Question about Stanton Audio Players & Recorders
Replace turntable belt - Stanton Audio Players & Recorders
    Champion:
  • Stanton Expert
  • 271 Answers
To replace a drive belt.
1, Remove the rubber platter mat to expose the platter.
2. Put your thumb and forefinger through the two round holes and lift the platter off. You may need to give the center spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter pulley and motor pulley with an alcohol swab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure t is sitting flat without any twists.
5. Flip platter over the right way up. There are1or 2 larger rectangle shaped cut outs in the platter.
6. Through the cut out pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
7. Align the center hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correct operation.
Job done.
Posted on May 06, 2013
Pioneer pl a45d
Hi Javier,
How to change the belt? how to replace belt on pioneer pl x300 pioneer pl x50 turntable .
A place to find the belt. Pioneer PL A45 PL A45D Realistic LAB 1500 TURNTABLE BELT T245
Manual with schematics. Sign up and free. Pioneer PL A45 Manual 2 Speed Belt Drive Turntable Vinyl Engine
How to set it up after you put the belt on.
How to set up Turntable cartridge alignment overhang VTA VTF vibration...
Another look on how to change a belt on a turntable? How to Replace Turntable Belt on Belt Drive Turntable
It is straight forward. Patience. Fare. Well.
May 16, 2014 | Pioneer Audio Players & Recorders
Turntable is slow, especially noticable on 33 1/3 rpm
hi,
your turn table is a belt driven one. The speed turns down when the belt become expanded. you should replace the belt of your turn table. Also put some lubricant in its center shaft ( not from the top lubricate it slightly after removing the plater).
I have here added some video related to the replacement of belt for turntables.
Not the exact for your one,for all the belt driven turntable the procedure is the same
ok
Jan 17, 2011 | Crosley CR248 Turntable
My sony pslx250h turnable belt was ordered and i can't find the repair book to repair it.
Pretty simple fix. Remove the mat, remove the turntable, install new belt on bottom of turntable hub. Place turntable back onto spindle. rotate turntable so you can see motor pulley. Stretch the belt from turntable hub over motor pulley, replace mat, enjoy.
Nov 08, 2010 | Sony PS-LX250H Turntable
REPLACING TURNTABLE BELT
as the belt sliped from the turntable you must replace it with new one.if upside down turntable you can see marking of belt on it.just put a new belt on turntable keep it on center.remove top rubber pad you will see three or one big hole on turntable from where you can see the belt turn that hole so you can see motor pully just hold belt by a screwdriver and pull it on motor pully.
Jun 21, 2010 | Audio Players & Recorders
Model PS-LX300USB Turntable Drive Belt
Hi Norman
Normally the belt does not go through any special tensioners or anything of that nature,The belt should go directly from the spindle motor onto the inside of the platter. Hook the belt on the motor section and lay the belt open wide inside the turntable. Next, replace the platter and manouvre the belt onto the platterinside through the two large holes
Mar 11, 2010 | Sony PS-LX300USB Turntable
How do I attach the turntable belt to the Aiwa px e850
Lift the platter off the turntable. You can identify the motor spindle by using your fingers to turn the round shaft which rotates freely. Remove the rubber mat off the platter. Place the belt around the outside of the drum on the bottom of the platter. From the top of the platter, place your finger in one of the platter holes and tension the belt so it will not fall off or twist. Griping the platter trough the holes while keeping tension on the belt place the platter on the turntable aligning your finger with the belt to the motor spindle. Place the section of the belt on your finger over the motor spindle. Replace the rubber mat on the platter.
Nov 05, 2009 | Aiwa PX-E860 Turntable
TURNTABLE SPEED TOO SLOW. IS THERE ANY WAY TO ADJUST IT.
The liely cause of the slow speed problem is the belt. Your turntable is belt driven, like components in your car's engine compartment. As the belt ages, it can begin to slip. Replacement of the belt will probably restore the speed once again. The PX-E860 turntable has been discontinued. There are parts, such as the belt, that are still available. How much longer these parts will be available for remains unknown. If you like the the turntable, you should consider purchasing several belts as the next time you need one, they may not be available or may cost much more.
One source for replacement belts (there may be many others, ie: eBay):
http://www.elexatelier.com/aiwa.htm
You might also need a manual to direct you as to how to go about changing the belt. The manual is a free (after registering) download below:
http://www.retrevo.com/support/Aiwa-PX-E860-Turntables-manual/id/1077bh126/t/2/
Oct 05, 2009 | Aiwa PX-E860 Turntable
Jvc turntable
hi, please check first your fuse inside your turntable, replace it if possible
Apr 04, 2009 | JVC AL A158BK Turntable
KM837 manual to fix belt on turntable
IF the belt fell off, it is likely that the belt is stretched and needs to be replaced. Use a couple of pencils to open up the belt and beasure the length. The belt should go around the two pencil erasures forming an oval. Use that measurement to determine the belt size and purchase a replacement belt. The belt will go around the platter and around the motor hub.
Dan
Feb 03, 2009 | Crosley CR248 Turntable
Belt replacement
http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all turntables including yours that will show how to install the belt an a few other things.
Nov 08, 2008 | Aiwa PX-E860 Turntable
237 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
