Question about Samsung Galaxy Mini S5570 Android 2.2 Unlocked World Phone - Lim
Carburetor air screw adjustment - Samsung Galaxy Mini S5570 Android 2.2 Unlocked World Phone - Lim
  • Samsung Master
  • 7,482 Answers
Hi Hya
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Please take time to rate me
Bud
Posted on Apr 27, 2013
Could some help me with factory carb settings on this saw
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
store.chainsawr.com/.../tuning.../1126042-adjustment-and-tuning-of-a-c...
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws ... These saws have what is called a "fixed jet" which is set from the factory.
Stihl Chainsaw Carburetor Adjustment - Tune-up Settings
tekindoor.com > MISC
Stihl chainsaw's have three carburetor adjustment screws (LA) Idle Speed screw - This ... When the engine is tested at the factory the carburetor is set to obtain a ...
How to Adjust the Air and Fuel on a Stihl Chainsaw ' Home ...
homeguides.sfgate.com > ... > Adjustable Mortgage Rates
The fuel/air mixture in any gasoline-powered engine is regulated by the carburetor, and the carburetor in a Stihl chainsaw is factory-adjusted to provide the best performance.... You'll find three adjustment screws for the carburetor, usually located under the air filter cover.
Factory carb setting on Craftsman 2.0 or Poulan Micro ' Firewood
Dec 04, 2015 | Garden
I have a John Deere Riding lawn mower which starts
Hello roobar2009:
>>From your Description it Sounds like a Carburetor Problem, a Bad Fuel Filter or Bad Gas.
>>If you have Changed the Filter and the Gas and the Problem is Still happening, then
>>The Following is a Simple Way to make Sure the Engine is Getting Gas from the Carburetor to Run.
>>If the Engine Starts and Quits, then Check the Carburetor Solenoid.
>>If the Carburetor Solenoid is Good or has been Removed and the Engine will Start and Quit when the Gas is Poured into the Carburetor Throat, then Soak and Clean the Carburetor.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 17, 2009 | Garden
Toro lawnmower starts then cuts off. It appears to be leaking fu
If there is a fuel leak causing this problem it could be from the line going to the carburetor or the float bowl. If no leak is present there, could be flooding or a sticking needle in the carburetor allowing fuel to enter constantly.
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Tooo much fuel pull cord fuel expels through exhast.
Hello aurora12104:
The Carburetor Float Needle Valve is Not Seating Properly and is Causing the Engine to Flood or the Head Gasket is Blown between the Push Tube Galley and Cylinder and the Head Gasket Requires Replacing.
Check the Oil and Make Sure it has Not become Contaminated with Gas. Change Oil if it has a Gas Smell or the Crankcase is Over Filled.
Soak and Clean the Carburetor and Replace the Float Needle Valve.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Good Luck
Respectfully
jbridger (John)
May 12, 2009 | Garden
Tiller motor set up for six years and now the motor will not start.I cleaned the gas tank,carb. ect.When I try to start it gas comes out of the muffler.What can I do to start the motor.
Hello
If you Used Spray Cleaner to Clean the Carburetor, then you Need to Remove the Carburetor and Soak it in Cleaner Overnight. The Float Needle Valve is Sticking and Flooding the Engine.
>>I Suggest you Make Sure the Gas is Free Flowing to the Carburetor Inlet Port (if the Model does Not have a Fuel Pump). If the Gas is Free Flowing to the Inlet Port, then
>>**Remove, Disassemble and Soak the Carburetor Overnight in Carburetor Cleaner (I Use Gunk).
>>The Primer Bulb is Held in Place with a Locking Collar at the Base of the Primer Bulb. Use a Small Flat Screw Driver and Carefully Pry the Lock Ring Up in Small Amounts All Around the Lock Ring until the Lock Ring and Primer Bulb can be Removed from the Carburetor Body. Usually a New Primer Bulb is Required when you have to Soak the Carburetor. The Rubber is Usually Rotted to Much for the Primer to be Reused.
>>Your Primer Bulb May Differ Slightly, but Removal is Usually Almost the Same Except for the Primer Bulbs that are Bolted to the Carburetor. These are Simply Unbolted and Changed with the new Primer Bulb.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve and Needle Valve Seat if Applicable. This is a Flat O-Ring Located in the Inlet Port the Float Needle Rests in. Use a Strong Wire with a Slight Bend to Remove the Old Seat. Sometimes a Small Pocket Screw Driver can be Use Also.
>>The New Seat will have a Slightly Beveled Side and a Flat Side. The Flat Side goes Towards the Carburetor Body when Inserted into the Inlet Port. Spray the Seat with Spray Lubricant to make Installation Easier. The End of a Drill Bit that is Slightly Small than the Seat can be Use as an Insertion Tool.
>>Wear Gloves or Use a Rag when Handling the Sharpened End of the Drill Bit. Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. Even the O-Ring Around the Bowl can be Reused if it is Not Broken. The Only Parts you May Need to Replace is the Float Needle Valve (and Seat if Applicable).
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Garden
Is the carb adjustment screw on bottom
Hello
>>The Following is an Instruction File I made for Correcting this Problem. Any Input is Appreciated.
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is the Nearest to the Engine.
>>The Engine Idle Screw is Usually Easy to Identify because you can See where it Makes Contact with the Carburetor Throttle Shaft Plate Stop Ear. The H and L Air Mixture Screws Go Into the Body of the Carburetor and the Tips Cannot be Seen.
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns.****
>>Reset the Engine Idle if Required. If This Carburetor has a Single Air Adjustment.
>>Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Rapidly Throttling from Idle to Full Throttle.**
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
When i start my mower gas seems to come out of muffler or the vents around it
Hello
IS the Crankcase Oil Over Filled and have a Gas Smell to it?
If Yes, then the Carburetor Float Needle Valve is Not Seating Correctly and is Flooding the Engine when the Engine is Not Running or the Head Gasket is Blown Between the Push Tube Galley and the Cylinder.
Good Luck
Respectfully
jbridger (John)
May 10, 2009 | Garden
We bought a Swisher T11544 44" Trailmower with a 11.5 Gross HP Briggs & Stratton Engine. It only runs for 3-5 seconds then it stops?
Hello:
From your Brief Description it Sounds like the Carburetor Requires Cleaning.
Good Luck
Respectfully
John
May 08, 2009 | Swisher 44 Iinch 11.5 Hp Trailmower...
After I start my lawnmower, the rpm?s oscillates up and down for aprox 15 to 40 sec and then stabilizes.
Hello:
>>The Cause of this is a Slightly Restricted Passage or Jet in the Carburetor and it Takes a Few Seconds for the Governor the Engine at a Slightly Higher RPM to Compensate for the Restriction.
>>The Restriction is Usually Varnish that Builds up Over Time and Usually Requires Soaking the Carburetor Overnight in Cleaner to Correct this Problem.
Hope this Helps. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Apr 22, 2009 | Garden
Mower will only run if choke is on
Hello cmsbss:
>>From your Description it Sounds like the Carburetor requires Soaking and Cleaning.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Apr 21, 2009 | Troy-Bilt Pony Garden Tiller
Samsung Galaxy Mini S5570 Android 2.2 Unlocked World Phone - Lim Logo
53 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
