Error 045 motor not follow
After start machine not run. just show message is 045 motor not follow
2 Suggested Answers
sodeep
  • 3267 Answers
SOURCE: My Canon IRC 3170 N
e014 due to fixing motor not turning (fixing roller faulty_need to replace)
Posted on May 30, 2011
E5 show in my screen keep on beeping
Look in you manual under messages it is some type of error message
Sep 21, 2015 | Singer 6180 Brilliance Sewing Machine
Run time error
Go to the following webpage and download the program, run the program and it should repair your runtime error problem
Bud
http://download.cnet.com/Smart-Runtime-Error-Fixer-Pro/3000-18512_4-75965634.html
Oct 09, 2013 | A4tech Xmaster Computers & Internet
My Powerfirst T960 stopped twice while running. Display stays on (no error message) but backlight turns off. Also, was speeding up/slowing down while running
1)LUBE THE DECK BELT, this problem is by lack of maintenance schedule, maybe you have deck belt worn. This produce enough friction between deck vs deck belt and shut down the machine for protect the electonic system.
2) Lube the rollers bearing in according with the maintenance schedule.
3) Test the voltage input motor, if there are the motor need repair.
4) Test the output voltage board, for the input voltage motor, if there are NOT the board si faulty.
5) RUN the software calibration for diagnose, troubleshooting and fix it.
see my person TIPS for help.
sincerely. God bless you
Apr 18, 2012 | Exercise & Fitness
My washer is showing dE message what is this mean?
The machine identifies and indicates some operational errors through a series of beeps.As you are using LG WM2455 Front load Washer it is showing error message The error message "DE" This error signal beep during drain.Unhook/clean drain pipe and press the 'Start/Pause' button to continue cycle.Thanks for your question.
Jun 17, 2011 | LG WM2455 Front Load Washer
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
Nov 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Samsung washing machine shows error "LE"
This is usually a communication error, unplug the machine for 20 minutes and then see if it returns when power is restored.
but if this does not helps then the actual reason of LE error code is as follows:--
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The hall sensor is out of order/defective.
The hall sensor seems to be part of the motor.
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jun 14, 2009 | Samsung WF203ANW Front Load Washer
Fisher & Paykel DS605 starts cycle, stops, beeps, shows U3 error.
U3 means the tub filled to quickly or the water failed to drain. Do you have very high water pressure? are you using the wrong detergent? eg you can't use tablets (powerballs) etc in the unit. Try putting half a cup of white vinegar in the tub to kill any foam. Check there isn't anything stuck under the motor rotor inside the tub and the there's no signs of damage. Put the drain hose in a bucket and see if the water drains ok when the unit starts? If everything seems ok I'd suspect the main motor controller module but it may be worth getting an appliance tech to inspect unit first as it's hard without seeing this unit. feel free to ask any questions. Cheers
Apr 12, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
