Question about Roland Music
Internal battery replacement
Problem after battery replacement with Roland A-90: Even the replacement was successful (and the Reset of Roland A-90 completed) the sound is just running for 30 seconds then disappears showing after some flickering a blank but lit display. Sometimes it shows very shortly the message internal battery: NONE! i looked at it again, but I could not recognize that there might be a contact issue at the battery socket. It is placed pretty firmly in the socket. So what else could it be?
  • 5603 Answers
SOURCE: I have a Roland D110 sound module. The rhythm
I would check to see if the unit has either a Lithium or NiCad backup battery in it which MIGHT be exhausted and need replacing.
Posted on Apr 01, 2010
SOURCE: The LCD display on our yamaha DGX620 has
i have the same problem after lending it out to someone, could it be that it was left on for a long period of time ? did you find a solution yet?
Posted on Jun 18, 2010
  • 5603 Answers
SOURCE: My Roland KR-4700 keyboard will come on and play
This si likely a problem in the power supply. The regulator is probably failing and dropping the voltage to the processor below what it will operate.
The probkem PROBABLY can be isolated with freeze mist circuit cooler.
First step is to check the voltage of the 5 volt source after it fails.
If you are not adept at electronics this is not a DIY thing.
Posted on Jul 05, 2010
Testimonial: "So nice to talk to someone intelligent! Really appreciate the expert advice!"
  • 1138 Answers
SOURCE: the display of my roland XP-80 is Zero, &
The procedure at this link shows you a battery replacement procedure that should work for you:http://ztup.com/Roland-D110-Battery-Replacement-Guide.htm You will need to design new user patches if you didn't back them up.
Posted on Jul 13, 2010
  • 101 Answers
SOURCE: I have a Roland FP-8 that I used for performances.
you have some internal components bad audio output IC, capacitors, driver transistors etc. your doing nothing wrong.
maybe just don't leave it on if your not playing it. Heat kills Electronics.
Posted on Jan 01, 2011
How to open a Roland RA-90 to replace battery
Get the manual from web site and it will tell you how to replace the battery.
Sep 23, 2017 | Roland Music
I have a roland e96 trouble. Fist indikator in lcd internal battrey low, but not change the battey. now my roland e96 is blank.
You need to replace the battery. It will most likely be a coin sized battery in a slip in holder on the main board. If you need help, here is ROland Customer Service contact info-
Support Roland
After that, you can reset the E96 back to the factory settings by following the directions here-
Roland 96 Initializing the 70 86 96 Restoring the Factory Settings...
Mar 18, 2015 | Roland Music
I have a roland e96 that showed the message_INTERNAL BATTERY WEAK every time i switch on and the display of screen is empty
It's likely a coin battery, like the type in a computer, used to keep the bios or settings ram user settings (whatever)memory
Nov 30, 2014 | Roland Music
I lost the internal data of roland e96
If you are referring to the User Data, then yes that would be gone.
Time to reset and start re-programming
The roland d10 powers up but none of the buttons or keys work? the screen just says "roland d10 synth"? please help!
The unit name is part of the boot sequence, it should go beyond that and boot up completely. If it gets stuck there, there is surely some problem. Maybe a depleted internal battery, I don't know. Ask a local service center, maybe there's a combination of buttons you could check out while on the phone prior to bringing it in for repair...
Jan 07, 2013 | Music
Does anyone know hot to change a Roland E-70 musical keyboard's internal battery?
Well I did it. Remove 14 screws marked with arrows. Be careful separating the top from the bottom as there are several cables to deal with. The only cable I disconnected was the larger Ribbon Cable. The CR 2032 battery slides out by lifting the end of the retainer about 1/16 of an inch. Then simply slide in the new battery and make sure it is seated. Then just reassemble.
Aug 18, 2012 | Music
I have a Roland xp60 that produces no sound! Everything else seems to be fine - the display registers that I am hitting the keys & even the skip-back sampling feature produces a wav file I can see on...
Two things come to mind: 1. These synths have mute and output control settings. Verify they are correct as even a factory reset might not set them to default. 2. The next thing is that the volume control itself is damaged which requires internal investigation. Was this working and was there an accident with it... dropping manhandling, or accident with power or cables? There could be a cable that has fallen off between the main board and where the audio outs and jacks are. Be very careful if you open this of ribbon cables from the halves of the shell.
Sep 17, 2011 | Roland FANTOMG8
I have one AC 90 110 volts, and have used it in 220 volts. I think the internal fuse is broken. The solution is only change the broken fuse for a new one?
That will be step 1 to what will probolly become quiet a bit of problems. I'm not huge on this unit but generally speaking if you opened the chassis your going to see a few burnt components (rectifier,diodes,transistors). But lucky 220 hits so hard it's usually just a replace the stuff you see burnt (get schematic if possible) it's a pretty straight forward repair.
Sep 08, 2011 | Roland Ac-90 Acoustic Chorus Guitar Amp...
I wanna learn the circuit diagram of roland gw8
You would have to get the circuit schematic from Roland and they may not give that out as it is proprietary. I have circuts for Fantom and Yamaha Tyros and believe me you won't learn anything beyond the block diagram. The circuit details are BURIED inside chips that you probably can't even get data sheets on and certainly can't get or understand the firmware of the internal operating system.
Feb 16, 2011 | Roland GW8 Keyboard Arranger
Music Logo
100 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
