Question about Compaq FS7600 17" Flat Glass Monitor
Compaq Monitor Model 7600
Please help. My screen is set for full view and tried everything to make it look right. It is on full screen but along the right side of the screen is a one inch dark area and only less than half inch dark on the left side. It looks like a picture tube got mal adjusted. off set or whatever. I moved in April but did not notice this till now. Could the jarring in the truck and box off set the screen or could this be another problem. Please help if you can reply to me. at [email protected] Thanks. Roselee
  • 1 more comment
  • Roselee Irvine
    Roselee Irvine Aug 08, 2007
    Thank You! I did adjust the screen but have to let it be a bit dark on the right side because full stretch makes the web page where part of the screen page hidden. But it is ok to have the smaller black edge. I am hoping to get eventually a slim line screen monitor. Used or otherwise.
    Thank you so much.
    Have a beautiful summer.
    Sincerely
    Roselee/Lilrose
  • Anonymous Apr 12, 2008
    Brought my computer back from the repair shop. When I hooked up the 7600 monitor, there was a black border around the screen. As far as I could find out, there are no drivers for this monitor. The solution is this . . . There are control buttons on the front of the monitor. By selecting the menu button, you can then make several selections. One selection is to stretch the screen. You can stretch it up or down and sideways. There are other selections available which you may want to use. Essentially, even though the problem was staring me at my face, so was solution. The answer was simple. I thank this site for helping me.
  • Anonymous Aug 03, 2008
    my screen is full screen but its all in the middle of the monitor with dark spaces to the left and right
  • Compaq Master
  • 12,061 Answers
There are usually controls, button or knobs, to "Stretch" "Move" "Pincusion" and others... have you tried this, as this is what it "Sounds" like to me from ya description? If there are NO controls on the front to accomplish this task, at the REAR of the unit there should be controls marked to show the function. Below is a link where ya will find a Manual that may help ya. http://www.retrevo.com/s/HP-7600-Monitors-review-manual/id/281ci552/t/1-2/
Posted on Aug 08, 2007
SOURCE:
Compaq FS 7600 - display - CRT - 17" driver
click start control panel you will see thre options change theme change desktop background and adjust screen resolution then select resolution from the drop down list you can adjust to your preffered settings 1024x 768 is usually recomended (you have not stated your problem)
hope this helps
Sep 22, 2011 | HP Compaq FS7600 17" CRT Monitor
My monitor's screen resolution and color depth are at a very very low resolution and I am unable to increase/improve this. Consequently, everything is fuzzy and colors are impossible to view. My monitor is...
please try doing a factory reset of the monitor.
please press the menu button on the monitor itself. you can easily locate the buttons below or on the right hand side of the screen on the monitor panel.
select the factory reset /recall options with the help of the arrow/+ - buttons.
this would reset your monitor color settings to default.
Jan 22, 2010 | CTX Computers & Internet
''out of frequency range'' on crt monitor
Go into your "Device Manager" in Windows and find out if your HDTV monitor is still installed. Delete the settings under the monitor tab and reboot the computer. With any luck the reboot will cause Windows to re-detect your current monitor and install the proper settings. A similar process may need to be followed with your video card driver as well. CAUTION: Make sure you have a disk or some means of installing a copy of your video card driver before you delete out the currently installed one.
Hope this helps!
OpenSource13
Apr 05, 2009 | Compaq Computers & Internet
My monitor displays images in stetched full screen format
the description you gave was the long way right click on my computer, select properties then device manager, you will be in the same place but lots faster, plug and play does not identify the monitor or its compatible display resolutions, right click on the desktop select properties then display settings, go into advanced tab and look at the monitor, and the adapter, you can play with the setting until you find one that works, 1400 x 900 may not be supported by the video card(adapter) so that may be why your loosing the video settings.
hope this helps.
Mar 15, 2009 | Acer X193W LCD Monitor
Somehow, I've enlarged the image size on my Compaq 7600 monitor. How do I reverse it?
Right-click the desktop and go to properties.
Under the settings tab you can change the screen resolution size. the bigger the number the smaller the icons will be on the screen
Dec 08, 2008 | HP Compaq FS7600 17" CRT Monitor
Dear Lilrose: Here's how to dim your FS7600 monitor. Press
"menu" on the front of your monitor. Now press + button until
the icon just to the very right of the 12 0 clock position is
highlighted. Now press select. A graph will appear and by
pressing the minus button the screen should start to darken.
When you are satisfied, push the menu button to escape.
Hope this helps.
Radial
Jun 19, 2008 | HP Compaq FS7600 17" CRT Monitor
Input not supported
Do you get anything on the screen when you first turn on your computer?
If you do the windows resolution somehow got set to high for the screen to handle. To fix this press the F8 key a couple times after the BIOS splash screen goes away ( The screen that has HP or DELL, etc on it). If done at the right time it will bring you to a menu that has several options including safe mode. You'll want to pick " Enable VGA mode." From there it will start to load Windows, but everything on the screen will be large. Once windows is fully loaded find a empty spot on your desktop and right click. From the menu that pops up please select Properties. It will open up a box that says "Display Properties." Click the tab that says Settings. On this tab move the resolution slider to right right a click or two to make the monitor normal size and click apply.
Nov 14, 2007 | View and View Technologies VNV AquaView...
How do I get the widescreen monitor to show unstretched images?
i had the same problem with my new widescreen monitor... turns out the best setting (at least, for my specific monitor) was 1440 by 900 pixels. at this setting the desktop still stretches itself to fill the entire screen, but everything else is completely unstretched. (to adjust the screen resolution, right click anywhere on the desktop, then go to properties, then settings.)
Nov 07, 2007 | Gateway FPD2275W LCD Monitor
Display on moitor
just press the auto button on panel it will adjust the screen
Aug 17, 2007 | Compaq FP 7317 17" LCD Monitor
Monitor problem
Replace video filter capacitor supplying voltage to RGB driver transistors like 47uf 160v.
Aug 05, 2007 | HP Compaq FS7600 17" CRT Monitor
Open Questions:
See all Compaq FS7600 17" Flat Glass Monitor Questions
Compaq FS7600 17" Flat Glass Monitor Logo
393 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
