Whirlpool Front Loader WFS1071BW, rinse cycle problem
Machine starts & washes clothes, at spin cycle the panel lights flicker (as if a loose connection), then stops with Door open light lit up (red). Can not open reset, open door, when restarting (from start or rinse stage), same problem occurs.
I had exactly the same problem with the same machine... I've seen a few people on various forums with the same problem. The problem on mine turned out to be just the EMI filter located next to the power cord inlet. I just bypassed it for now until I can get a replacement.
Posted on Oct 27, 2013
  • Leo Salo
    Leo Salo Oct 28, 2013
    It turned out this only temporarily fixed the problem... the real issue was the motor brushes. Seems bypassing the filter made it somewhat more immune to the noise. New brushes found on ebay for a couple of dollars, they are 1/2" x 1/5" x 1-3/5" and require soldering. Will see how it goes when they arrive!
aborcass
  • 2651 Answers
SOURCE: Brand new Front Loader not washing
well if its spinning and not washing, that does sound like aproblem with unit and not what your doing, id call a service company to figure it out, thats why you bought new, not so youd repair it
Posted on Mar 30, 2008
SOURCE: Front loader washing machine AWM 6100 Whirlpool
check brushes on motor. how old is machine?
Posted on Feb 01, 2010
  • 56 Answers
SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Posted on Feb 11, 2010
SOURCE: Whirlpool WFS1071BW front load washing machine -
Unplug your washing machine and then you will be able to get the door open and the clothes out. You may need to leave it off for awhile to get it to work but make sure you have a bucket ready to catch the water coming out.
Posted on Oct 19, 2010
  • 57 Answers
SOURCE: Whirlpool Front loader Washing Machine
MAKE SURE DOOR SWITCH IS MAKING CONTACT WITH THE DOOR OPEN THE DOOR PUSH SWITH WITH YOUR FINGER HIT START OR SEE IF LIGHT GOES OFF IF IT DOESNT THE SWITCH IS BAD
Posted on Jan 24, 2011
Have a lhw0050pq4 ft loader washer (whirlpool) 5 years old little use. in 5th wheel trailer and it seems to lose its place in the cycle can you help?
The control board will need to be replaced. It is located on the top, right hand side of the unit as you look at it from the front. Remove the screws on the top panel, slide it back to remove it. You will see the board. Here is the board to order.
Oct 29, 2012 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool washing machine WFS1273AW manual
I have a whirlpool WFS 1273 AW front loader that gets stuck in the spin cycle. The timer counts down from 18 minutes to 17 minutes and starts to spin but before it gets to full speed the control panel lights all flash, go blank, and the. The timer resets to 18 minutes. I have cleaned he drain pump, removed the clothes and tried it when empty and it does the same thing. It does not appear out of balance.
Jan 04, 2012 | Whirlpool Washing Machines
My Whirlpool Duet Sport front loader washing machine will finish washing the close but does not rinse then spin out the water. I have to turn it off turn it back on to spin and drain. I have used the...
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jun 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
May 10, 2010 | Whirlpool Washing Machines
Suds will not spin out. What can I do?
This machine is designed to use HE detergent which is low sudsing if used in the right amount. If the wrong detergent or too much is used sudsing and possibly an error code of SUDS may occur.
You can run a rinse/spin cycle to help clear the suds, you might have to run this cycle several times until the suds are gone.
If the machine is locked out and will not allow you to start a cycle, try unplugging the machine for 30 seconds then plugging back in. Turn the power on and push cancel/drain. This should let you take the clothes out and start the rinse/spin clean out.
Once you have removed all the suds I would recommend running a cleaner such as smelly washer or Affresh through the machine to remove any hidden residue from the excess soap.
Always use HE detergent in a front loader
Apr 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
All my clothes smell mildewede
the washer is not pumping out the water correctly ---- try some different wsh cycles to see what happens --- make sure it drains during the spin and rinse cycle
Aug 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Spin cycle not removing enough water from clothes
your manual states that it can be caused by cold rinses and or spin cycle not getting completed. please try to rinse in hot or warm and see if that does not solve your problem
Dec 20, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
153 people viewed this question
Top Washing Machines Experts
