Question about Sharp 32L-S400 32" TV
Sharp tv My tv keeps switching to input two automatically. But if I have something plugged into the front RCA jacks it doesn't do it.
  • 3 Answers
U need to reprogram your eprom files are corrupted
Posted on Aug 07, 2007
SOURCE:
RCA jacks on back of flat panel sharp TV set, which are audio ouy
Most TVs have a red and white set of RCA connectors that are marked "OUTPUT" The back panel will also have the same type connectors for audio input.(can be very confusing) They are usually marked input.
In the case where there are no RCA connectors that are marked output then the only choice is to connect into the headset 2.5 mm plug. They make a plug to rca connector cable for this purpose.
Attached is a photo of a different TV only to help to give you an example of how they are usually set up.
Dec 21, 2015 | Sharp Televison & Video
My Ariana TV only shows the colours black and white
Might have video plugged into wrong plug. Nowadays, for RCA video, Green jack (which is usually for dvd player three color) is used also as conventional video output for old dvd players. They have an automatic switch to detect if you're plugging in old video (yellow) jack in. Picture will be in colour upon plugging into the right jack. No need to shut tv off, just plug in until you see color. Should be sharp & clear.
Jan 22, 2014 | Televison & Video
No plug ins work other than what is in jack 1 why?
Try using the "source" or "input" button on your tv or remote control. That will cycle through any ports that are being used (hdmi, component, rca, etc)
Hope this helps!
Mar 09, 2011 | Televison & Video
How do I listen to my Sharp LC-32L400M through my home theatre system?
Depending on the home theatre system and the tv. Your TV will have an audio out of some sort ie: Headphone jack, Digital Audio Out, Or something along those lines. And as far as the home theater system what kind of inputs do you have, Aux with a headphone jack, or digital audio in something along those lines. You have to be able to match them up. For example my TV has a headphone out, and my Surround has RCA cable input jacks for the AUX. I ran a headphone jack to 2 RCA white and red plugs. Once you have to correct connections made, you may have to adjust your tv volume mine is at about a quarter the way up, But make sure when you plug it all in that you select the correct input on your Theatre system. Hope this clears some issues up for you. Cheers
Feb 06, 2011 | Televison & Video
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
Hi, I bought an aquos lc-30hv4u and it has no rca jack etc, only two plug ins labled display input 1 and 2. I am guessing its just a pc monitor. How would I use it for cable tv video games etc
There are lots of inputs on the back behind the cover. Three inputs (1, 2, 3) have an S-video, composite video (A/V) and component video jacks. The cover will come off if you press the two top hook at the top of the cover. Then rotate the cover towards you. There are also a DVI-D port and 2 coax (antenna in) jack. The tuners included are for NTSC (analog OTA) and CATV (analog cable). The front of the PC (VGA) and a S-video or composite (A/V) video input (called Input 4).
Composite and component video jacks are all RCA jacks (as are the associated audio jacks for the input). Composite cables uses three RCA plugs on each end - yellow for video, red and white for Right and Left audio. Component video cables have three plugs on each end that just carry video (red, blue and green); the audio is wired separately with just 2 RCA red/white plugs. Match your colors from the device out to the TV input.
Changing inputs can be done with the remote or the input button on the top of the TV. The input button is to the left of the power and Main Power buttons.
Connecting your game system, cable system and all will depend on the units. For the best picture, use component video cables for mose set top box. Some cable boxes have a DVI port - use that if the box has that option. If they do not have component video out, then use composite or S-video cables.
The owner's manual is available from Sharp as a pdf: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx?downloadtype=ownersmanual . Use the drop down menus as follows > LCD TV, Model not listed, LC-30HV4U then click Search. The picture of the inputs are on page 10.
I hope this helps.
Dec 15, 2010 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Coaxial hookup broke off. Can i use an s cable through vcr? need instructions.
If your Sharp television has RCA jacks, you may use them through your VCR. Your VCR would have to have a tuner and then you may use this as a means for getting a signal. Newer VCRs and DVD players generally do not have a tuner. Thanks for asking!
Jul 22, 2010 | Sharp 27N-S300 TV
I HAVE A RCA TELEVISION, MODEL F20632. I CANNOT FIND THE MANUAL TO HELP ME SET UP MY VCR. I HAVE A 4-PLUG VIDEO CABLE (YELLOW, BLACK, GREEN AND RED). CAN YOU TELL ME WHICH CONNECTIONS ON THE TV I NEED TO...
the yellow rca input jack( not the output one ) is for video in (by itself ) and the red and white rca jack inputs are for the right and left audio that is also required when using the yellow video jack
the red and white audio jacks are also required when using the component video inputs ( BLUE , GREEN & RED ) rca jacks
but only one type of connection is required ( yellow video jack , red and white audio jacks ) or ( the blue , green and red component video jacks and the red and white audio jacks )
you will need the yellow video input and the red and white audio inputs
Jan 05, 2009 | RCA F20632SE 20" TV
Receiver to tv hook-up
Is this a Pioneer receiver? They have the prefix of VSX but I can not locate that model on Pioneers website. It could be because it is an older model and no service information is on the website for receivers older than about 5 years old.
To answer your question I need more information. Do you want to connect the video switching of the receiver to the TV or just want the sound of the TV to go to the receiver? I would also need to know what type of video devices you want to connect and what type of inputs and outputs your TV has.
Most TV's have at least a composite video input, that is the most common type. it is a yellow RCA jack on the back of the TV and will be listed as an "input". That is what would be connected to the video output jack (yellow RCA) of the receiver from the TV for video switching. Then you need video sources connected to the video inputs of the receiver to go to the TV. You also need to connect the audio RCA cables from the video devices to the receiver on the proper video inputs that you have connected. Each video input for composite or S-video has audio RCA jacks (red and white) inputs so you can hear the sound of your video device on the receiver.
If you only want to play the sound from your TV on the recevier, you can use the audio output RCA jacks on the TV and connect them to an audio input of the receiver. This is a very simple way of using the receiver for all the different devices connected to the TV without having to connect everything to the receiver and then always having to have the receiver on any time you watch TV. The audio RCA jacks are always the red and white jacks. you just need to make sure you are using the output jacks of the TV and they are connected to an input jack on the receiver. Then you must switch the receiver to what ever input you just connected the TV to, like the "Video 1" or "Video 2" or maybe "Aux" input.
I hope this helps, but you didn't give much information on how you wanted to connect them.
A good rating would be appreciated if you found this free information helpful.
Let me know if you need any more help,
Dave
Jul 06, 2008 | Audio Players & Recorders
Video Inputs for a Sharp TV Model 25EM50
video inputs is commonly located in the back or side of TV set for any standard TV set are RCA type round yellow is for picture jack,red jack is for sound,and white jack is also for sound second channel.
Jan 17, 2008 | Sharp 25R-S100 25" TV
Sharp 32L-S400 32" TV Logo
95 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
