Question about Locks & Locksmithing
Digiper electronic lock
How to Change the Code on a Door Lock
  • 8 Answers
SOURCE: How do I change combo of electronic lock
Have you tried removing the cover (inside the house).. there should be a program button, which you press, enter your code, and press again....don't forget to try your code before actually locking the door...
Hope this helps
Posted on Jan 08, 2009
SOURCE: I have a Unican 4000 series electronic door lever
Unican 4000 factory-default master code is 12345678
Posted on Mar 08, 2011
  • 963 Answers
SOURCE: I want to change the 6 number code for opening the
This link will take you to a PDF file of the programming instructions. It will require that you have Adobe Reader or similar installed to view the file:
http://napcosecurity.com/download/Res-Priv_DL4X00_WI1194B.18_PROG.pdf
Posted on Apr 10, 2011
  • 15 Answers
SOURCE: Have a Rona electronic lock (Weiser) and the key
First, I fix this problem after an hour of try.
I conclude that this dorr lock is better that is appear. Is not a 2 codes door lock, it's a 3 codes one.. and the problem you have is the third code not reset. You can put the same code in each third emplacement. you have just to press the program button 3 time for the third code...
I determinate that I put the third code by error the was i program it the firs time.
I guide you...
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Posted on May 15, 2011
  • 101 Answers
SOURCE: Lock is non-responsive, even after replacing the
There is only a one year warranty on the electronics. Check the installation manual for a reset procedure and double-check the battery installation & electrical connections. Most manufacturers do not sell the electronic parts separately, ans it might actually cost more to repair an electronic lock than replace it.
Posted on Aug 26, 2011
Change code
If it is locked and the person you got it from didn't give you the existing code, you can't. We see this all the time. If there was a way to bypass the code to the safe, anyone could do it. They are called a 'safe' for a reason, the contents are safe once the door is closed and locked :-) The only way to get in is to take to a locksmith who will drill the door, open it and put a new door on it. This is not usually a cost effective open with a small locker type safe.
Nov 23, 2015 | Home Security
How do i change the code on this lock
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Jan 31, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Need to change code.
There is a video on this page, showing how to change codes.
Jan 29, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
How do i change my code?
Nov 27, 2010 | Schlage BE365-CAM BE365CAM619 Satin...
How do i change the code???
Nov 27, 2010 | Schlage BE365-PLY BE365PLY626 Satin...
How do I change the combination?
Nov 19, 2010 | Schlage BE365-CAM BE365CAM619 Satin...
I have a schaeg BE365 and i would like to change the coad
Nov 14, 2010 | Schlage BE365-PLY BE365PLY626 Satin...
Change code
Try this
Open the safe.
press the red button on inside of door
entry the new code you want followed by B
Should be good
Nov 22, 2009 | Safe International Digital Electronic Safe...
Hope this helps
Jan 07, 2009 | Weiser Lock POWERBOLT ELEC DEADBOLT
Locks & Locksmithing Logo
138 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
