Question about HP Compaq Presario SR1430NX (PS566AA) PC Desktop
HP Compaq Presario SR1430NX Powering On Issues...HELP!!??!??
I'm having issues powering on my HP Compaq Presario SR1430NX. It's been having issues for a while. I'll power it off and unplug it to apply thermal paste to the processor/heat sink and then it'll take a while to be able to power on. This time the computer has been taking longer than usual. The power supply is fine and I've tried unplugging everything (all power cords, keyboard, mouse, etc) and plugging them back in but it still won't power on. Usually unplugging all power and plugging it back in works just not this time. I'm trying to find out what else could cause power on issues. Any feedback would be much appreciated.
  • Louis
    Louis Apr 26, 2013
    [EDIT] I've tried the unplugging and holding the power button trick. It didn't work!!!
  • HP Master
  • 3,799 Answers
If the power supply is "Fine" then it has to be your motherboard. Look for the capacitors around the board. They should have either a dished or flat top. If any are domed or have a powdery substance on them, they will need replacing. Or if you don't want to do this, replace the board.
Posted on Apr 26, 2013
Hi please help me, my compaq presario 1700 flickers then i dont see anything the screen turns into black, but the sound is ok and its not hibernating, and overheating, but sometimes it comes back to normal...
This is most likely an hardware related issue in which case you need to get it checked. To narrow the issue, you can try hooking up your laptop to an external monitor if possible and see if it does the same. If not, then there's probably an issue with the displays internal connectors. You can also try powering your laptop with only the power cable attached and without the battery, then reset all power management settings. If the problem goes away then it's probably a power management issue.
Apr 18, 2011 | HP Compaq Presario 1700T Notebook
I have a compaq presario sr1430nx and am trying to install new hard drive. i got recovery dics and they install but computer is stalling on one-time setup process. just goes on for hours and hours.. Any...
Hi!
I worked with HP before, their computer hardware have what they so called "System Tattoo", this prevents the end users to change any hardware in the computer. You may try calling them at 800-474-6836. Hope this helps even a bit.
Apr 16, 2011 | HP Compaq Presario SR1430NX (PS566AA) PC...
Can i get a new processor fan for my Compaq presario SR1430NX? I have a Intel Pentium 4CPU 2.93GHz processor
Yes, new fans are available online at sites like http://newegg.com, These are sold to match the processor so make sure you select one for your EXACT model, to avoid damage. These are difficult and complex to install however and I would not recommend doing it unless you are a computer expert, take it in to your local HP service provider to have the fan replaced, fans are about 15-30 dollars, so don't let them rip you off. Hope this helps.
Mar 15, 2011 | HP Compaq Presario SR1430NX (PS566AA) PC...
Good day.. my compaq presario cq40..is powering on but blank on the screen and caps lock and num lock blingking only..thanks
Hello good day,sir
My compaq presario cq40..is powering on but blank on the screen and caps lock and num lock blingking only.I try ready so many time but everything are not meaning for me that's why i need your help,sir.please,give me some advice for power back.
Thank sir.
Feb 18, 2011 | HP Compaq 6735s Notebook
COMPAQ presario SR1430NX ... when i plug the ethenet cable in back of computer I get no network lights
There could be a couple of reasons for this.
Swap the ends of the cable and attempt to connect.
Please use a known good cable.
Please ensure that the network adapter is properly installed.
For checking this, please go to the device manager and see if you have any yellow exclamation marks on the same.
In case this does not help you, please reply with the Operating System name, Router/Switch model name.
If this doesn't work for you, please comment and let me know, and I will be happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
Nov 01, 2010 | HP Compaq Presario SR1430NX (PS566AA) PC...
I do not have motherboard driving disc
This is HP Support, and the Drivers and Downloads page for the Compaq Presario SR1430NX Desktop Computer,
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=459491
(Using Windows XP as an Operating System)
Nov 07, 2009 | HP Compaq Presario SR1430NX (PS566AA) PC...
Compaq Presario sr1000(sr1430NX) will not stay powered on
Hi!
Please check for the cables coming into the motherboard from the power supply. Also try and check for any loose cables.
If that doesn't help then please get your power supply changed as its faulty.
Please rate this solution.
Thanks
Rylee
Feb 11, 2009 | HP Compaq Presario SR1430NX (PS566AA) PC...
HP Compaq Presario SR1430NX (PS566AA) PC Desktop Logo
59 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
