Question about Dell Computers & Internet
9 pin smps - Dell Computers & Internet
    Brigadier General:
  • Dell Master
  • 3,400 Answers
No keyboard, no display, doesnt sound like computer boot ups
firs remove the cover and remove the 24 pin conected to the motherboard from the smps you will also see another 4pin conector conected to your motherboard from the smps remove them to then short the pin green and bleck in the 24 pin connector and see wether the smps fan is working if working coneect the 24 pin to the motherboard leave the 4 pin aside and switch on the computer if the processor fan is working switch of the computer and connect the four pin conector to the motherboard and switch on the computer if the processor fan is not working then you have problem with the motherboard
Jan 29, 2011 | HP Computers & Internet
Tip
How to check the SMPS in Desktop Computer while the system is Dead Condition
1.Remove the all power jacks from Motherboard before check the SMPS. 2.after removing the SMPS then follow the below steps
i) Short the Green and Black wires with a small conductor(wire) in 20 pins jack of SMPS ii)Now plug the main wire into SMPS
iii) On the SMPS Now see the SMPS fan whether it is running or not if the fan will be run then the SMPS has no Problem else SMPS will be Problem. 3.Change the New SMPS with same ratting of Watts
on Apr 17, 2010 | Computers & Internet
My computer want come on with the power the light is on on the back of the tower but it will not come on when i push the power button
you need to check the SMPS first remove the 24 pin conectior to the motherboard from the smps and short the green and black pin if the SMPS fan is working there is no problem in the SMPS conect tthe 24 pin conector to the motherboard then remove the 4pin conector from the motherboard from the smps and switch on the computer of the computer fan is working you have froblem with *********** board
Jan 17, 2011 | HP 1GHz Compaq/ Desktop Computer (RB1GPKG)
Seams like fan not working
if the fan is not working first you have to test the smps remove the smps connector from the motherboard and short the green and black pin it he smps fan is working then the smps is fine coneect the smps connector to the motherbord and switch on the computer still not working then remove the four pin connector from the smps and restart your computer if irts working the problem is in your motherboar
Dec 30, 2010 | Dell (6F858) Cooling Fan
Is that any specified smps to be used for mother board
Depends on the age of the motherboard.
To clarify;
When Switched-Mode Power Supply's were first made for personal computers, for the main power cable they used two of them.
This was the AT power supply.
http://www.playtool.com/pages/psuconnectors/connectors.html#oldpc
The next version of the SMPS used a single main power cable, the ATX power supply.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
As personal computers increased in Processor power, and graphics power, it was found that more power to the motherboard was needed. The ATX main power cable was increased from 20-pin to 24-pin, to handle the extra load,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
A lot of motherboards also receive extra power through a 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
This power cable is used for power to the Processor.
Power Supply's (SMPS) have increased in power over the years to keep up with the demand for power.
They have also increased the number, and type of power cables used.
Some now have an extra 6-pin PCI Express power cable for added power to a graphics card, or two 6-pin PCI Express power cables.
Some SMPS's have an 8-pin PCI Express power cable for added power to a graphics card.
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8
If an SMPS has an 8-pin EPS +12 Volt power cable, it is used for added power to the motherboard, for the Processor.
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
If your concern is how much power can your motherboard handle, know this;
A computer ONLY uses the power it needs, and NO more.
If you had a 10,000 Watt power supply, and the computer only needs 100 Watts, the computer only uses 100 Watts. (10,000 Watts is an exaggeration)
Do you know the motherboard's name, and Model Number?
State in a Comment, and I should be able to tell you what power cables it needs, and give examples of an SMPS that will work.
SMPS,
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Nov 06, 2010 | Computers & Internet
My Smps is ok, when i switched on smps fan and processor fan not on
Check Following Instruction:
1. If your SMPS ok, Check 20 pins cable connect properly to the motherboard, or Fan 4 pin connect to the motherboard.
2. And Start your Motherboard. It will OK.
Apr 13, 2010 | Intel Motherboard
How to use ATX-250-12z SMPS with 24 pin
Chances are that 250w power supply is not going to power a motherboard with a 24 pin connector, but you can try.
You will need to purchase a 20 to 24 pin adapter cable.
Google Search Terms: 20 to 24 pin adapter
Oct 27, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Dell smps ps-5141-2d pin layout
145 watt smps was shipped in very very old computers, its not manufactured any more. how ever you may still want to try for best buy. 1% chance you may get it. i searched everywhere its images are not avilable. the pin layout inside and outside is the same. as in 180 or 200 watt smps. repairing is not a good option. get it replaced if its okay with you. please tell me the system model number or service tag so i can look for alternative smps for your computer. thanks.
Oct 10, 2009 | Dell Computers & Internet
Psu
Hmmm.... mainly you have:
-20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
-4 or 8-pins connector that powers CPU
-the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
If you totaly unshure, there is manual:
Illustrated How to Replace an ATX Power Supply
Sep 05, 2009 | Computers & Internet
No power
1. Please check with the power supply of pc from a/c plug. 2. if power supply is ok then ensure that the input poewer cord is at right position in behind of cpu. 3. If you are using old type power supply (which do not autumatically turned off by operating system) then there is problem with power switch or SMPS. 4. If you are using advance power management (generally used in now-a days computers which is automatically turned off by O.S., then there may be a problem with power pin that is connecting thae mother board and power button. Shut down your computer and open the cpu chasis and tighten the pin and ensure that it is properly inserted (the location of the pin is near hard disk lid pin, power lid pin). 5. If this pin is ok then check with pconnecting wire of pin and power button and also the power button. 6.Then turn the computer on. If it does not work then check the power connectors from SMPS to mother board are properly installed and inserted. 7. If power connector is ok then there is posssiblity of problem with your SMPS (power supply) of computer. 8.Generally due to heavy load of power and long usage the condensers of smps get mailfunctioned. Take the smps or computer to a local hardware expert.
Aug 25, 2007 | Compaq dc7100 Small Form Factor (PJ361UA)...
Computers & Internet Logo
23 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
