Question about Refrigerators
Compressor relay rva6ap6d 947 u837 in dublin
Compressor relay, 35a 400vac
The nf90 does not seem to be pushing cool air. what needs to be checked?
Hi Anonymouse!
Please check first the compressor for something like working. If it only vibrates, you notice a high temperature in it. If this hapens, just replace the capacitor of the compressor... a white tube with 2 wires in one side and a possoble screw on the other (tipical values for europe is 400VAC in USA 200VAC and capacities from 4 to 20uF.
If the compressor it´s running, and you notice one of the pipes slightly cooler than the other, well, then you need to load gas and a help from a pro with proper equipment!
Good luck
Jul 16, 2016 | DeLonghi Heating & Cooling
Tip
How to wire and size a potential relay
To size a potential relay you must read the Start winding voltage (the BEMF)
which will be above the supplied line voltage, in this example I use 300 volts for math.
BEMF = 300 volts,
300v x ,50 = 150v minimum
300v x .80 = 240v maximum
300v x 1.20 = 360v continuous
So you want the Start capacitor to stay in the circuit to at least 150v BEMF or risk stalling, and you do not want the Star capacitor to stay in beyond 240v BEMF or risk
exploding the Start capacitor.
The 120% continuous rating is to oversize the coil in the potential relay that remains in the system to protect it .
If you have a compressor that is not running you will need to jump it with a Start capacitor(a large one) to the run capacitor for 1 second or so to bump start the compressor, then you can read the Start winding for the BEMF reading.
on Oct 14, 2013 | APPROVED VENDOR Potential Relay, 35A, Pick...
Dublin
What is the make and model of the device that the relay is on?
Apr 26, 2013 | Bosch 1985 - 1994 Classic Saab 900 Turbo...
Hi! I need to find Zip code of Dublin???
Go on to google and type zip codes for Dublin Ireland..Like most cities there is more thanone.They have all that you need on that site good luck
Jan 28, 2010 | ZipZoomFly Coupon Code E3ANTEC
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
