Question about Biostar G31-M7 TE Motherboard
After 4 sec power off
When start system after 1 min power off automatically and also i am getting display so what should i do?
    Brigadier General:
  • Biostar Master
  • 3,400 Answers
Remove all electric cords ,and put them back firmly and tight.
for the videocard make sure the cabel is seated tight
Posted on Apr 26, 2013
AFTER SETTING TIME COOK TO 1 MIN 60 SEC AND PUSHING START BUTTON 4O SECS MORE IS ADDED, I.E. TOTAL 2 MINS SHOW ON DISPLAY. CAN I RESET THE THE COMPUTER.
There are sixty seconds in a minute, so 1 min 60 sec is the same as 2 min. If you want 40 seconds less than 2 minutes then set it for 1 min 20 sec or for 80 sec.
Oct 03, 2013 | Danby DMW139 Microwave Oven
We have a model 8110 saltwater pump. When we started the pump this year we could not get into the programming mode. We pressed the left button for 2 secs and nothing happened. We unplugged the unit for...
It will not work until you program hrs from 01 to 12. After you power the unit, press the left button for 2 seconds or so until you hear the beap. At this point, the display should blink 00. Now, single press the right button, do not hold the button down more than a second or two. each press will increase the time up... If you are doing this, it should work, if not call 1-800-234-6839 for further assistance..
Jul 22, 2011 | Intex Automatic Salt Water System for ...
HP Pavillon dv62030ez No more start up. Fan and lights get power for a second, then nothing. Think thr BGA doesn't fit any more, due to overheating.
Hi
This may be a problem with the bios. Try to reset the bios. follow the below procedure
1. remove the main battery
2. remove any USB cables etc., if connected
3. hold the power button for 15 secs.
4. reconnect the power adapter (Do not install the battery yet)
Later if the system starts well then shut down the Laptop and install back the battery and connect the charger and start the Laptop again
If the above will not solve the problem then follow the next step
1. Remove the power adapter and the battery
2. Open the back side cover where the Memory is installed.
3. remove the BIOS battery
4. leave the laptop for a while may be 10 mins.
5. Now connect the BIOS battery back
6. System will automatically start do not press the power button
7. set the date and time
8. Shut down the Laptop
9. Start normally back on.
DO RATE MY SOLUTION
Saleem
Jun 30, 2011 | HP Pavilion dv6000z Notebook
Can't set the clock on a 1987 Quasar Superwave convection Microwave MQ8777BW
I had a similar problem--no manual--but found this way to set the clock:
1) Be sure colon is flashing (unplug and replug)
2) Press the 10 HOUR/MIN, 1 MIN, 10 SEC/MIN, and 1 SEC/MIN buttons until the correct time displays.
3) Press the CLOCK button.
Hope this helps.
Mar 24, 2010 | Microwave Ovens
LCD NOT APPEAR
Bios does one long and two short beeps
This is the code for Video Failure.
Replace the Vid Card.
Sep 04, 2009 | Computers & Internet
WHEN I START THE CAR, IT WILL SHUT DOWN
YOUR ANTI THEFT SYSTEM HAS BEEN TRIPPED ...U CAN CALL DEALER AND GET CODE FOR FREE...SOMETIMES ITS TURN KEY ON FOR 1 MIN THENAGAIN FOR 3 AND SO ON ..BUT THEY WILL KNOW CORRECT CODE
Jul 15, 2009 | 1999 GMC Yukon
First 10 minutes it is working fine. After 10 mins it is getting stopped and started automatically for every 2-3 seconds.
sir i'm sorry to say you have air in your system. the trouble is at the orfis,seperating high side to low side. water molecul freezes then melts. very comon in ref. system. either pump down the system or isolate ga and add a filter dryer for that size unit
May 03, 2009 | Heating & Cooling
Computer won't turn on
check your monitor connection and memory ram
Jan 06, 2009 | HP Compaq Presario SR1420nx...
Biostar G31-M7 TE Motherboard Logo
26 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
