Question about Optoma HD65 DLP Projector
Optoma 65hd display menu empty
Hi, since few days, when I'm going into the menu Image or display, the standard list of setup (contrast, brightness, ...) doesn't appear any more. When trying to change these setup with the remote control, nothing change. Did some know to reset all the setup, I try to do it on the Option menu but it didn't solve my problem Many thanks for your support, Chris.
  • 25 Answers
Which input are you using? Some models will disable certain controls when using the HDMI or DVI inputs. Just to troubleshoot, try switching to a different input (composite video, s-video, or component) and see if the controls re-appear.
Posted on May 01, 2013
2 Suggested Answers
  • 11800 Answers
SOURCE: Optoma 65HD image just stopped
I'm starting with the assumption that you have tried different sources of signal and different cables, with the same result.
Simple test: try to bring the menu on the screen. If you can then the AV inputs aren't operational, replacing the board that carries them will cost around $150 with labor. If nothing appears on the screen then the image processor is inoperative and the entire mainboard will have to be replaced. This would cost over $350 and it's simply not worth it - for a little more money you can buy a brand new one.
Posted on Nov 14, 2010
I want to do a channel auto scan how do I do this?
This will be in the onscreen menu accessed from your remote. In the setup menu you will find sub menus. Most likely it is in something titled video or initial setup.
Jul 26, 2014 | LG 32LK310 LCD HDTV, 32 Display Size, 16:9...
Viera th-42pz82 setup
There is service menu option to adjust the white balance. But is is a semi skilled work. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. You must have knowledge in electronics to follow.
Apr 29, 2013 | Televison & Video
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
The projector is showing the image upside down and back to front. How do I remedy?
Hello
Check the Projection Setting on the Setup Menu of the OSD.
The projector has an OSD that lets you make image adjustments and change settings.
On the setup menu, select "Projecion"
Use " > " or " < " key to select from four projection positions.
For more details, go to page number [33] of its user manual. If you haven't the user manual with you now, send your email address to me by FixYa comment box. I've the downlaoded user manual to your projector. I can't send it to you by this window as this window does not allow me to upload PDF files by it. If you send your Emai ID, I'll send a copy of the user manual to you by return mail. OK.
Nov 28, 2011 | Optoma EP7155 DLP Projector
Hellow. I bought a Lake PC to TV video converter. I pluged to my laptop and TV and no special problem, but the contrast and bright of the image in my TV is very bad. I pushed buttons to open the menu...
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes hope this helps
May 30, 2011 | Audiovox Lake PC to TV Converter Box...
Optoma EP757 displays green image when input connected. Initial splash screen displays fine. All colours are the way it should be but as soon as a video source is connected, it displays the image in...
I would suggest replacing the type of cable you are using. Changing the type of connection, such as S-Video or VGA or something other than what you are using, may resolve this issue as well. Because the splash screen comes up normal, this tells us that the issues lies not with the device but with whatever it is you are connecting it to. Comment back if this does not resolve the issue and we can move further.
Good Luck,
NOLA Tech
Jan 27, 2010 | Optoma EP757 DLP Projector
Brightness/Contrast Adjustment
try going to the setup screen button left of adjustments
try going to the set up menu on the left of the buttons come down to the slider control just above the information icon then go across to color reset hope this helps regards Jim
Mar 12, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Optoma HD65 DLP Projector Logo
69 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
