Question about Ovens
E02 ERROR CODE
IFB MICROWAVE OVEN E02 ERROR IS SHOWN AFTER EVERY 5MINS WHEN USED IN CONVECTION MODE
Powerman
  • 68 Answers
SOURCE: Kitchen Aid ovens - error codes
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit. The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter? I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
Posted on May 03, 2007
SOURCE: jenn air combo wall oven/microwave
Bend over, pull down pants. They Got you....
Posted on Apr 26, 2008
SOURCE: Elitech 1300W convection oven: How to set it for self cleaning
Hi
If you watch the advert for the Nuwave or Flavorwave they set the machine to defrost setting.
Put water in and a bit of washing up liquid and put on for about 10 min.
Posted on Dec 09, 2008
SOURCE: Oven will not heat up on bake broil or convection cook.
I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
Posted on Apr 09, 2009
localwonder
  • 6784 Answers
SOURCE: f9 error code while using the convection baking function
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
Posted on Jul 30, 2009
I have an error code on my GE Microwave JK5000DK
you probably need a new microwave or try to unplug it or you can probably take it to get someone to fix it for you
Mar 11, 2016 | GE JK5000DFBB 27" Built-In Single...
Trying to use self clean feature on my 2009 themador wall oven and E106 code appears?
Are you sure of the error code number? A list that I found only goes from E1 to E15 and F0 thru F9 & also a Fd code. Double check the code and respond back to me and I will see if I can help you further.
Aug 01, 2014 | Thermador Masterpiece MEDMCW71JS 27"...
F84 trouble code on electrolux icon wall oven
I am getting the same error right now for the microwave part of the microwave oven combo. The oven is working fine with no racks out of place.
Sep 10, 2012 | Electrolux ICON Designer E30SO75ESS Oven
I have a kitchenaid convection oven with microwave F6 EO code
Your tring to fix an appliance that's 10 yrs. Old ! Replace is your answer
May 14, 2012 | GE JKP85 Electric Double Oven
We installed kitchen aid microwave convection oven model kems308. it is displaying error code F6E0, "Lost communication". Any idea on how to fix?
Turn the power to the oven off. It usually is not possible to unplug the power chord for the built-in appliances so go to the main switch board and just turn off the oven power for about 5 minutes and then turn on the switch. The error code should disappear. Mine did!
Chander Mehta
Jun 06, 2010 | KitchenAid 27 in. Built-in...
How to use ifb 20Pg2s model microwave oven
Here's the link to download and print the owner's manual for your microwave.
http://216.92.68.214/home_appliances/micro/manuals/20PG2S.pdf
May 18, 2010 | Ovens
F9 error code while using the convection baking function
Jul 30, 2009 | GE Ovens
Microwave on counter making wall oven change
ok the microwave has magnetic fields that may be messing it up only way is to turn microwave off or move it at lease 1 meter away from oven let me know how that goes's for you
Dec 30, 2008 | Jenn-Air 27 in. Electric Single Wall Oven...
Thermador CMT227N
Hello air pro AC,
Welcome
You said, In the microwave mode - immediate clicking noise at start up. Oven, Convect modes work
Oh there are many things to check here.
1.look at the wheel base turning the plate that rotates your food for crumbs or sticking pieces of food.
2.check that the wheels are not worn down.
3.There can be a problem in the bearing, or linkage, or motor that spins the plate!
Do you get a error code?
How old is it ?
huuum
Waiting your response!
Oct 17, 2008 | Thermador Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
