There is no setting to find. clean charger port with rubbing alcohol and a tooth brush, be gentle. turn off - let dry and recharge for 2 hrs. worked for me. pain I know. taking battery out will not help. but should check battery conections to see if they are clean,do the same as above. if purple you have water damage. verizon warranty is void if this is the case.
I just charged mine for a day and It worked fine after that.
I have an LG VX8300 and I had to take the back off and scrub with a brush and alcohol to get rid of the "Car Kit", but now my speaker only picks up sound if I blow into it which essentially makes it unusable, but a step closer to resolving the issue.
I put my cell phone on the charger and
within 5 min it was workin fine
The only reason this could happen is when your charging port or it could be around the port is wet My only recomendation since you can't open the phone is to use a tooth brush with some alcohol. wet the brush with alcohol and try to clean the charging port.if it did not work you might need to take the phone to some one who can replace the port.
This happened to me before, but it was because i dropped it in liquid....if that's the case take out your battery froa few days and let it and let your phone dry out...may be dirty between battery and connector..if so clean gently.
You have to change your Profile to General or Outdoor or any other setting except Car kit, there should be a Profile setting under your Menu button, you must remember to Activate the Profile you select Hope this helps Regards
Phone was sitting on kitchen counter and when I picked it up it was in car kit mode and I don't know how to get it out
suddenly my cell turned in kit car mode, I was not able to change it. I cleaned the charger part but nothing happened.
same exact problem here. phone has not been around water and goes in and out of car kit mode
intermittently goes into car kit mode.Then goes out again. Now it's mysteriously working again, will try the methods others have suggested if problem reappears.
