Question about Sennheiser PX 200-II Headphones
The bass has cut out of my Senn Px200ii headphones... I can hear everything else, but the bass lines are non existent. Any Suggestions?
I don't hear any bass anymore... How do I fix this?
One of The negative lines from the speakers or microphone/volume control are losses to jack. change the jack.
Aug 08, 2014 | Wesc Golden Oboe Headphones
MY sennheiser 205 headphones stopped working overnight. I can hear everything fine, the only thing is that i can barely hear the vocals. I did switch devices to see if that was the problem and it was not....
1) You are turning up the volume too much. Headphones, especially non-top of the line headphones, are not meant to be listened to at very loud levels. In this case, the crackling you are hearing is the speaker trying to reproduce a bass sound that is "clipping", or exceeding the maximum output level for that system. Remember - headphone speakers are very small; they have a harder time producing low sounds accurately. The solution is to just turn them down a little.
2) Assuming problem 1 is not the problem, the other likely issue is that they came with some sort of mechanical defect built in. If you are not playing them loudly, but you are still getting a crackle, especially if it is only on one speaker, they probably are broken. It is probably the jack itself, or the wiring leading up to the earpieces. Either way, it is not a terribly hard fix if you have some electrical know-how, but if you don't, there are plenty of people who can rewire them for much cheaper than it would be to buy a new set. However, if this has been happening since you got them, I would call the manufacturer first and see if they will replace them. Sennheiser tends to pride themselves in the quality of their equipment, so I would not be surprised if they sent you a replacement set.
Hope this helps!
Jul 01, 2011 | Sennheiser HD 205 Professional Headphones
When we plug in hubby's remote headphones (he has a hearing impediment), it cuts off the sound and I can't hear it.
That is normal operating mode when using the headphone jack. The only way for you to do this without cutting the sound from the speaker so you can hear the sound (if your remote headphone has the Line level input), is to use the audio line out (WHITE and RED RCA jacks) to feed the remote headphone unit.
What the make and model of the remote Headphone system that you have?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Jun 05, 2011 | LG 32 32LK450 32 in. LCD TV
Hello. With my HD205 headphones, in the left headphone it has a small crackling noise with certain songs.. I don't know if its meant to be like that? Its done it since I had them first - Happens to bass...
There are two likely causes for this. One is much, much easier to fix than the other.
Hope this helps!
May 03, 2011 | Sennheiser HD 205 Professional Headphones
Sony MDR-EX36V Stereo Headphones - No Bass or Stereo Sound
for the bass check your eq on your player (make sure it not off or default)..for the stereo effect you might have yanked the wire a bit from the ear piece or even the plug piece to cause the non stereo ....earbuds get caught on a lot things and we just keep movin and doin until its to late...
May 28, 2010 | Sony Bud Style Headphones
Technics su z2 amp shuts off sound
hello. we cant help if we dont know what music source you are using.
Apr 13, 2009 | Technics SA-AX530 Receiver
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
Home Theatre for Acer Aspire6920
i would like to change the language on my pc
from japanese to english
Aug 19, 2008 | Acer Aspireā„¢ T180 PC Desktop
Phone showing non-existent headphone enhancement!...
If you plug your headphones into your phone it should not stop you from making and receiving calls. I think you might be on a silent profile or offline profile. I play music and listen to radio on my N70 and all is well.
Dec 26, 2007 | Nokia N70 Cellular Phone
Sennheiser PX 200-II Headphones Logo
23 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
