Promac cinemac 2100 tv diagram
No video plain raster
    Top Expert:
  • Televison & ... Master
  • 75,157 Answers
The chroma processor IC should be checked and replaced.
Posted on Apr 26, 2013
2 Suggested Answers
SOURCE: unlock my promac cinemac 2100 tv
i bought a new remote control for my tv, pressed and hold the display button for 5 seconds or so... and voila! my tv was unlocked!!
i guess this is the standard way in unlocking tvs.
thank you so much to those who suggested this. :)
Posted on Jun 26, 2008
No picture ,plain raster
T'Con board fault. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name and type (TV, VCR, DVD player etc:) of your device, in the search box [at the top right] of the home page. It will make surf easy.
Use the keyword phrase "How to replace T'Con board"
Jun 13, 2015 | Televison & Video
Sound on but no pitcher
Sound on means audio section is ok. No picture is video board problem. Pl check input cables. Or give Hdmi cable input. Disconnect all inputs switch on u should get plain raster that is only dots on screen, or blue back screen, if nothing contact authorised dealer,
Feb 08, 2015 | Panasonic TH-L32C20X 32 inch Multi-System...
Lcd display blinking 32t550a
It could be many things. Count the blinks. This is a blink code that may help in diag failure. 32inch set are cheaper to replace these days. Do some shopping before you pay for serv of this set.
Oct 02, 2013 | Sony Klv-32t550a Bravia Multi-system Lcd...
Lcd display PLAIN RASTER
NO onscreen display at all when pressing menu? Could be t con board which may not be available without replacing completed lcd panel or main board. 32 inch tv is not expensive to replace . Shop around before putting money into this set.
We need a screen on modelRC/J36 Thanks
sony lcd KLV 32T550 A HAS ONLY PLAIN RASTER
Oct 02, 2013 | Televison & Video
Monitor plain raster ok but nodisplay (or) no image
check video output ic and resolder..then check vga cable..
Jan 04, 2010 | Samsung 793S 17" CRT Monitor
IM A TV TECH. I HAVE A SONY LCD KP-60XBR800 I HAVE NO RASTER. POWER OK, MENU OK BUT NO RASTER ON TUNER, TUNER VOLTS OK,CAN YOU HELP ME PLEASE. THANKS my email sergioaguirre0182@hotmail.com
check the high voltage with the screen control turned up high where there is no raster. suspect problem within the video circuit where there is no high voltage or defective picture tube.some time when the screen is black and the screen control advanced,you can see if the tv has video or vertical or horizontal problems on the screen.service the high voltage circuit if there is no raster or high voltage is seen.no raster can be caused by the no heater or filament in the CRT.---- a defective picture tube can cause many problems, such as, poor brightness ,missing colors,intermittent picture,poor focus,a single-colored raster,arching in the gun assembly,retrace lines in the picture,negative picture,chassis shutdown,noheater or filament lit and no raster to name a few.an open filament or heater can cause no picture or no raster symptom.a defective CRT can have an extremely bright screen.loose particles of the cathode element can lodge between the grids and cause an intermittent black and white picture. simply tap the ends of the CRT gun assembly and notice if the picture begins to flash off and on.---- with a leaky picture tube after turn on the raster dims and get extremely bright.a dim picture with no green in the raster can result from a bad green assembly. a heater-to-cathode short can cause a raster to change colour or a result in no raster at all.replace the picture tube if there is severe arching in the neck of CRT. excessive brightness with retrace lines and a vertical collapse to a thin line can be caused by a bad coil on the neck board of the picture tube.rejuvenate the picture tube when there is very bright green screen. check for the resistance change on the resistors of the CRT neck board for an excessively bright picture with retrace lines.excessive dust inside the CRT spark gaps within the picture tube socket can cause the very bright raster and the chassis shutdown.a defective video amp,luminance buffer,or reference transistor can cause a bright picture with retrace lines. -------- for getting any required parts to replace you can get it from www.radioshack.com or from www.partstore.com or from www.shopjimmy.com --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 06, 2009 | Televison & Video
Samtron sc 428pt no display
Hi...there,
Well, no display usually caused by burnt out backlight inverter. Need to replaced a new one or repaired it... Happy Holidays!
Dec 05, 2008 | Computers & Internet
Samsung Vp-D103i V-light get on.
Do you have the correct adapter?It sounds like you have the wrong one.
May 11, 2008 | Samsung VP-D103i Mini DV Digital Camcorder
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
