Denon 2308 Have made optical and HDMI connections between TV and receiver but cannot get audio through receiver. Don't think optical connection is set up correctly
    Genius:
  • Audio Player... Master
  • 1,054 Answers
Check your tv's setup menu. Some tv's require you to turn on the optical audio output. It defaults to being turned off unless you go in and change it.
Posted on Apr 26, 2013
  • 319 Answers
SOURCE: hdmi or optical
There are no noticable differences between HDMI and optical except price. Although optical is less prone to EFM interference, HDMI can carry a wider bandwidth, depending on quality, but cost a lot especially long runs (10 ft or more). Also optical cables are not prone to connector tarnish which occurs even with gold pins of HDMI
Posted on May 07, 2008
  • 1894 Answers
SOURCE: Connecting a YAMAHA RX-V2700 receiver to my TV and cable box
why not you use a normal AV cable
instead of hdmi cable
Posted on May 22, 2008
marsrover
  • 682 Answers
SOURCE: Mac Mini and Denon 3801
http://www.retrevo.com/samples/Denon-Receiver-manuals.html
Posted on Aug 09, 2008
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
SOURCE: Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Posted on Dec 24, 2008
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
Apple tv to optical audio on avr 1601
You need to assign the optical input to the video input you are using. It's under the 'Input Setup' menu.
Or use HDMI, it will output the audio thru the HDMI connection. Once again assign the input under the Input Setup menu (press the Menu button on remote to access setup menus)
Nov 19, 2011 | Denon AVR-1601 Receiver
Trying to connect HP M9060N and Sharp Aquos through Denon AVR 1508, only get 'no signal' response. Have HDMI 1 set to DVD, HDMI 2 to AUX, HDMI 3 to TV, which is order of HDMI outlets on receiver.
Depending on your TV inputs, you are better off to run video componenets through TV first then, connect TV to reciever via digital optical. Recievers have video pass through but, noyt the best route. You can use TV's menu to choose what you watch and, only have the one output from TV to reciever. Make sure you scan through TV and reciever menus to make sure you are selecting the right channel.
Jun 21, 2011 | Denon AVR-4306 Receiver
How do I get audio from my tv to my receiver through an hdmi cable? AVR 2807
Your tv needs to have an HDMI out. If it has just connect that to the Denon. Tv might not have HDMI out so connect an optical cable from the tv's optical out to the Denon's optical in.
Sep 29, 2010 | Denon AVR-2807 Receiver
Denon AVR 2308 ci. No sound when using TV (Niece changed setting
there should be a way to change a setting between.....analog, coaxial, optical 1 and optical 2..if everything is connected through rca jacks try analog
Nov 03, 2009 | Denon AVR-2308CI
Best way to hook up all my componets
The best way to use the Denon and get your money's worth is to connect all devices to the Denon using HDMI connects if possible, if you use HDMI make sure you assign the audio if needed.
HDMI from Denon to TV. the Denon will upconvert all signals to HDMI to the TV
Jan 29, 2009 | Denon AVR588 Receiver
We have a Denon AVR Surround Sound receiver, a Samsung HDTV, an XBox 360, an ASD-3W Denon Ipod Dock and Klipswitch speakers with a subwoofer, center channel and too bookshelf speakers. We need help...
HDMI input connect as follows:
1. Connect an HDMI cable from the Cable box to the TV/CBL HDMI input on the Denon.
2. Connect an HDMI cable from the Xbox to the DVD/HDP input on the Denon.
3. Connect an HDMI cable from the HDMI out-put on the Denon to an input on the Samsung.
You don’t have to use the optical output from these to devices since the HDMI cable allows for the transfer of both audio and video, if you have them extra use them in addition to the HDMI cable and last,
4. On front of denon after you setup and assign your optical connections, if you use them, once you select TV/CBL or DVD/HDP as a source, press the input mode button to select auto
Jan 08, 2009 | Denon AVR588 Receiver
How to Hook up HDMI from Comcast Motarola Cable Box
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
Connection help with receiver and lcd TV
depend on what you wants to do. if you wan to get sound from your tv on receiver connect out from tv to in on receiver if U have optical out from tv send this to optical input on your receiver and set up your receiver to impute to digital HDMI carrie sound and video...
(My Denon receiver set-up shows an HDMI cable going from the Video Out on the TV to the HDMI MONITOR OUT on the receiver)
OUT TO OUT don't make sense ...could be out to impute you may have HDMI going from receiver to TV and other HDMI imputs on receiver to use receiver as distribution unit say you have satellite HDMI, DVD HDMI, Computers HDMI IMPUTE all of this connected to your Receiver and the HDMI monitor out from your receiver connected to TV so now you may select any of this sources to wach In your TV and lessen trough receiver speakers
Apr 10, 2008 | Sony BRAVIA KDL-40V3000 Television
 Grubhead
Grubhead
