Question about EliteGroup Computers & Internet
I switch on my computer then it blacksout after about 5 minutes
    Brigadier General:
  • EliteGroup Master
  • 3,400 Answers
Is it a homebuild computer ?.so as you describe it ishould think the processor (CPU) is overheated and the computer shouts down to protect the processor.you should check cpu-fan and heatsink.maybe they need some thermal paste.or invest in a better cpu-fan and heatsink.
Posted on Apr 26, 2013
When turned on it it loads operating sytem and then blacksout
Turn on your computer then Press F8 rapidly until a troubleshooting choices appear, choose SAFE MODE and wait for it to load. After booting to windows safe mode go to start>run>cmd and type chkdsk /r then reboot.
Aug 09, 2013 | HP Compaq Presario V2000 Notebook
My tv blacksouts with no picture but has sound?
tried with resetting doesn't work?totally black screen or has a white screen display?
Sep 30, 2012 | Samsung PN50B430 50 in. TV
1993 Buick cuts off while driving and will not crank for 5 minutes. The car will easily restart after it has set for about 5 minutes but cuts off again after about 30 seconds. It does not run rough at any...
This sounds like a problem with the ignition interlock system. This system uses a chip in the ignition key to tell the computer it is the right key in the ignition, and allows the starter to engage. If the key switch is worn out, or the key itself, the vibration from driving can jar the key in the ignition and cause the computer to shut the ignition off. If the key and switch are tight and have no play, there could be a glitch in the computer. You can have this checked by a good auto technician shop. GOODLUCK!
Apr 19, 2011 | 1993 Buick LeSabre
I installed the new filter but the red light is still on. What should I do to turn off the red light. Tks in advance
On the refrigerator side: Open the door and press the light switch in and out 5- times so you can reset the computer, do this quickly. If this fails, try unplugging the refrigerator for a minimum of 5-minutes. Plug unit back on after 5-minutes- this should reset PC.
Oct 05, 2010 | Maytag MZD2667HE Side by Side Refrigerator
Monitor color is pink at switch on. 5-10 minutes after normal
There are many things that could be causing that, but to fix it would take some electronic equipment, schematic, and know-how. It could be as simple as a faulty potentiomet, but a shop would charge you more than it's worth to fix it. My advice is to live with it until it gets too bad, and invest in a new one If you're not ready to advance to the LCD monitors yet, check with a Used Computer Store- they usually have CRT monitors at a reasonable price. Hope this helps.
Mar 25, 2010 | SAMTRON 55V 15" CRT Monitor
Sometimes one of my computers *always same one) doesn't recognize the mouse and keyboard.
This is a common problem with KVM switches. To isolate the problem, here's what you need to do:
1. First, connect the keyboard and mouse directly to the problem computer to ensure that the keyboard and mouse works correctly while being directly connected.
2. Swap the connection of two computers. If you're having a problem on the computer that is connected to port 1 of the KVM, connect that computer to port 2 of the switch or just swap the connection. If the problem recur on port 1, then there's a problem with the keyboard and mouse cable on port 1.
3. But if you're not able to duplicate the problem on port 1 or 2, disconnect the KVM switch from the computers, leave it disconnected for 5 minutes.
4. After 5 minutes, reconnect the KVM to the computers and reboot the computers.
5. If same problem occur, then contact the manufacturer of the KVM and have them RMA the device.
Thank you!
Feb 09, 2010 | Edimax EK-PS2C (EKPS2C) 2-port KVM Switch
My screen only displays after 4 /5 hrs
Try a different screensaver.
Also look in the display properties by simply right clicking the desktop and clicking properties.
Then locate power management.
the initial seems to be a bad screensaver judging by the 20 minutes, but the 4-5 hours seems to be a sleep mode that bypasses the screensaver issue.
Jul 23, 2009 | Computers & Internet
No sreen after startup window
Boot your system into safe mode and reduce the resolution to your monitor. It is set to high and blacksout because of memory. Besure to use F8 in order to enter safe mode before windows start.
Good Luck
Fehdi
Mar 28, 2009 | Dell Computers & Internet
Red lines flashing red then blacksout
Their is only two possible things they are Bad Red picture tube or video ic on red CRT board more then likley its your Red Picture Tube.
Sep 21, 2008 | Sony KP-57WV600 57" Rear Projection...
Non Displaying any things for a 5 to 10 minutes in first instance startup
this may seem unusual but try unplugging power cord from the back of computer for 5 minutes then fit power cord and try again sometimes the bios get upset and has trouble finding hard drives etc.
Jul 25, 2008 | Intel DG31PR Motherboard
Computers & Internet Logo
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
