Question about Cooper Wiring Devices 1301-7LTWBOX LIGHTED GROUNDING QUIET TOGGLE SWITCH
How do i wire a multi voltage light with a 220v supply and a 220 volt photo cell
  • Cooper Wirin... Master
  • 5,245 Answers
2 Suggested Answers
  • 5245 Answers
SOURCE: how do you connect a photo cell to a 220v HID fixture?
You can connect photo eye white wire to ground wire, and it will work, since each hot wire in 240V circuit carries 110V to ground.
But this installation is not code.
It is not necessarily dangerous if you are only person working on electric circuits, and you remember what you did, and don't work inside main box without turning off power.
See illustrations.
http://waterheatertimer.org/How-to-install-and-troubleshoot-photo-eye.html
Running a White neutral wire from nearby outlet is best solution.
Or buy 240Volt photo eye.
Posted on Oct 13, 2012
What do i have to do to plug my 110 air conditioner into where my 220 window unit
You need a step down transformer, to convert 220V to 110V. You can't just plug the 110V A/C unit in directly unless it is clearly marked as being suitable for multi-voltage supply (110V - 220V input).
Such a transformer has to be of sufficient capacity to handle the current, or wattage, that will be required. The Frigidaire unit in your question is a 3.5 kW cooling capacity, so the transformer would need to be about the same, ie for a 10A supply at least. They are quite big boxes, about $120.
http://welectronics.com/TRANSFORMERS/step-up-down.JPG
You would put this in the roof or in a cupboard.
Apr 25, 2015 | Frigidaire FAC126P1 wall/window Air...
How to test the electrical system of the generator for free
Ez test to determine if stator wiring is ok. This test works on generators that have two sets of 115v plugs and 220v plug. Use a 12v, 1amp ac power supply ( smaller ac power supply should work ok ). With generator not running, apply 12v to one of the 115v outlet plugs. Now verify 12v output voltage with meter at another 115v outlet on generator. Also verify that there is about twice the voltage at the 220 v outlet plug (should be about 20v - 24v) . If the adjoining 115 v outlet plug has no output or very little voltage or if the 220 volt plug has no output, most likely stator is damaged or breaker is off. If the stator is shorted voltage reading will be very low and power supply will heat up. If stator is open, there will be no voltage at second 115v plug or 220 v plug. If voltage is ok at the other outlet plugs as per test above then most likely problem is with voltage regulator, or brushes not making contact or armature winding open or just needs to be energized. Unplug the 12v power supply after test to prevent it from overheating. Most generators have two 115v windings that together power the 220v plug. When you energize one of the windings with the 12v power supply, the second 115v winding will be energized also and give you a voltage reading about equal to 12v. You will not damage the generator with this small voltage being input thru the plug. Good luck
Oct 14, 2014 | Electrical Supplies
Wiring diagram for aosmith a48a93a66 motor
Label will show wiring diagram.
Usually: L1 Line 1 will be 120V Hot
L2 Line 2 is Neutral
Low voltage is 115 volts
High voltage is 220 volts
Motor shipped new with 220V default
Compare existing wiring to what appears on label.
Label will show wire colors Brown, yellow, red, white etc.
Move these wires as needed to change voltage.
Take photo of label, post on internet, add comment with link to photo so diagram can be viewed.
Nov 08, 2012 | Pool & Spa
Plugged 110v dishwasher into 220v
When you have a 220v outlet there are two wires that both supply 110volts, thus the 220volt rating. 110volts uses 1 wire that supply's 110 volts and the other wire is a "neutral" what is a non current carrying conductor. In other words there is no 110 volts on the second wire. Most of the time if you supply a 110 volt appliance with 220 volts you most definately fry something if not everything. Probably the main thing that blew was the control panel be it a computer board, dial switch etc. Sorry for the bad news but it might be cheaper to replace the unit than having it looked at and repaired
Feb 05, 2012 | Whirlpool Dishwashers
Washing machine w/ 110v plug in to 220v
DON'T!
Never plug a 110 volt anything into a 220 volt supply and never plug a 220 volt anything into a 110 volt supply. They are just not designed to do so. Their electronic's power supply and their motors are specifically for the specific voltages. Changing the plug at the end does absolutely nothing.
I just hope I have got to you in time!!!
John C
retired Englishman in SW France
Feb 19, 2011 | LG Washing Machines
A friend from US gave me hp netbook-1103135- is it 110 or 220v please advise thanks
It most likely has a 110V plug on the power supply; however, all you have to do is buy the appropriate 220v cable for the power supply for your country, and it should work fine on 220V.
External power supplies are designed to use either 110v or 220v -- all you have to do is change the cable or use an adapter and you're good to go.
Dec 20, 2010 | HP Computers & Internet
How to reinstall heating elements. not sure about the wiring.
The electrical specifications are based on 220 volts. It should be noted that higher voltage will increase power, just as lower voltage will have the reverse effect. The (POWER MODE CONTROL) can be adjusted to compensate allowing the user to increase or decrease water temperature. For best performance adjust temperature at MEDIUM FLOW (approximately 1 GPM) this is the average water flow at any faucet with an aerator.
Remember, that any adjustments made on your unit will take seconds to reach point of use. DO NOT OVER HEAT WATER. Water temperature from 105F to 120F is adequate for all practical purposes
MODELS Model Max KW at 220V Volts Max Amps at 220V N-120 11.8KW 220V 54 N-100 10.8KW 220V 49 N-85 8.5KW 220V 38 N-75 7.5KW 220V 34 N-64 6.4KW 220V 29 N-42 4.2KW 220V 19 N-10 3.2KW 110V 29*
Nov 13, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Will it be okay to connect a 110 volt laptop to a 220 volt LCD projector?
What voltage is your mains supply?
The laptop's adapter should be a multi-voltage type 110 to 240 volts input.
If your mains is 110 volts AC then the 220 volt AC LCD projector won't work unless you connect it to a step up transformer (110 to 220 volt transformer).
If your mains supply is 220 or 240 volts then both the laptop and the LCD projector will work without any problems.
Aug 24, 2010 | Computers & Internet
Will a Canon Pixma MP 160 printer work in europe running 220 volt
Have a look on the markings on the adaptor. There it will be mentioned ---input voltage ---- 115V or 220V
If both 115 and 220 are mentioned it will automatically handle voltage differences.
Please make sure to avoid burning.
Dec 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Cooper Wiring Devices 1301-7LTWBOX LIGHTED GROUNDING QUIET TOGGLE SWITCH Logo
62 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
ken skalski
Jim Y
Jim Y
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
