Question about Epson Stylus CX4600 All-In-One InkJet Printer
Error masege "part end life" at Epson CX4600
I replaced the ink cartridge with a refill one which has ink leakage. I know the Epson CX4600 printer's parts are okay but a lot of ink dropped into the printer and caused the control panel LED to flash and the computer says the printer part is end life and need to call service to repair. I replaced four new ink cartridge and cleared the printer moving parts but the error message did not go away and the printer still does not work. Can you tell me how to reset the printer to remove the error message in the control panel and let it work again? Thanks, jdw
    Problem Solver:
  • 5 Answers
Go to the Epson website and download the reset program and run it.
They will have a disclaimer telling you that the ink pad MUST be replaced by a trained tech, or the ink will overflow and short out electrical parts. I have had my printer for over 5 years and most of my ink goes into the ink pad as I dont use it much and most of the time at least one of the print heads is clogged, my pad was no where near overflowing. I soaked up as much as I could with tissues.
If you move the catridges to the left and look down you will see the ink pad. Use rubber gloves, it is very messy
This is a utility to manage your ink. Gives an accurate count of how many ink shot are left in each cartridge. The print told me I need a new magenta but this program says I have 13% left. It also has sepparate routines for cleaning the black and color (unfortunately not individual cartridges)
http://www.ssclg.com/epsone.shtml
Posted on Jul 19, 2009
I had the same problem, and i did not find the actual solution here.. the problem is just an old waste ink pad. if you move the thing that holds all of your ink cartridge, you should see a blue ink bad. replace that or get a bunch of tissue and qtips to dry it up by pressing on it (your hands will get very dirty). then you need to download a software to reset the value of your "protection counter." i got the solution from here:
http://www.edmartechguide.com/2007/11/parts-inside-your-printer-are-at-end-of.html
once you install the software, just close it (it will actually minimize it to your task bar). then right click it >> protection counter >> reset protection counter. if u want, you can even check your current value. i had 39000/36000, which is why i keep getting that error "E" or end of life. once you reset the counter, just turn off your printer, and turn it back on. it'll work like it is brand new.
HOWEVER, if you did not replace your pad, you wanna clean that thing as much as you can and as frequent because even though the value will be reset to 0, once you print that value will jump to maybe 20000 depending on how well u cleaned it. then you will have to go through the process of resetting it again (which is no big deal). hope this helped
Posted on May 04, 2008
  • CX4600 Help May 04, 2008
    edit: link was not fully posted. click here to get to the resource site
Using refills has almost certainly filled up your waste pads - apart from messing up the electronics - so you will need to replace thse before it works again. Mick
Posted on Aug 06, 2007
Replace cartridge screen stuck
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 01, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Just put new ink cartridges in, but yellow is out. Do I need full yellow cartridge in order to print? Printer is not printing.
Did you use Epson Genuine Cartridges? Brother Genuine Cartirdges????
Mar 25, 2010 | Epson Stylus CX4600 All-In-One InkJet...
Hi.igot an epson stylus sx125 i want to replace ink cartages but it says ink cartridges not recognized
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
Mar 18, 2010 | Epson Office Equipment & Supplies
Epson CX3900 says all cartridges empty but not true
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
Also go thru the utility to change cartridges. This will make the chip know that you have all new cartridges and will move the ink station in place.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
This is the only advice I can give you. If you find this helpful, pls rate me.
Feb 04, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
I replaced the ink cartridge but it says out of ink
I received that same message when I was using Generic. Please read on.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
Jan 31, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Replaced the black ink cartridge, pressed the ok button and it states to replaced the black ink cartridge. I have opened it and checked to make sure it has been installed correctly several times and it...
Jan 23, 2010 | Epson Stylus NX400 InkJet Printer
The ink does not flow after replacing cartridges. The printer was unused for a long time
Throw away the old cartridges and purchase Epson Genuine Cartridges.
Good Luck.
Jan 19, 2010 | Epson Stylus RX500 All-In-One InkJet...
Epson Tylus CX4600 ink light
If any ink cartridge is empty, you won't be able to print until you replace the empty cartridge. Leave any empty cartridge installed in the device until you have obtained a replacement.
The print heads will clog up in a week or two. So you also won't be able to print until you clean the print heads.
This is a utility to manage your ink. Gives an accurate count of how many ink shots are left in each cartridge. The printer told me I need a new magenta but this program says I have 13% left. It also has separate routines for cleaning the black and color (unfortunately not individual cartridges)
May 18, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus Printer CX4600
I don't know if this will work on an Epson, but it does on Cannon. The pads on the cartridges or the ink jets in the printer head may be cloged with dry ink. Get some Q-tips and rubbing alcohol (water is a poor substitute). Take out the ink cartridges and touch the pad on the bottom with a Q-tip (one for each color). If there is color the cartridge pad is OK. Take a fresh Q-tip dip it in rubbing alcohol and GENTLY rub the little holes on the bottom of the plastic box the cartridges go in. Thse are the print head jets. You should see color. You may need to clean it a couple of times if the ink has dried down into the jets. It is OK to have the Q-tip pretty wet, but not dripping.
Hope this helps
Dec 03, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus CX4600 All-In-One InkJet Printer Logo
1,274 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
