Question about Boating
Fires up but won't keep running
Fires up ok but will only run for a second or two. Put the boat to bed last fall, treated the fuel, fogged each cylinder with fogging oil. Went to start this spring with this result. Tested fuel pressure at test port and have 20 psi which meets spec. Plugs are new, gapped correctly, they are getting wet with fuel. Crank position indicator is correctly gapped. No check engine light showing, all fuses are good. Fuel pump runs for the spec 10 seconds and turns off unless cranked. Fuel filters replaced, gas fresh. So far no change. Any ideas?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,190 Answers
Prime fuel up after the filter !!
Posted on Jul 08, 2014
daves944
  • 1050 Answers
SOURCE: Buick Regal dying
You have a problem in the fuel pump relay circuit for sure then. I'm betting the relay, but it could be that dropping resistor.
Posted on May 11, 2009
alicantecoli
  • 22156 Answers
SOURCE: 1980 VW rabbit, manual/fuel injection: I am
it starts from cold because the auto choke is on ,allowing a richer mixture ,try removing the sender unit in the tank and seeing if the connection from the pump to the outlet connection is ok or leaking causing a loss of fuel pressure
Posted on Aug 02, 2009
SOURCE: 1994 XJ6 hard start problem
Check Air Flow meter/Sensor
Posted on Aug 14, 2009
  • 6982 Answers
SOURCE: 93 wrangler 2.5 will crank but won't start. I pour
Yes...check the pump, filter and output. Also check the ballast resistor for the pump. Stop pouring fuel into the cylinder...instead, use carb cleaner and spray into throttle body (excess fuel in one cyl will contaminate your engine oil). If it runs normally after you get it started likely the pump is good (unless you have problems at high rpm's under power) Regulator is likely good as well...default is to more fuel not less.
Posted on Oct 07, 2009
ZJLimited
  • 17970 Answers
SOURCE: 2001 ford e250 5.4 v8...vehicle
Are you try scanned the PCM to know if some fault codes are stored there? Are you check injectors? We recommend to de-pressurize your fuel system. Disconnect the power to your fuel pump, by either disconnecting it's power supply, or pulling the fuel pump fuse or relay. Once the fuel pump has no power, crank the engine for a few seconds. The engine might start, but should die a few seconds later. If it continues to idle, then you didn't disconnect your fuel pump.
Once the fuel system is de-pressurized, we can begin to remove various parts from the engine bay to help clear up room. On a typical system, there is a fuel feed, and fuel return. For these types of systems, you would need to disconnect both of the lines, and then disconnect the fuel pressure regulator. The fuel injectors are held in with clips that hold the harness to the injector. Remove these clips, and pop off the wiring harnesses. The fuel rail is held in with a few bolts. Remove these bolts, and then the fuel rail should be loose. Pull the fuel rail out of the intake manifold or cylinder head, and you can now easily remove the fuel injectors.
Couldn't start his but had 40 psi fuel pressure, but even though it turned over. Are you check crankshaft, this is located crank sensor under the a/c compressor, to the left of the balancer. The camshaft sensor is in the timing cover usually behing the PS (Power Steering) fluid tank. FInally, try jumping or bypassing the fuel pump relay to test if have pressure, if this work, then go to the next device, fuel filter, then next at fuel pressure regulator and this way so on.
Keep us updated.
Posted on Feb 09, 2011
Westwood t1200 - sparks on pulling cord but engine doesn't start . Was serviced last summer and parked . Fuel +. New carb and plug Ideas please
For an internal combustion engine to run, it needs fuel, air, spark and compression. Since it ran last year it is safe to assume you have good compression. Also, you can assume it has air if it was professionally serviced last fall and was running ok when you put it away.. You have spark so that leaves fuel. The first thing to check is fuel supply. If there is a fuel shutoff valve on the fuel tank or the fuel line leading to the carburetor check to see if it is ON. If the tank has gas and the valve is open or non-existent, then remove the air cleaner and spray a quick shot of starting fluid into the carburetor with the choke open and try starting it again. If it fires but quits, it is a fuel delivery problem. Primary suspect is a plugged main jet in the carburetor from sitting over the winter with oxygenated fuel in it. That is the same type of fuel you put in your car. It oxidizes metals. The jet can get restricted from oxidation (like rust). If that is the case the carb needs to be cleaned professionally. Use non-oxidized fuel in the future and run the engine dry for storage. Keep no more thn a months worth of gas on hand. Hope that helps.
Mar 12, 2016 | Garden
2007 flhtc won't idle
Hi Anonymous, try a fuel stabilizer. Good luck.
