Question about Toshiba Satellite A205-S5831 Notebook
Added new water dispenser paddle, now no water and ice auger runs contimually!
Frigidaire PLHS69EESSN side by side aprox 5 yrs old Plastic water dispenser paddle snapped off. I replaced with new one after looking at a step by step video. I was sure to first unplug fridge and was careful to discharge any static electricity first just in case. I installed the paddle without any problem. When I put it back together, I plugged the ribbon back into the control board and slid down the two white locking slides for a straight and secure ribbon connection. BUT I was not 100% sure what way the control board side of the ribbon was suppose to face!!! When I plugged the fridge back in, nothing happened. i.e. No button lights lit, no water, no ice, no changes at all. Because it was apparently facing the white plastic coated part of the ribbon connector, I figure no harm- no foul. So I next unplugged fridge and turned the ribbon over to the other side and plugged it back into the dispenser control board (the board that attaches the buttons). When I plugged fridge back in, most of the control lights lit up this time BUT THE ICE MAKER AUGER IS SPINNING with the freezer door closed, and would not stop unless I opened the freezer door! Also, the water dispenser would NOT activate....so no water. Also, the lights for the water and for the ice dispensers would stay on no matter what I did. The fridge otherwise would still make ice and cool normally. If I un-attach the ribbon from either board, the auger stops spinning and the dispenser lights go off. After a lot of online reading I found others that had same problem after replacing the water paddle. Most would fix by replacing the ribbon. Others would fix by replacing the control board. One person said he had to replace the power board to fix. I replaced the ribbon as most had done, but it did not help. I decided to get a repair tech with 30 years exp look at it. He said it was the first time he has seen this problem. He called the manufacturer troubleshoot phone number. He explained everything over the phone and they told him to replace the ribbon, AND the power board, AND the control board!. Now my DIY water paddle replacement will probably be another $400 or $500! (He will give me a price in a day or two). I already paid $80 for the paddle and $10 for the ribbon, and $89 service charge to diagnose. The tech took out the entire water/ice part and did not see anything hung-up etc. He also tested the micro switch and said it was fine My question.... I know that elec parts can not be returned if the attempted install does not work, but do you think it is necessary to replace BOTH boards and ribbon? This is turning into a big expense, and could really get out of hand.... and what if replacing ALL parts still does not fix it! Is there any way to safely just replace ONE board without risking blowing out the other board that it is connected to? Any ideas on how I should proceed without having to mortgage the house to fix this cheap plastic paddle fiasco? Thanks.
  • Toshiba Master
  • 7,627 Answers
You will have better luck if you posted to the correct category.
Posted on Apr 26, 2013
  • 120 Answers
SOURCE: Toshiba M35X S161 Ribbon Connector
You can buy another one cheap at a computer retailer, maybe. Search eBay too. There are various good things available there.
Posted on Nov 30, 2008
dragon_sun25
  • 107 Answers
SOURCE: Power light blinking
That is because either you screen is dead(test by connecting a exteral monitor) or you motherboard is dead and I have been seeing many dead motherboards as of late
Posted on Dec 09, 2008
  • 70 Answers
SOURCE: Toshiba A105 keeps Restarting ---
maybe the power input is error
the uncorrect power input will result bad
or, it's your mobo broken
Posted on Jan 25, 2009
  • 2976 Answers
SOURCE: Nothing on powerup.
Open it up again and find the wire you blew off.
Posted on Oct 25, 2009
SOURCE: Toshiba Satellite P25-S5093 screen/boot problem
Insert your Windows XP DVD in the drive, start up the PC. After it loads up and asks if you want to install or repair, hit 'R' for repair. This will kick you into the C: prompt. Type chkdsk /r for repair. It should take about 30 minutes. I have repaired about 10 computers with this in the last 6 months. (usually after a blue-screen error) It may be due to the BIOS needing a new update. Check for that at your PC Manufacturer's "Downloads & Updates" section. and follow the BIOS update procedure.
Posted on Jul 15, 2010
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
Ice Maker Dispenser Motor Won't Stop Running
There is a plastic part in the dispenser that holds the micro switch that operates the auger motor when you push the paddle. If you're handy with hand tools, you can order the part and replace it yourself. The part is on the outside of the door.
Jun 15, 2017 | Kenmore Refrigerators
Water dispenser dripping
The seat in the door valve has probably failed or has some trash in it.
Jan 20, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer wont dispense cubes, only crushed ice
I had this same problem for a few days. I opened the door & played with the ice dispenser hole and it ended up working again
Dec 19, 2008 | Frigidaire FSC23F7D Side by Side...
Ice dispenser circuit board removal
Does auger motor get power when paddle is depressed? Must hold in door switch to check. Front panel screws in at bottom; remove drip tray. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Frigidaire FSC23F7D Side by Side...
GE GSS25LGM Ice maker not dispensing ice
You have one of three things wrong. The auger motor is frozen up, the ice bucket is broken or you need to dump out any ice, run warm water through the entire ice bucket, dry it out and try again with fresh cubes. My guess is the auger motor is frozen. You can buy a vinyl boot that covers the auger motor to prevent moisture buildup and freezing from GE Parts at 1-800-626-2002
Nov 21, 2008 | GE GSS25LGM Side by Side Refrigerator
Auger runs constantly
check to see if the micro switch is stuck in the closed position spray a little wd 40 on it if it is and work it out and in to free it no i don't think you have a rely problem the auger moter cant run unless the microswitch is activated by the paddle let me know or stuck
Oct 20, 2007 | Frigidaire FRS3R5EMB Side by Side...
Ice Dispenser not working on PSS26SGPA Stainless Side by Side
This is a common problem with this GE and "lookalike" models. The dispensers first break the front plastic drum that holds to the auger and eventually cracks the rear circular sleeve as well. Pieces from the drum usually fall off and are even dispensed with ice ... eventually the drum is damaged enough that the auger no longer operates. The motors on these units, however, continue to operate.
You can receive the replacement parts needed to make the ice maker auger operate again by visiting the GE parts website. A usual repair will run $40-60. Unfortunately, the design of the replacement drum has not changed, so be prepared for this to happen again.
Best of Luck.
Apr 24, 2007 | GE Profile PSW26P Stainless Steel Side by...
Water and Ice does not work. Ice dispenser does not even turn.
There is a motor that turns the auger for ice at the door but it has nothing to do with the water at the door. If you are sure the water line at the door isn't frozen then I'd suspect the control board isn't working (no power to the motor or the water solenoid valve). These diagrams may help you see what's inside so you can look deeper into the issue. If you can, try turning the ice auger by hand (dump all the ice out first). Also check that melted ice didn't re-freeze and bind up the auger, etc. If you can leave the fridge off a day with the freezer door open that would melt any frozen water line, just to be sure that's not the problem. http://www.partselect.com/Schematics/Frigidaire/6VV40M4Y.gif http://www.partselect.com/Schematics/Frigidaire/P3WRBSB1.gif
Jan 14, 2007 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Toshiba Satellite A205-S5831 Notebook Logo
164 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
