Question about Pegasus 875-9296H Estates Shower Faucet Only, Heritage Bronze
Shower cartridge replacement
Replacing cartridge due to low water pressure. Now cant get new parts installed properly.
Low Water pressure from the unfiltered spout on the Pur wat?r filter rf-9999. Plenty of pressure in the line.
Check out the nozzle screen for clogging. And if that does not do it then the cartridge inside your faucet is not operating properly. And those cartridges can usually be replaced. If faucet is a Moen it has a lifetime warranty and all you do is call them and they send to your home a brand new replacement cartridge. Do U have a Moen?
Mar 04, 2016 | Plumbing
I just changed my under sink culligan D30 water filter and there is a leak when I pressed the pressure button. What should I do to resolve this problem?
Well the simplest answer is the gasket isn't seated properly. The standard approach is to remove the cartridge, check for any foreign material (dirt, sand, grit, etc.), rinse with clean water if necessary and reassemble.
Sometimes these cartridge units can be fiddly to get the seals to 'seat' properly so once you're sure that the parts are together nicely then you can use a bit of pressure to tighten them up. They usually need to be fairly tight.
Mar 05, 2015 | Culligan Under Sink Water Filter
The flow of cold water is extremely low after replacing the Symmons mixing valve?
You may have installed the cartridge incorrectly. That is reverse flow direction. Please check. Please provide model number of the mixer you have used. It might be on this site. http://www.symmons.com/Bathroom-Products/Product-Categories/Tub-Shower-Systems.aspx
Sep 12, 2014 | Dmm Symmons Temptrol pressure balancing...
New danze cartridge no water
Possible issue with pressure balancing cartidge, When you remove parts, turn off water, remove parts, slowly turn on water and see if brass valves lets water out. If yes pressure balancing cartridge or cartridge itself is defevtive.
May 18, 2014 | Danze Home
Low water pressure
The plumber who installed it originally may have installed it incorrectly.
Jan 22, 2014 | Home
945 Kitchen Bridge Faucet - Swivel Spout, 9-1/2" (no Han) Brand: Newport Brass NB945-26 Series: 900 The stem moves up and down slightly when I turn on/off the water pressure. It does not leak but...
There is a good chance that if you remove the handle there will be a retainer of some sort. The retainer's job is to keep the stem/cartridge from pushing out due to water pressure. It may be in the form of a nut or a clip. Be careful removing the handle because if the retainer is completely disengaged then the stem/cartridge may shoot up. Turn the hot and cold water off at the valves located under the sink and relieve the pressure by turning the faucet on. If it's a loose nut it will spin freely. Tighten it. If it is a clip you may need to play with the stem/cartridge to align it properly before the clip will move into place..
Jul 15, 2011 | Newport Brass Plumbing
Low water pressure
Remove the spray head and point the hose into the sink drain. Turn the faucet on. If you have good pressure, cal American Standard for a free replacement spray head.
If you still have low water pressure without the spray head, ask them for a new faucet cartridge.
After replacing the faucet cartridge, if you still have low water pressure you will need to ask for a new faucet, possibly free if yours is still under warranty.
Sep 07, 2010 | American Standard Kitchen Faucet 6310 020...
Low water pressure. New installation, replacement
The posi temp valve has a little system built inside to anti scald you when your taking a shower, they have little parts that move back and forth, they get easily clogged from sediment and minerals in the water and always get stirred up when the water is turned off and back on from doing work.
Mar 17, 2010 | Moen Posi-Temp Single HandleTub And Shower...
The moen began to leak over time now i cant turn the water for
Call moen and give them your model no. they will send you a new cartridge free of charge. if you can't wait local stores like lowes will have them. Turn off your main water shut off valve and take off handle, then with some pliers take off brass ring, the cartridge will pull out. First notice the notch it rests in and notice where the hot water adjustment disc is. Assemble the new one the same way, put some vasolene on orings and reassemble. hope this helps.
Jan 12, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Pegasus 875-9296H Estates Shower Faucet Only, Heritage Bronze Logo
51 people viewed this question
Top Pegasus Home Experts
Donni Steen
Tom Chichester
Are you a Pegasus Home Expert? Answer questions, earn points and help others
