Question about Microsoft Computers & Internet
My Keyboard Is Not Working
OLD KEYBOARD REPLACED, NEW ONE SAME - WHAT NEXT PLS?
    Scholar:
  • 156 Answers
Please specify the PC model and operating system installed.
Posted on Apr 26, 2013
The Machine
  • 788 Answers
SOURCE: keyboard key not working
If it is just one letter then you most likely have a bad keyboard.
Try an external keyboard, if the 'c' is still not working with the external then it's probably some weird software issue. But, if the 'c' is ok on the external you will probably have to replace the keyboard. Replacement keyboard are pretty easy to find on ebay or the web and are usually very easy to replace.
Posted on Jan 14, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Asus a6000 keyboard
Keyboards are most generally held by screws in one of two places. 1- On the bottom, could be marked with a K, With bottom screws, the keyboard may have tabs on it holding it, you will need to pry the tabs gently out away from the plastics. 2- towards the top of the keyboard under the power button strip. Try this link, you may be able to find a breakdown diagram for your machine there.
http://repair4laptop.org/notebook.html
Don't be afraid to remove all the screws on the bottom of the machine if you're unsure as to which are for the keyboard, it won't hurt anything as long as you get them all back in. If they're marked with a B, it's a motherboard screw, and P is for plastic casing.
Posted on Jun 30, 2008
playaway
  • 18 Answers
SOURCE: Missing Keys on the the keyboard, want to replace the whole keyboard.
If you are handy with a screw driver and take your time, you should have no problems replacing your keyboard.
Tools Required: A small Phillips and a small flat-blade screwdriver are required replace the keyboard.
Gateway has excellent documentation on how to replace your damaged keyboard.
The User Guide you require is 8511418 - Component Replacement Manual http://support.gateway.com/s/Mobile/Q106/Blade/8511418.pdf
Detailed instructions can be found on pages 7 and 8 of the User Guide. If you have any qeustions please ask.
Good Luck!
Posted on Aug 11, 2008
  • 3 Answers
SOURCE: coke spilled on to the keyboard for my laptop.
Hi
The keyboard has to be taken to service centre, As the coke becomes gummy substance after dried up and the whole keyboard membrane track has to be cleand with isopropyl alcohol and the keyboard controller strip cable leads and connectors has to be cleaned with isopropyl alcohol or with any component leads cleaning solution
Posted on Mar 18, 2009
  • 1542 Answers
SOURCE: Acer Aspire one KAV60, keyboard
Hi
Have you tried to download new drivers for it at all
http://www.acersupport.com/
Posted on Nov 13, 2010
Amilo li2727 keyboard not working
i think you can try to connect an external keyboard to one of the USB ports
Apr 23, 2014 | Fujitsu AMILO Li 2727 Notebook
I have a Dell Logitech wireless keyboard that has recently quit working although the mouse is working fine. I have replaced the batteries to no avail. what is the next step?j
If you've replaced the batteries and it still isn't working, your last hope is to see if the keyboard has a reset or connect button on it. Press this (and the one on the dongle if there is one) and it should reset the connection. If not, you're going to need to buy a new keyboard i'm afraid, as this one is kaput.
Thanks
Moza805
Aug 31, 2011 | Logitech Deluxe Keyboard
The shift keys and ctrl keys on my nc6230 laptop have stopped working. Any solutions?
Clear temp files and reboot
If you're using Skype turn off keyboard shortcuts
Make sure sticky keys are turned off
Keyboard cable/keyboard may need to be replaced
Nov 23, 2010 | HP Compaq nc6230 Notebook
I have my HP PAVILION DV4-1106ee...My lapt0p had problem with keyboard...The keys A,S,D,F,J,K,L,:,' and even my ENTER and right CTRL doesn't work...How can i fix this without replacing new keyboard...Its...
heating is normal. better to keep in a hard bord so that hot air can flow easily.
without replacing the keyboard it is difficult to repair. but u can try by removing the keey & cleaning. if its not working the u need to open the keyboard, which is risky. because any thing wrong need to replace the key board. so better to take it to a service centre.
Aug 13, 2010 | HP Pavilion dv4-1120us Notebook
Keyboard problems
Is the keyboard flexible cable the same pin as the original keyboard? If yes and you are sure the new keyboard is okay, then you can change the language to the preferred language e.g US English, change its position to the first and make it referred. Its should work. You can also check online if there is any keyboard or input driver which when installed can be of help.
Apr 12, 2017 | HP OmniBook Vt6200 Notebook
Compaq kb-0133 keyboard problem ''\'' key not working
If that is the case try some different keyboard.... on the PC i am sure that it will work fine.... and if it does that means the the old keyboard is bad.... kindly get is replaced
Jul 23, 2009 | HP Computers & Internet
Keyboard and mouse ps2 usb not working
hi, only advice I have is to try different keyboard, the most basic keyboard you can find - looks like the OS is not picking up the drivers for your input devices - usually if you have an old keyboard it seems to work!
Regards,
Mar 13, 2009 | Computers & Internet
English language support on laptop with German Keyboard
The easiest solution will be to locate a replacement laptop keyboard for that model. they arent hard to replace and usually cost between $40 and $80. I would web search HP Spare parts Third party is usually cheaper. Keyboards are pretty common replacements on laptops due to wear an tear. Most are replaced using a small phillips screwdriver. Its likley you can find removal instructions on the web as well (if they dont come packaged with the keyboard.
Dec 24, 2008 | HP OmniBook Vt6200 Notebook
Mikomi wireless keyboard
You must in
  1. right click on my computer
  2. click on properties
  3. click on hardware
  4. click on device manager
  5. click on keyboards
  6. click on(+)
  7. then right click mouse
  8. click on update driver
  9. select second option in window(advanced)
  10. then click on( search removable.......)
  11. then insert driver cd in cd rom
  12. And click on Next option
If you have done this then do this
  1. if it is not work then do above procss and select third option(Don't search.I will...............)
  2. And click Next option
  3. click Next option in next window.Thats it
Hope this be of initial help/idea. Pls post back as requested, how things turned up or
should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 15, 2008 | Gateway 2520915 Keyboard
Computers & Internet Logo
20 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
