Question about Fujitsu LifeBook Computers & Internet
Fujitsu Lifebook B3020D harddrive not recognized on XP install
I got a new IDE harddrive for my Fujitsu Lifebook B3020D and I tried to install XP Pro on it, however, when I'm prompted to go ahead with the installation, I get a "HD no found" message. I know the HD is good, the software is legit. I already tried enabling/disabling the IDE option under device configuration in BIOS. That didn't work. Am I missing something like a driver maybe or a setting in BIOS?
sandrew
  • 2961 Answers
SOURCE: same problem in HP dv6040ca
Firstly, the system configuration is normally in management menu or similair on your programmes menu. If not you will find that the bios menu in most laptops are basic and normally the main settings are hidden; you will need to speak to HP Technical for assistance in that. There is no reason to not be able to upgrade to XP Pro; but with an upgrade you would need to keep your original XP Home installation, otherwise you will need to completely install XP Pro firsly using the format option when you insert the Windows disc. As with most laptops all programmes and drivers are usually on a seperate partition on your hardrive, so be aware you are going to lose all this when formatting, so back up all files and settings. You may also have restore discs, if this being the case all programmes and operating system will be on them, so no need to worry about losing anything from your hardrive apart from your documents. Why do you need to dissable SATA?
Posted on Nov 20, 2006
  • 63 Answers
SOURCE: M7NCD ULTRA raid drivers
If the SATA drive is operating in 3.0 Gbps mode and your motherboard can only support 1.5 Gbps mode, the drive will not be detected in BIOS or XP. Try jumpering the drive to SATA 1.5 Gbps mode. The label on your hard drive should indicate which pins should be shorted to achieve this setting; if not, look up your particular model on WD's website to find the manual.
Posted on Nov 19, 2007
  • 110 Answers
SOURCE: Bad Harddrive
Can you just clarify that you installed XP with the new IDE drive installed in the notebook and that you have selected disc 0 in the bios as IDE and that it is aslo set to boot from that drive?
What you are describing also fits the symptoms of installing XP on a SATA drive without installing SATA drivers first. (XP doesn't install SATA drivers, Vista does.)
So this does sound like a bios setting issue
Posted on Apr 11, 2008
SOURCE: USB not working on HP NX7010
I have the same problem. No sctive USB ports, yet device manager shows ok. updated system BIOS and Intel chipset from HP site - still no good. Also removed bluetooth unit, still no good.
Turned off USB power management, still no good!
The laptop was working perfectly until this happened.
Any more suggestions?
Posted on Sep 05, 2008
sodeep
  • 3267 Answers
SOURCE: New Harddrive, new install windows pro XP
Visit this link: http://support.asus.com/download/download.aspx?SLanguage=en-us
Select your OS & get access to all MB drivers.........sodeep
Posted on May 17, 2009
Notebook Lifebook E8110 - some keys sometimes dont work. Backspace, and keys around "mushroom" pointer like r,f,g,h// I tried in Word and Notepad and nothing, in Internet Explorer they work. Now...
Fujitsu America - Support - LIFEBOOK T734 Notebook PC
support.fujitsupc.com/CS/.../supportsearch.do?...Notebook%20PC
USB 3.0 devices not working as Super Speed when resuming from Standby ... Fujitsu LifeBook T734 Notebook PC; Softex OmniPass; Microsoft Windows 7; Microsoft ....When setting up external monitors on the VGA or DVI port do not change the .... Vista and XP Tablet PC act differently at this point; both need to make some ...
[PDF]E8110 spec - Fujitsu
Dec 26, 2015 | Fujitsu LifeBook E8110 Notebook
How to activate touchpad on fujitsu lifebook modela6025 a series
Go the Device Manager under Control Panel and make sure it is not disabled. Right click and select enable. If you see a yellow exclamation mark next to it means the driver has not been installed and you will have to download and install it.
Jul 17, 2014 | Fujitsu LifeBook A6025 Notebook
I want to completly remove Windows and repl,ace it with Win XP Pro
If you have a valid copy of xp pro, then just insert the disk and boot from it when asked. when you are asked about an install, choose a clean or new install and everything will be erased and you will start over. Be advised that you will need to get the lifebook drivers burned to a disk before you start.
Nov 23, 2012 | Fujitsu LifeBook AH530 NoteBook
Fujitsu n6410 reboots randomly
format and install fresh os. keep good antivirus with good firewall. use avast professional.
Aug 29, 2009 | Fujitsu LifeBook N6410 Notebook
Gateway 450ROG only recognizing 7805 MB of 60GB hard drive
you may have to wipe that harddrive clean and start over new
Dec 12, 2008 | Gateway 450ROG Notebook
Bad Harddrive
please check your cables and try with new one.check the bios setting
Apr 04, 2008 | HP Compaq Business Notebook NX9010
Computers & Internet Logo
21 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
