Question about Kenwood VR-505 Receiver
How to connect a kenwood VR 505 AV receiver to an HDTV with cable box
5 Suggested Answers
bluenadas
  • 203 Answers
SOURCE: IR receiver on unit not working?
Sounds to me like the issue is the rx in the unit. It can be fixed with very little work if you can locate the part. Let me take a look and see if I can locate the part number for you. Although I have to say that Kenwwod can keep a tight lip on their parts lists.
Posted on Nov 22, 2007
It seems to be a general problem on Kenwood Receivers. Pls check this out http://www.moerk.org/kenwood/ or this http://resnet.uoregon.edu/~gurney_j/kenwoodrepair/
regards sgershoj
Posted on Jan 08, 2008
SOURCE: Kenwood VR-209 Receiver doesnt stay on
The power transformer is bad. Part # L07-2485-05 it costs about $ 85 bucks to replace it. It is the big one.
Posted on Jan 28, 2008
mlapres
  • 757 Answers
SOURCE: Got a Kenwood vr405 surround receiver, a Sanyo
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Posted on Jan 14, 2010
Testimonial: "Thank you for the insight. I may have figured this out on my own eventually but this definitely got me situated much much faster. "
Hooking up Kenwood VR505 to TCL Roku T.V. All I want is audio from the T.V. for Surround sound
Use an optical cable to connect them. Optical TV out to Kenwood optical in.
Oct 22, 2016 | Kenwood VR-505 Receiver
How do i connect the sub woofer for kenwood-505
I inherited a Kenwood SW 505 Sub woofer. I don't know if it works I plug it in but no lights.
Oct 07, 2012 | Kenwood VR-505 Receiver
How can i connect my kenwood vr-505 to my t.v only
I assume you mean you want TV-related sound to play through the Kenwood.
It's in the manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-VR-505-Receivers-manual/id/480ag214/t/2/
I personally would recommend minimum TV involvement in sound and minimum receiver involvement in video, but that's just me.
You might want to ponder why you would need audio from a TV in the first place if it originates elsewhere like a Cable Box. The fewer hops and interconnects a given signal takes on the way from the source to your ears, the better (and cheaper, too, as optical or HDMI cable is expensive). You COULD skip the TV entirely. Many don't even HAVE audio (monitors, for example). The receiver only NEEDS a basic composite video output to the TV so you can use the TV for setup and control. You COULD run vanilla stereo audio to the TV from the Cable Box for watching Oprah.
I run all of my best DIGITAL audio directly from the sources to my VSX and the best DIGITAL video directly from the sources to the TV.
Mar 25, 2011 | Kenwood VR-505 Receiver
How do i connect it to a the subwoffer sw 50 ht
on the back of your receiver is a subwoofer pre-out, connect one cable here, and connect the other end of this cable to your subwoofer - line level in. (depends on your subwoofer and receiver) but that's how mine is connected. yours will be similar.
Feb 10, 2010 | Kenwood VR-505 Receiver
Hello I am trying to hook up a dvd player to my kenwood vr 505 that has been in storage for a while. How do you hook up a HD tv and dvd. Does it go out from the receiver to the tv, and does the dvd go...
If you are using HDMI cables for HD then you will need to connect this from your dvd player to you tv. Then connect your dvd player to you amp using either fiberoptic cable or co-axil (orange) this will transfer your dolby digital signal. Then connect other stuff like video / freeview etc to the yellow red and white on amp, you may need a scart to phono cable. Then connect monitor out from you amp to the yellow on your tv .This way when you select the source on the amp the picture will change also. If you search the web for vr-505 manual there are some sites offering it.
Nov 27, 2009 | Kenwood VR-505 Receiver
Wiring for VR-505
This is like buying a car without the power steering pump, which specially designed proprietary part. I am not familiar with that particular model, but if it requires special wires, then you may have problems obtaining them and may need to go to the Manufacturer. You would not have accepted a car that had no power steering pump, just because the salesman recommended it. Fortunately we are talking about a manufacturer with integrity and I am almost sure that you will get your cables, as long as you can prove ownership. Did you ever examine the sockets on the receiver, which could be simple RCA jacks. Do that before you go to the manufacturer. Then you can go to Radio Schack after you look in your junk pile to see what kinds of wires you have in that special wire box. CONSTANTIN (arzconst)
Jun 20, 2009 | Kenwood VR-505 Receiver
regards sgershoj
Nov 06, 2007 | Kenwood VR-505 Receiver
Kenwood VR-505 Receiver Logo
48 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
