Question about Sony SA-W10 Subwoofer
Sony sa w10 subwoofer
Fuse burnt out (1800mAL250V), what can i replace it with, i have different fuses, 0.75A250V and 15A250V. will they work?
SOURCE: SONY SA-WM500 SUBWOOFER
firt you clean the subwoofer with cleaner after that, check the subwoofer srrounding, no electrical wire ,mobile phone & electrical operated items is near ur subwoofer.
1. Do not use maximum volume of subwoofer.
2. Use only 65-85% volume of your sub woofer.
Posted on Sep 25, 2008
SOURCE: No Power Sony Sub Model SA-WM500
I fixwd it by NOT subscurbsing to your Show
Posted on Jul 09, 2009
SOURCE: Power, but no sound
take an ohm meter and remove wires from speaker...put meter in the ohms position...you will put a lead on each of the terminals of the speaker...you should have a reading of 2, 4, 8 ohms....you may also try to use the continuity test, same, but there will be a beep ....this basically ensures that the coil running through the speaker is still good, as one piece, otherwise it will get no good reading and this is usually from blowing the speaker or sudden high bass sounds....
Posted on Aug 09, 2009
  • 336 Answers
SOURCE: Unit blew the internal fuse. SONY SA-WMS367 SUB-WOOFER
Bad output IC or voltage rectifier are the most likely at fault.
Posted on Nov 29, 2009
SOURCE: my sony sa-wx700 has blown the 6.3 amp fuse on the
i can't open yahoo mail in box
Posted on Dec 27, 2009
The fuse blows in the SA-WM500 whenever there is an input from the amplifier.
http://www.retrevo.com/support/Sony-SA-WM500-Subwoofers-manual/id/752ag404/t/2/
The fuse blowing is a symptom of something seriously shorted internally. What preceded the initial problem? Smoke is bad. Fire would be soon to follow without the fuse blowing. Take it to a tech.
Jan 17, 2011 | Sony SA-WM500 Subwoofer
My Subwoofer Sony SA_WM500 was always burn the fuse therefore I had to change the STK, but now it takes off sound very low, How can I have back the high sound level? Zaruque Quimuenhe
It's no clear what you mean by "I had to change the STK", but if that means you have somehow defeated the fusing or place a larger fuse than it requires then STOP and shut it off. You might be risking a fire or more serious damage to the amp.
I would recommend you find a hands-on tech to look at it.
If you have resolved the fuse problem and now just have low subwoofer volume, you might want to track it back to the source and ITS subwoofer volume setting. There IS a volume level control on the sub, too. Turn it up.
The manual is here:
Jan 11, 2011 | Sony SA-WM500 Subwoofer
Nov 28, 2009 | Sony SA-WX700 Subwoofer
Sony SA WX 700 - Fuse (6.3 A 125V) keeps burning out
The switching power supply transistors have shorted out. Other parts may be gone also. A difficult fix. Too bad, it's a great sub.
Sep 13, 2009 | Sony SA-WX700 Subwoofer
Just quit. no seem to be burnt .does not work. no sound. fuses good. similar problem it seems like that posted jan. 15,2009
Please check +12 volts at Q809 emitter pin and -12 volts at Q810 emitter pin on power board. Also check collector voltages on both transistors and let me know to move further.
Jun 04, 2009 | Sony SA-WX700 Subwoofer
I don't have no power replaced the fuse still no power
i have a sony subwoofer with no power. i found out that the voltage regulator (ic's)are bad. check that.
Dec 07, 2008 | Sony SA-WM40 Subwoofer
No sound
Hi, I've had this problem with the M-VR400 and apparently I had the Tape2 Monitor button pushed on, and I was trying to listen to Video-1. Well, mentally I said I have nothing connected to Tape2 Monitor so I figured the machine couldn't decide on sound Input properly, so I turned off that button and my Surround Sound came back on just like Magic! :) Hope that helps.
Sep 23, 2007 | Mitsubishi M-VR700
52 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
