Question about Rcf ART310A 10 Active Reference Speaker ART 310 A
Rcf 300 schematic - Rcf ART310A 10 Active Reference Speaker ART 310 A
Protect indicator is always on and motor boating sound
The amplifier is unable to achieve DC balance. This will require servicing. Could be a bad capcitor in the power supply.
Sep 04, 2011 | Rcf ART310A 10 Active Reference Speaker...
Hi i have recently purchased an rcf hc3200 and 4 x event 4000 speakers, these were all dommenstrated and shown to be working fine however when i connect 1 speaker to the amp (either channel) the sound...
Bass cancellation can occur if the polarity of one cable is reversed? Positive at the amp MUST go to the positive at the speakerS else one speaker will be pushing & the other pulling & the low frequencies get cancelled. You may also hear some strange imaging effects as you walk around the room - a bit like stereo from a mono setup.... check your cables :-)
Mar 23, 2017 | Rcf Hc 3200 Rcf Hc3200
The Limit Prot LED on my RCF Art-321A speaker remains on upon power up. The speaker also pops upon powering down. What do you think it could be? Thanks
The amp is blown. Some popping on power down is NOT uncommon, but the protect LED means the pwer amp is out of balance which is ******* speakers. Take in for repair.
Aug 05, 2011 | ART 315-a Rcf Art 315a 2-way Proaudiostar
I just bought an 800RB (been WANTING one for DECADES, finally put "cash-on-hand" together with "the SWEET one came along"). I want to know if the speaker jacks for the 300-watt amp are...
Here is the schematic AND everything you need to know about the speakers:
http://elektrotanya.com/gallien-krueger_800rb_sm.pdf/download.html
Scroll down to "Get Manual" on the site and click on it to download. It appears that the MINIMUM impedance on the trebel upper set is 8 ohms and MINIMU on the woofer is 4 ohms at the jack in each case.
Apr 26, 2011 | GallienKrueger Gallien Krueger 800rb
Need the part nmber for a rcf art 315 woofer 15"
The part number can probably be obtained from RCF directely as the speaker may be specially made for them. The specs are:
15" high power woofer, 64mm edge wound aluminium coil
email them to request part number at:
e-mail: rcf-usa@comcast.net
Apr 13, 2011 | ART 315-a Rcf Art 315a 2-way Proaudiostar
Where can i get a behringer b2031a schematic
i found legit looking schematics here...the pdf includes many revisions, adding to their credibility...haven't put them to the test...
http://www.electronica-pt.com/index.php/component/option,com_remository/Itemid,34/func,startdown/id,16026/
Feb 14, 2011 | Behringer B3031A 2-Way Active Studio...
Does anybody have a schematic for the Behringer LPA1300 power amp section used in the K3000FX keyboard combo? Are the output devices supposed to be the ground path for the power amp. (there are no...
Look at this one:
http://elektrotanya.com/behringer_k1800fx_sch.pdf/download.html
This is for the 1800 however...
Often they will just double up with two amps, one inverted, and use in bridged mode.at the higher power in what we call an "H" arrangement.
Since the drains are tied together, the heatsinks MIGHT be hot output level.
Feb 05, 2011 | Behringer Ultratone K3000fx 300w Keyboard...
Marshall md hdfx100 vol. cut
a bad solder weld on a reverb pot can cut the volume.. you need to check the solder welds on all the pots and jacks. then move on to the grounding resistors, they look like sugar cubes, and are usually 300-500 ohm 3-5watt. those usually have cold solder welds and need to be resoldered. you can email me thru my website yostamplifier.com if you need further assistance. from there i will look into the schematics and help you fix your amp....via email.
Jul 04, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Crate PA6FX
if they are square cement power resistors they are probably 3-5 watt 300-500 ohm .... are there colored stripes on the resistors? those are probably grounding resistors, they usually are installed too close to the board, get real hot a bunch of times and then crack the solder welds. when you replace them bring up the height and make space under the resistor to keep it off of the board and put a little drop of silcone underneath to hold them in place.
Mar 29, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Rcf ART310A 10 Active Reference Speaker ART 310 A Logo
73 people viewed this question
Top Rcf Music Experts
Vito Vacirca Jr.
Are you a Rcf Music Expert? Answer questions, earn points and help others