Apr 23, 2013 | Harley Davidson FLHTCUI Electra Glide...
We have a '03 Pontiac Grand Am GT, 3.4L (3400).
If the resistor bypass doesn't solve it, another remedy could be a plug-in type engine block heater- I mean plug into household current. It keeps the engine coolant warm in the block. Every other car here in Montana uses one-works great for those below zero nights. When the wife pulls into work, just run an extension line and keep the car plugged in till time to go. Other than that, IDK, sounds like you've covered it pretty well as far as solutions.
Nov 05, 2012 | Cars & Trucks
1994 evinrude boat motor keeps blowing fuse. motor keeps running but once shut off won't restart. also while motor is running the tilt won't work work
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Jun 27, 2012 | Cars & Trucks
97 chevy blazer w/ 4.3 won't start unless i pour full directly into it....what is causing this. was driving and it just stalled ...fires but won't turn over completely
if you can put fuel in throttle body and it runs. then it is not getting any fuel. check your fuel pump fuse and the relay, if ok, then you may have a bad fuel pump or a plugged up fuel filter. check filter and fuses first. good-day !!
Jul 18, 2011 | 1997 Chevrolet Blazer
I have an 01 1200 XLH. Road hard and "put away wet last fall", no winterization. As penance I have removed and cleaned tank, carb, etc. I appera to be geting gas and the bike fires fine but...
Hi Lighthouseju, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below and good luck:
Harley Davidson Sportster error codes and how to access them
May 23, 2011 | 2000 Harley Davidson XL 1200 C Sportster...
Last year I purchased a Troy Bilt snow blower . I used it one time after using it I drained the gas out of it. Just recently I got it out and was checking it out because they were talking about snow so it...
Cecil,
I am curious why this repair was not covered under the warranty? This snow blower has a 2 year warranty from the manufacture.
Two things for you.
First, there has always been the "what came first, the chicken or the egg" issue over leaving fuel or draining the fuel from you snow blower. Half the experts say drain it, and the other half say leave it in.
Secondly, all of the current Cub Cadet, Craftsman, Troy-Bilt, Yard Machine, and Yardman snow blowers with the Powermore engine need to be treated differently than the old Techumseh or Briggs side-valve that you were used to.
The issue with your Powermore engine is actually today's ethanol fuel. If you leave the ethanol blends in your tank without a fuel stabilizer the alcohol separates from the gas. This alcohol then rises to the top of the tank and gets into the fuel lines. The fuel lines actually will soften. (I've seen the primer bulb actually melt on a few units)
If you drain the tank and run it dry the remaining fuel will "varnish" and/or dry out the carb.
I know a service manager that repairs a lot of these Powermore motors. Instead of replacing the carb, his techs actually take the carb off, soak it overnight in carb cleaner and then reinstall it. This is so common that he keeps a few clean carbs on the shelf and then just switches them out when a customer has a problem.
So how do you keep from getting those high repair bills? First, use fuel stabilizer ALL THE TIME! Mix Sta-Bil, Sea Foam, or Craftsman Fuel Stabilizer according to the directions on the bottle. Secondly, try not to use ethanol blended fuel. Especially try to fill the tank the last time you use it in the spring with non blended fuel. Third, When you put your snowblower away, fill it with stabilized fuel, start the motor and run it until warm. Then "fog" the carb with SeaFoam spray until it loads up and quits running. Put it away for the season. (If you don't know how to fog go to SeaFoam's website and read about doing this with the spray)
It will start next fall.
Feel free to ask me any other questions about your snow blower. Don't forget to rate this answer and you are welcome to leave a comment about it.
Jan 11, 2011 | Garden
Need diagram of a force 150hp outboard motor
To winterize a Force outboard you should start the engine and remove the fuel line. Remove the air box and while the engine is running rev up the engine a bit and spray the fogging oil into the throat of each carberator when the engine is about to run out of fuel. keep spraying the fogging oil until you see thick smoke coming from the exhaust area. The exhaust comes out of the center of the prop. When you see the blue smoke then keep spraying and let off the throttle and choke the engine so it dies. Stabilize or get rid of your fuel in the fuel tank and you can let it sit like that for the winter. Leave the outboard in the down position so that any water will drain by gravity out of the prop. When you want to use it next spring just hook up fresh fuel, squeeze the fuel bulb and fire the engine up. It will smoke for a few seconds until that fogging oil burns out of there but it will be ready to run.
Oct 10, 2009 | Boating
Boating Logo
56 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
