Question about Western Digital Caviar 40 GB Hard Drive
Western digital caviar ide drive jumper settings master
  • Western Digital Master
  • 10,137 Answers
The jumper settings are on the label or just above the jumpers on the end of the drive
Posted on Aug 16, 2017
Benimur
  • 6966 Answers
SOURCE: Formated Hard drive from Ebay
Apparently you have tried most if not all of the basic install procedures.
If and when you connected it as a secondary or slave to a working/booting PC, was it auto detected at the CMOS/BIOS stage? If yes, then perhaps it is a partitioning/formatiing issue, if not then chances are that it is a hardware problem and the drive is dead.
Alternately, you can try using an external SATA/IDE Interface to USB such as a VANTEC CB-ISATAU2 SATA/IDE to USB 2.0 Adapter or any comparable product. This would provide the SATA/IDE connections to your new hard drive as well as a USB cord to your PC's USB port.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Jan 14, 2008
  • 509 Answers
SOURCE: my western digital wd800bb caviar, has no label
Set the jumper like this for a secondary hard drive...
Posted on Jul 09, 2010
nonontech
  • 4737 Answers
SOURCE: I have a Western Digital
You can refer to this:
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Oct 27, 2010
SOURCE: jumper settings
check this official web of western digital...
http://www.wdc.com/en/products/legacy/Legacy.asp?Model=WD400EB
Posted on Feb 26, 2011
virtual_a
  • 531 Answers
SOURCE: what kind of master/slave used
Hi
The WD schematic diagrams here should tell you everything you need to know:
http://www.wdc.com/en/library/eide/2579-001037.pdf
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
This helps Answerers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Posted on Sep 06, 2011
How do you turn a hard drive from master to slave
To set a IDE Hard Drive as Slave you would need to change the jumpers/pins on the back of the drive
See this link Here
May 17, 2014 | Western Digital Caviar WD2500BB 250 GB...
What is the jumper setting for wd200bb 20gb hard drive for slave
Slave - Installing the new drive as the secondary drive:
If installing your new Western Digital hard drive as the secondary drive on the cable with
two IDE devices, move the jumper shunt on the drive to pins 3 and 4. If necessary,
configure the jumper on the other IDE device as Master.
May 04, 2011 | Western Digital Caviar WD200BB 20 GB Hard...
I have a gateway and am trying to replace my current hard drive with the Western Digital Caviar WD400BB 40 GB Hard drive . I currently have 2 maxtor drives in that are op as 1 partition. I hook it up but...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
Apr 01, 2011 | Western Digital Caviar WD400BB 40 GB Hard...
Hd western digital wd800jd - preciso do manual do hd. e tambem configurar jumpers. grato!
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
hope this helps
Dec 10, 2010 | Western Digital Caviar SE WD800JD SATA...
Need jumper settings for slave drive WD1600JS
slave :::':
hope this helps
Dec 10, 2010 | Western Digital Caviar SE WD1600JS...
Hi i have a western digital wd1600 160gb hard drive last year i used the hirens boot disc to completely wipe my hard drive and repartition the drive but now when i try to use my western digital tools for...
Have you tried setting the jumpers on the new drive to CS (cable select) If you use that setting, the position of the drive on the cable determines whether it is master or slave. For example, the plug at theend of the IDE cable is the master and the plug in the middle of the cable would be slave. Just a suggestion. If you are using SATA, this does not apply.
Jul 18, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
Is a 80gig western digital hard drive compatableto a asus p2p pentium 2 celeron motherboard if so what are the jumper settings for the hard drive and do i have to change my jumper settings on the mother...
hope u r a professional..
yes, itz compatible..
howevr, for all pata ide drives..remember the master(MA or MS) jumper is always in a vertical position along or just beside the ide cable port/pata port..while the slave is either 'open-all' or just beside..
there's no such jumper to b fixed on the main/mother board..
for details contact system admin/vendor....
Nov 10, 2009 | Western Digital Caviar (wd800lb) 80 GB...
Jumper setting
ok
check your ide connectin that blue end of ide cable always at motherbord .also check that your ide cable is working properly.
Jun 23, 2009 | Western Digital Caviar SE WD1600AAJS 160...
My XP PC won't recognize portable Western Digital hard drives
Not sure how to help without knowing what hardware you're using to read the drives.
But here are a couple of links from WD that may prove helpful...here and here.or here.
I'd look for something similar on the support site for your device.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 15, 2009 | Computers & Internet
Western Digital Caviar 40 GB Hard Drive Logo
869 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
