Question about Cyberhome DVR 1600 DVD Recorder
No video Output
I can put a DVD into my Cyberhome 1600 and get no video output. I get an audio output with no problem, but the video is just a BLUE screen.
    Problem Solver:
  • 5 Answers
Try changing video cords and if u are using vcr as i am try selecting diffrnt channe on the unit that may help u solve or ay not juss update your posts if it worked (the vid I am reffering to video,audio plugs red white and yellow it worked out for me if it is dealing with when recording make sure proper video selection as well as audio
Posted on Aug 11, 2007
SOURCE:
Connect dvd player to television
first,look up your portable DVD if there's a audio/video output...next,if your DVD have that,you need a RCA jack for audio/video that connect it to the audio/video input of your TV..
thank you and good luck
Apr 05, 2011 | Cyberhome CH-LDV7000 Portable DVD Player
Can you put a phillips dvdr610 onto a television with built in freeview and then record from it. If so how?
If your TV has an OUTPUT MONITOR Output Jacks, Yellow, (Video) Red (Audio) & White (Audio) FEMALE RCA Jacks.Then these will output WHATEVER is showing on the TV screen. And can be used as an Output for any Recording Viewing device. There will be other, FEMALE RCA Jacks,AV, Yellow, (Video) Red (Audio) & White (Audio) and possibly also The Composite Video, Red, Green, Blue, all Video, These are INPUTS, they will be there also. Make sure.
Feb 16, 2010 | Philips DVDR610 DVD Recorder
Cyberhome DVD-1600 In the settings menu I went into the A/V setup. The scanmode was switched to Progressive; however, nothing showed and after the 10 seconds it did not revert to interlace. Now I'm ge
Cyberhome DVD-1600
To set the factory default settings just do the following:
  1. Get the DVD-1600 manual
  2. Open to the page which shows you how to set the player to factory default settings
  3. Switch on the TV and click to the channel that you will watch your DVDs
  4. Switch on the DVD player and make sure there is no disc in it - this ensures the DVD is not already in a menu or any other thing
  5. Follow the instructions in the manual to the 'T' although you will be unable to see anything
  6. If you follow the instructions correctly you should get back to 'interlaced mode'. By this time you will be able to see the DVD output on the screen.
Apr 12, 2009 | Televison & Video
I need manual for my Cyberhome CH-DVR 1600ME2 (with SCART output)
I HAVE THE MANUAL (COPY) FOR SALE FOR A DVR 1600 PRICE IS 7.50 W/FREE SHIPPING CALL 2095683327 TO INQUIRE.
Mar 31, 2009 | Cyberhome DVR 1600 DVD Recorder
Setting up mintek 100 dvd player to cable box to tv
Newer TVs have multiple inputs. Mr Mark is correct, you generally do not daisy-chain Audio/Video units unless you are using a recording device. Cable box to Cable input on TV. DVD player to other inputs.
Let's get some terminology out of the way. Specifically for the Mintek DVD-1600. There are NO inputs.
Coaxial Audio out (orange) is for digital audio only. Usually connects to stereo reciever for Dolby 5.1 surround sound. Not for TV.
S-Video (black w/4 small holes, 1 square) is for better quality video than composite. Use this to TV instead of Composite if you have a S-Video input on your TV.
Composite (Yellow) Older video input type. Works just fine. Connect to TV.
Audio Output ( Red & White) for analog stereo only. Goes to TV. Red=right, White=left channels.
Component Video Out (Blue, Green White) is the newest video output type in this unit. Better than S-Video. Use this option if available on your TV instead of S-Video or component.
Feb 13, 2009 | Mintek DVD-1600 DVD Player
Can't record from tv to dvd
I think you would have to run your sat line through the DVR-1600 first (Line In) then connect directly from the DVR to one of your TV Line-Ins (Audio R, Audio-L, S-Cable Video).
And then use the Cyberhome TV Tuner to record off your sat.
Jan 24, 2009 | Cyberhome DVR 1600 DVD Recorder
How to connect DVR 1600 to LCD HD TV or ATT uverse recorder
has to be scarts, your reciver (sky, cable ect ect) to your dvd recorder, from that to the tv, all scarts, might help, regards mark
Feb 01, 2008 | Cyberhome DVR 1600 DVD Recorder
Recording from vhs to dvd with a dvr
You can get a standard audio/video cable from any Radio Shack or audio equipment store. It will most likely come as a single 3-part cable with a yellow (video), white (audio left), and red (audio right) set of connectors on each end. Most equipment that's not too old will have matching color-coded sockets marked input/output. Simply plug the video/audio cable into the vcr output and the other end into the dvr input. then connect a second cord from the vcr output to the tv input. Then with everything turned you will be seeing the final signal on the tv and you can start the dvr when you are ready to start recording.
Nov 22, 2007 | Cyberhome DVR 1600 DVD Recorder
Audio and video is not working in my dvd mplayer
sometimes on the remote itself there is a video button to change over to diffrent mode, but at least should hear audio because thats on a totally diffrent output. i would try using a diffrerent output on the dvd player such as svideo, what were u using before on the out, was it component or the standard video out such as yellow output, you will have to use process of elimination..
Nov 21, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome DVR 1600 DVD Recorder Logo
59 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
