Reset minolta DI 470
How to solve preventive maintenance time M5?
5 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: MInolta Di 183
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Thanks.
Posted on Mar 25, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Just purchased an old minolta EP4050. Says
Easy one....press stop, then 0, then stop, then 1
so stop,zero,stop,one
You will now be in the service mode so be careful.
Look for the counters tab and press it
You should see a screen with multiple tabs. You are concerned with 2 of them.
First one is "Maintenance" Press this tab.
You will get a list of maintenance items with their preset values and the "count" or pages run on them. Look for any where the count is higher than the setting. If there is one where this is the case then use the arrow key to highlight that counter and clear it to zero with the C key. Be sure you are in the counter column not where the preset is. After you have zeroed any that are over the preset, exit out and turn the machine off then on again. See if M4 is gone. If it is great.
If not then repeat this procedure again but this time instead go to the Consumables tab instead of Maintenance and check the 2 counters in there. One is copy kit and the other waste toner collect. Clear them if they are over the preset. If the waste toner is over and you clear it you should empty the waste toner box or it could back up and damage the machine. The waste toner box is located inside of the plastic "box" on the back lower part of the copier. 2 screws remove the cover and the box just slides out. Be careful not to make a huge mess when emptying the box.
Good Luck
Posted on Dec 23, 2009
Testimonial: "You are an absolute genius. This copier has been sitting here for over 5 months with no one able to fix it!! Thanks & Merry Christmas."
  • 1297 Answers
SOURCE: minolta dialta Di 470 donne code c 0210 puis
C210,transfer/separation corona malfunction.Change or clean the corona wire and the corona holders(white Assembly).
Posted on Jan 23, 2012
  • 1297 Answers
SOURCE: when i turn the photocopier minolta di 470 on the table displays normally after a moment the photocopier turns off and displays the code c1334 i would like to now the meaning of the code.
C - 1334 Duplex take up print command error.
A duplex take up print command is not received for the paper to be taken up from the duplex after the papers has moved past the horizontal transport but before it reaches the transport roller.
The number of duplex take up print commands falls short of the number of sheets of paper to be taken up from the duplex or the leading edge of the sheet of paper,for wich a duplex take up print command is yet to be received activates the transport roller sensor.
Clean the transport feed rollers and the sensors.Reset the error code using the trouble reset switch and open/close the front door.
Posted on Apr 09, 2013
How to remove on screen preventive maintenance time m5
there is no M5 preventive maintenance only M2 and M3 please conform
May 10, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
Code c-0400 on minolta dialta di 470
open the front door, upper left small access cover remove the cover and press trouble reset. if code comes back replace the scanner lamp and associated circuit board.
Try this site for a start for parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
May 03, 2014 | Konica Minolta Office Equipment & Supplies
I have a photo copier machine minolta dialta di 470 that show error code c-0400
open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
Error code c0400 on minolta Dialta Di470
As I said before, Open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
Displat code C10A5 in minolta di470
Press the Trouble reset switch on the tech.rep.setting switches board to reset a malfunctions,or open and close the front door and turn OFF the copier wait 1 minute and turn ON.2_5_2013_6_54_09_pm.jpg2_5_2013_6_54_24_pm.jpg2_5_2013_6_54_38_pm.jpg
Feb 05, 2013 | Konica Minolta Office Equipment & Supplies
Firmware on to minolta di470
Step 1:
C-10XX Memory board failure.Enter in the service mode and reset the trouble.2_6_2013_6_19_30_pm.jpg2_6_2013_6_19_42_pm.jpg
Step 2:
If you can t reset you have remove the right upper cover and the memory board metal cover to located a memory board reset microswitch.2_6_2013_6_27_55_pm.jpg2_6_2013_6_28_08_pm.jpg
I have Minolta DI 470 copier , and when i print from my computer it displays " error printer 1808" , i can't found any solution till now. Can anyone help me to solve this issue.
An 18xx code that can't be reset is caused by a problem with the image processing board. Most likely it will have to be replaced.
I'd call for service on this one.
Mar 06, 2011 | Konica Minolta Minolta DI1811P Digital...
Minolta dialta Di 470 donne code c 0210 puis
Jan 10, 2010 | Minolta Office Equipment & Supplies
CODE MALFUNTIOS C1441 MINOLTA DI 470
C1441
1. Reset the malfunction.
2. Check that the Original Glass is properly installed.
3. Check for extraneous light and check to see if the CCD Assy and mirrors are
installed at the correct positions.
4. If the same malfunction is detected again, change Image Processing Board.
Jul 11, 2009 | Minolta Office Equipment & Supplies
M5 on DI 620 !
tenes que entrar en: stop key,0,0,stop key,0,1. entras en Counter y luego en PM. Resetear PC Drum 1, PC Drum 2, PC Drum 3 y borras el M5
Jul 10, 2008 | Minolta DiALTA Di520 Laser Printer
46 people viewed this question
k24674
jasbo
jasbo
