Question about Cosco High Back Booster 22-200 /22-207
Manuel I don't have a problem with the actual seat, but i have a problem putting it back together after taking it apart to wash it. Can you please help me to put back all the strack in place agin.
  • 48 Answers
SOURCE: can't put back together
Please look at this manual instructions to get a clear help. and dont forget your rating for me. Thanks.
Posted on Jan 25, 2008
  • 25 Answers
SOURCE: having trouble with straps in car seat
Bring the straps up through the holes on the bottom of the seat, one on each side. The metal plate on the end should pull in flat and snug against the plastic. Slide the buckle pieces back on, making sure they're facing the right direction to snap in. Slide the chest clip back onto both straps.
Place the ends of the straps through the slots you want the harness at (at or below the child's shoulders for rear-facing, at or above the shoulder's for forward facing), making sure that they don't twist. Pull them down low behind the seat.
The adjuster part of the strap has a kind of Y shaped metal plate - pull it up to meet the ends of your straps, making sure that it
doesn't twist, either.
There are loops at the end of the harness straps. Feed the curved part of the Y through the loop of the strap that's on the same side of the seat. Pull it all the way through, so that the fatter part on the ends of the metal plate are exposed and curve around a bit beyond the strap so that it doesn't slip back off. Do the same with the other side.
Now adjust the harness to fit your child. When it's tightened properly, you should not be able to pinch up any slack, lengthwise, at the hips or shoulders, and it should lie in a straight line down the front, with no drooping. Also adjust the chest clip - it should lie even with your child's armpits - not up in the neck, and not over the belly, where it can't do it's job properly. (It's job is to hold the straps over the center of the shoulders...if it's over the belly, they're likely to slip down off of the shoulders in an accident or sudden stop and also poses the danger of internal injuries.)
One other thing - car seat harnesses should never be submerged in water, as it can damage and weaken the webbing. They should only cleaned with a damp rag. If you put your harness in water when you washed the rest of the seat, I'd strongly recommend contacting Cosco (contact info here) to order a replacement harness.
Posted on Feb 19, 2009
SOURCE: cant put the car seat back together
took the straps off and can't put back together
Posted on Jul 25, 2009
SOURCE: I took the seat apart to wash and am not sure how
Look for the product number and manufacture date on the side or bottom of the carseat. The instructions then can be found on the Cosco website:
Good Luck!
Posted on Jan 08, 2010
  • 29 Answers
There is normally a splitter in the back, a metal piece with two hooks that is attachted to the adjustment strap. the sholder straps latch onto this. You can locate the appropriate manual here: The pages in the back normally discuss reassembly after cleaning.
Posted on Mar 20, 2010
  • 45 Answers
SOURCE: Cosco Touriva Carseats
The manufacturer's instructions are the final authority - don't trust anyone else giving you instructions! Here are the links to download Cosco carseat instructions:
Posted on Mar 25, 2010
0 characters
1 Points
I took my car seat apart to wash it and I don't know how to put it back together
We would advise you contact the manufacturer of the carseat as the likelihood is that the unit will need to be sent to specialist engineers to inspect and put back together correctly. Due to safety implications of the harness being incorrectly fitted it may not be possible to do this yourself.
Dec 19, 2012 | Baby & Toddler Car Seats
Putting car-seat back together
This is not a UK model so we're unable to help.
Please contact for assistance.
Nov 23, 2011 | Safety 1st 22456 MIL Convertible Car Seat
I took carseat apart how do I put it back together?
go on your products website type in make and model and an instruction manual will be available to read or download
Sep 12, 2009 | Eddie Bauer 31447 Booster Car Seat - Sage
May 31, 2009 | Cosco Touriva 22-100
Need instructions to put harness in carseat back together
my mom has an eddie bauer carseat for my daughter and washed it how do you put it back together
May 24, 2009 | Eddie Bauer Baby & Toddler Car Seats
Harness straps off cosco car seat to wash cover, help reattaching
I need help putting the straps back on a Cosco 5-point car seat. Took it apart to wash and can't get it back together
Mar 08, 2009 | Century Encore 5-point Harness
Putting the car seat back together
also try this official manual:
Nov 17, 2008 | Evenflo Triumph 5 Comfort Touch
I need help putting straps back on car seat
May 15, 2007 | Cosco Touriva 22-100
Cosco High Back Booster 22-200 /22-207 Logo
29 people viewed this question
Top Cosco Baby & Toddler Car Seats Experts
Level 1 Expert
Are you a Cosco Baby and Toddler Car Seat Expert? Answer questions, earn points and help others
