Question about Toys
Yardworks lawnmower 060-1778-0 does the battery come off to charge?
Does this model have a battery that can be lifted off and charged on it's own ?
  • 5 Answers
SOURCE: Vtech 2656 cordless phone battery not charging
These phones seem to have this problem, I'm not sure a new battery will fix it. I have found a wierd fix that works for me, but I have no clue why.
1-take the battery out,
2-leave it out about 30 seconds,
3-then put it back in but leave the cover off,
4-place it back in the cradle however you can with the battery hanging out (I wrap it around),
Now it will charge much more thoroughly for some reason???
Posted on Apr 16, 2009
SOURCE: Lawnmower Model CMM1000 Batterys will
All of a sudden mine also acted like it wouldn't take a charge and the needle wouldn't move. The plastic safety key also wouldn't insert smoothly as it used to and I would have to push the start lever before it would drop in. When I checked the charger, it was putting out 24v. When I opened up the lid I noticed that the starter cable was pushing the safety switch incorrectly. If it was moved a bit, the mower would then start. The starter cable is only secured to the handle by tie wraps. So if it gets moved around, it can cause the kill switch to be in the kill position. So now if I have a problem, I just move the cable in or out a bit. Fortunately, this find saved me a trip to the dealer and who knows how much $$$$.
Posted on Oct 15, 2009
backwoodsctr
  • 169 Answers
SOURCE: YardWorks 19'' 24V mower not charging
JIM I HAVE SEEN THIS ISSURE MORE THAN A HANDFULL OF TIMES, THE MAIN PROBLEM IS A LOOSE WIRE TO THE MOTOR HEAD, POP OFF THE COVER AND INSPECT. IF THAT DOES THE TRICK THEN GREAT!!! IF NOT THEN U HAVE INTERNAL MOTOR ISSUES THAT WILL BE COST PROHIBITIVE TO REPAIR.
Posted on Nov 19, 2009
  • 29 Answers
SOURCE: I have a craftman GT5000 Lawnmower it quit charging.
The charging system is under the flywheel, but first check the 2 wires are connected at the side of the motor, they might be black and white at the conector.
Posted on May 01, 2010
gopakumarg43
  • 74136 Answers
SOURCE: Where can I get Durabrand Battery model BAT-09 for my DVD player Model PDV-709
Hello
Try this link for the availablity.
http://batteries.batterymart.com/durabrand-battery-pack-model-bat-09
Posted on Mar 01, 2012
Worx 17'' Cordless Lawn Mower (Model WG787). I've got a barely three month old lawnmower and the battery is fully charged yet the blade only barely spins. Seems to be virtually no power despite the charged...
The batteries are defective in this unit. It should be returned to the dealer that you purchased it from and get exchanged, or your money back. Another way to test this mower is to charge the batteries fully, then test them. If they are truly fully charged, run the mower until it slows down, and test the batteries again. If they are still charged, (unlikely) then the problem is in the motor itself and still should be returned.
Sep 09, 2017 | Worx 17" Cordless Lawn Mower with...
I just purchased a Toro e-cycler cordless mower, model # 20360. I tried plugging in the charger to the Ac outlet and the mower receptacle. My understanding is that the charger light is suppossed to be...
It could be that the batterys don't need to be changed and shouldn't be unless fully discharged, if u charge before the batteries are fully discharged u run the risk of damaging the batteries. The problem is sometimes batteries get what is called a memory charge, this means if u use your lawnmower for a short time than charge it and u do this repeatedly the batteries will only discharge for this sort time and will only charge for a sort time. Than if u need it for a big job it will seem that u have only operated it for a little time and u need to plug it in. The only way to fix the batteries is buy new ones, that way they always tell u to always fully discharge before recharging your batteries.
Sep 15, 2011 | Toro Garden
LT1000 lawnmower clicks when trying to start. It is the module that the cable from the starter is connected to. What is wrong?
You might want to check your battery, sounds like it is weak put it on a charge overnight and see what happens. Preferably a battery maintenance charger, they give the best condition for charging batteries
Nov 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Sep 28, 2009 | Garden
Outboard motor charging systems, do they exist or do i need to periodicly charge the battery for my boat
Look at your ID plate and get the model number of your motor. Then contact the Johnson dealer and see if your model comes with a charger, be it alternator or magneto. Many use systems similar to riding lawnmowers and they do not need charging.
May 18, 2009 | Boating
Toys Logo
152 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
