Question about Husqvarna Garden
How to remove starter
Trying to remove my starter on my lawn mower it has a 21 hp twin els 656 I wanna know the easiest way to get it off
I need to know the same. Did you ever figure it out?
Posted on Jul 18, 2013
VanHuben
  • 5 Answers
SOURCE: Lawn Mower won't start
Its a thing of beauty to see problems solve themselves. It seems to me this trial and error approach is very taxing and could have been avoided if 1, your small engine repair guy/Craftsman/Sears had sold you the right parts from the start, or 2, you had bought the right part... from the start.
Posted on Oct 24, 2008
thabrain
  • 76 Answers
SOURCE: murray riding lawn mower
with switch off try crossing out the solenoid. take an old screwdriver and place it on the two metal contacts jetting out from the solenoid usually by the battery or close to the ignition. if strarter engages when this is donr replace solenoid. if not replace starter. hope this helps.
Posted on Oct 28, 2008
SOURCE: Need lawn mower manual
need manual for pb195h42lt
Posted on Apr 24, 2009
  • 73 Answers
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
Posted on May 28, 2009
bargainbin2
  • 123 Answers
SOURCE: 13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Posted on Aug 29, 2009
Hydro pump reserve blowing out fluid on Toro z- master
is this all after the parts where changed and while bleeding out the air put the system under vacuum
May 13, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
How do I remove the Starter off a 1999 Mastercraft 15.5Hp Ride-On Mower
remove the upper engine cover then the twp bolts that hold it to the side of the engine
Apr 14, 2012 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
The electric starter spinns but wont engage to turn 6-5 hp briggs and strattanengine on my huskvarna lawn mower
hi there
svseanachai
have you had the battery out ? if so did you refit the battery back in , with the proper connections to battery - reversed connections at battery makes starter spin but starter clutch wont engage - have seen this on b/s 16 hp vee twin
if this is ok check the starter clutch / helix and gear they may be faulty or stuck
have a look let me know
cheers hope it helps
pauly46
dont fprget the thumbs rating
Jun 02, 2011 | Husqvarna 675 hp 21" Honda Rear Bag Push...
I start twice (when I pull starter rope) then the rope won't go back can I know what happen
Your starter/recoil unit has malfunctioned. Disassembly/inspection down to the point where you can get the recoil off will be required. Remove the engine cover screws. The recoil unit may be part of the cover or may be under it. You will easily be able to access it. Replacement parts for your mower are readily available.
Apr 30, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
I have an older 21" self propelled mower with a push button starter and pull rope starter. Neither will start engine.I
Need more info on what happens when you try and use the electric start and the rope start- does the engine turn over at all with either one?
Aug 15, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I have a Craftsman 21 hp, 42" riding mower ~ 10 years old...when trying to start it, it just makes a loud metal noise like the gears are stripped. I'm going to try to remove the starter tonight...will I...
depends on the engine, briggs L-head opposed twins can be viewed by removing the sheet metal head cover near the starter, changing its starter is fun, as one of the bolts is under the flywheel, it can be changed without flywheel removal, with patience. Briggs Vanguard and Intek twins starters are easier to remove, the intek cowling has to be removed to see anything with starter in place but the starter can be removed with the cowling in place, the Vanguard has a few sheet metal covers that must be removed. If you've got a Kohler, starter removal is usually pretty straightforward, take the starter to a local repair shop for a comparison or test if you are unable to determine what's wrong. A decent shop will at least inspect it and show you what a known good starter drive looks like.
Jun 03, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Battery fully charged, but only 6-7 volts getting to the starter. will start if jumped
Starter solenoid may be faulty. That causes the voltage drop. Remove the starter assembly and have it checked.
Nov 01, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Riding mower will not start
Hi
Starter drive is stuck. Clean by spraying brake kleen on starter drive and blow drive with air. Might
have to remove starter to clean. Check for missing cogs on starter drive.
Mar 29, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
