Question about Sony DSR-11 DV / Mini DV VCR
Tape stuck inside
I recently put a dvcam tape into the deck after using it with the miniDV option on another job. The deck is now in a mode where it will not shut itself off, eject the tape, or react to any of the buttons I push. Instead, it jumps between trying to play the tape and trying to rewind it continuously. Is there anything I can try to do or is there a simple way to open up the machine to get the tape out and see if that solves the problem?
  • Anonymous Sep 02, 2008
    i also have the same issue. grump.
  • jerzybondov Sep 03, 2008
    I had the same problem as this - got an error code C:31:11 popping up. Tape would play, rewind and forward wind but would not eject. Tried turning power off, on. Unplugging etc. No joy.
    Found this solution by Guest - worked a treat. Take the top off, push back the described gear. Out pops the tape. Thank you!!
    Novelist:
    Scholar:
  • 158 Answers
There is screws on the unit when the unit goes into rewind mode disconnect from mains and unscrew unit first check to see if the screws are scurity type haveng a hex or star shape on them if either then take to video and tv repair shop and explain that you need to remove a tape from unit you may have to pay for a small fee for it to be removed this part is all i can give but if you can remove screws yourself then locate the motor for tape ejet and load and manualy wind till tape is removed good luck
Posted on Aug 13, 2007
Yes,first remove the power to the unit, pop the top lid off, (4 screws) then u will see a controle board secured on top, there are 2 screswes on teh side, becareful not to break any of the wires connected to the board when sliding out of the way. below this board is where the tape is located. You should notice a number of visable plastic grears onthe side of the loading mechanisim. there reall is only one u need to be concerned with, It is Located on the left side of the motor, motor is located to the rear left side of the mechanisim. there u will see a long a FLAT gear, just to the left of the motor, there is a small amount of play in this gear, push this geer twords the rear of the unit and hold it there, reinsert the powersupply and press eject, this will tigger the eject mechanism and pop the tape out.
Posted on Aug 08, 2008
  • 11 more comments
  • stinsongs Jan 12, 2011
    Thank you. Your solution worked for me.
    Gratefully,
    ~jim
  • MidnightHour Feb 14, 2011
    Outstanding, the gear trick worked. Thanks!!
  • Strapscan Mar 30, 2011
    Thanks this saved me! Does anyone know what this means though? Is the deck screwed? Does it need serviced now? It has VERY low hours. Is this an anomaly that you get with certain tapes? Any advice would be great!
  • simon_gar445
    simon_gar445 Mar 12, 2012
    So incredibly grateful for this brilliant solution - thank you.
  • simon_gar445
    Brilliant solution for tape stuck in DSR-11 problem - thank you so very much
  • Reimon Oshana
    Reimon Oshana Jul 31, 2012
    God Bless you :)
  • bryanawelon
    bryanawelon Feb 20, 2013
    Many thanks for this excellent advice and guidance. I have just done as Guest mentioned, my tape is out and once again(at the moment) the DSR11 is working fine. many thanks. Bryan
  • Tony Wade Sep 04, 2013
    Your guest solution worked great. Many thanks, life saver!!
  • John Luther
    John Luther Apr 15, 2014
    IT WORKED!!! Anymoyus is right! FANTASTIC I got the casset out, a small amount of tape was extending out from under the closed protective casset hatch, the tape was slightly crinkled. I I wound it onto the spools, reinserted the casset and it is working again. God Bless.
  • Simon-Lee
    Simon-Lee Sep 12, 2014
    It really worked. Thank you All!
  • Morteza Parkook
    Morteza Parkook Oct 28, 2014
    Thank you!!! it worked indeed
  • Ramon
    Ramon Jan 05, 2016
    Thanks Anonymous... Made my day!
  • Eddie Bello
    Eddie Bello Apr 27, 2018
    Anonymous .. thank you so much for that!!
SOURCE:
DSR-11 will not record in DV SP mode.
dear, u need to change the memory cell of ur dsr-11 ,
Jul 29, 2009 | Sony DSR-11 DV / Mini DV VCR
Can't eject tape from deck
On Sony DSR-80P error 02-221 and 02-291 is a problem with the tape pull-in or eject. Mostly the tape stickers are bad situated over the stripe-cover at the top, which should be moving freely!
Remove the stickers from the tape or put them lower on the case. If the tape is already inside the machine is unable to reject the tape - disconnect the machine from electricity to open it or call service...
greetings from berlin, matt.
Jul 05, 2009 | Sony HVR-1500 HDV VCR
Can the Panasonic AG-DV2500 play 90 minutes Minidv tapes?
the DV2500 will not play LP (90 minute) tapes. when an LP tape is inserted, it will play for 2-3 seconds, and then eject.
Nov 28, 2008 | Panasonic AG-DV2500 DV/Mini DV VCR
With MiniDV tapes, the DVCam indicator ignites and the reading becomes jerked.
It could be several things causing your problem. The video head may be worn, the tape guides may be out of alignment or you may have a mechanism problem keeping the tape from wrapping securely around the rotating drum. If you can use an oscilloscope, you should check the RF signal coming off the drum test point to see if it is clean, or if half the signal is missing (bad drum or video head) or not smooth (guides out of adjustment).
Nov 08, 2008 | JVC BR-DV3000U DV/Mini DV VCR
MiniDV tape stuck inside
sounds like a defective cassette housing, but i have seen problems with jvc decks and camera when tdk or maxell tapes were used. the lids on these tapes seem to get stuck in the cassette housings in jvc equipment. jvc even recommends that tdk and maxell tapes be avoided.
May 24, 2008 | JVC BR-DV3000U DV/Mini DV VCR
Canon ZR 45 Won't Eject Tape
That would be the take up or supply reel fault. It may also be a mode position error. Try here for advice but I don't advise tackling this job without full service instruction manual for the deck. No idea of your country so try here first;
https://www.usa.canon.com/internet/portal/us/home/support/details/camcorders/support-minidv-camcorders/zr
Apr 15, 2017 | Video Cameras
Sony DSR-11 DV / Mini DV VCR Logo
2,228 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
