible the starter has a "dead spot" in it.have someone turn the key to start and bang on the starter with a hammer .not too hard.the starter on ford starters usually have a solenoid and it is possible that is no good either...
cheers ed
Jul 13, 2009 | Pro-Fit Pro.Fit Fo 71 02 Ford...
Microsoft Windows 98 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
