Lennox iComfort thermostat won't stay connected
The thermostat apparently won't stay connected and the installer is useless. If I disable the wi-fi and then enable it and reconnect, it will connect for anywhere from a few minutes to several hours but it always disconnects. I get the error "connection to server has not been established or has been lost". My laptop, phone, and Blu-ray player can all connect just fine. Can anyone offer any help before I rip this thing off the wall out of frustration?
  • 53 Answers
SOURCE: How to connect Panasonic BD60 Blu-ray disc player to 2 components
If there are red and white RCA jacks on the back of the BR player and on the receiver you should be able to get sound. The same as your VHS.
Posted on Dec 29, 2009
  • 6 Answers
SOURCE: I can't get our Samsung Blu-ray player(Model
I am not an expert a "tinkerer"at best but I do have the 3600 like you and I have no problems connecting. Make sure there aren't any spaces or special characters in you router name. Follow your instruction manual and get the 3600 connected first then try netflix: Menu, setup, network, set your settings and it will tell you available networks, choose yours, enter your security code then do a connection test. If its not connecting at what step are you having a problem?
Posted on Jan 10, 2010
SOURCE: My Sony BDP-S560 can't see or connect to my laptop
I have a sony vaio laptop and a BDPS560 which connected automatically. Is the green WLAN light on the blueray lit up?
On the laptop, if public is set for the location in Windows network settings, devices will not be shared automatically. Hope this helps S.Newsham
Posted on Mar 06, 2010
  • 4090 Answers
SOURCE: I have just bought this blu ray player and a new
It may well be that these Blu Ray are the new generation discs. You may need to download the Firmware upgrade file burn it to a Cd and run it by pressing Play.
Goto LG support site download
Please rate my help++++Thanks for using FIXYA
Posted on Jun 25, 2010
  • 7 Answers
SOURCE: The Insignia NS-WBRDVD blu ray player will not
This is a common problem. If you go to the Insignia web site and find the forums, you will see a 40 page list of wireless connection problems. The wireless section of this player is junk. Use the wired connection and save yourself a lot of aggravation.
Posted on Nov 16, 2010
I want to connect a NEST thermostat with WiFi to my Lennox furnace. The existing iComfort by lennox has 4 wires, R, I+, I-, and C. Where would these connect on the Nest?
They don't. And why would you want to trade it out??? You are currently running off the communicating terminals. If you are going to install a nest you will have to match the nest wiring with the legacy/24volt terminals on the furnace control board and likely the outdoor unit will need rewired as well. Not extremely difficult but why??? The nest is not what it's cracked up to be!!
Sep 12, 2017 | Heating & Cooling
Which color wires do I connect to I- and I+ on my Lennox digital thermostat?
Can you give me more info on the thermostat? Model number maybe or Lennox Elite for example? I have never heard of these I numbers but would like to do some research on it.
Nov 20, 2014 | Hunter Heating & Cooling
My Lennox MS7 heat pump was installed about a year ago and hasn't had any problems until last week. It has started changing settings (like on or off, higher temperature, light on or off) without prompting...
Go to the unit locate the control module. Take wires to thermostat out. Now jump from R to Y your AC should come on. Jump R to W your heat should come on. Jump R to G your blower should come. If you have done these and it stay on or run as it should then you need a new THERMOSTAT.
Oct 26, 2013 | Lennox 7 Series MS7-HO-30P MS7-HI-30P Heat...
Lennox furnace won't start
Check the circuit board to see if the little 1 amp car fuse is blown, if it is replace it, if not, check to make sure the furnace is on and the door switch is engaged. if that doesn't work call a proffesional to come diagnose the furnace.
Mar 01, 2013 | Heating & Cooling
Furnace computer won't let furnace light
What is the model number? I have an SLP98 (installed on 11/29/2011).... and if I take the cover off the front of the furnace the panel that has the fancy "Lennox" badge on it) you will see two clear round windows about the size of a half dollar (one high on the furnace box and one lower on the blower box.) If you look downward into the window on the blower box you can see a red LED display that will sometimes flash error codes like E228 (one character at a time). If your model has something like this, let me know. I've done some DIY fixes recently out of necessity....and their easy.....and several technicians confessed they didn't know much, if anything, about the newer high effieciency Lennox gas furnaces.
Mar 01, 2013 | Lennox Heating & Cooling
I have a lennox 2 stage gas furnace and a lennox XP15 heat pump controlled through the Lennox 7000 touchscreen thermostat. I want to disable the heat pump due to excessive noise due to lower temperature...
At tstat press options. Press installer setup. Yes, you are qualified. System settings, non heat pump. Gas/ oil heat. Save changes. That should do it with no wiring changes.
Jun 18, 2017 | Heating & Cooling
Televison & Video Logo
442 people viewed this question
Top Televison & Video Experts
