Question about Husqvarna Huskystar 207 Sewing Machine
Parts I lost my pressure foot for my machine and I was hoping I could find a replacement.
  • Husqvarna Master
  • 7,365 Answers
Contact a viking sewing machine dealer and see if they can get the part for you.
Posted on Apr 26, 2013
The pressed foot lifter won't hold the material, I can push it up down turn it around this is not right
Are you saying the presser foot has very light pressure on the fabric? If so, most machines have the ability to increase the pressure the presser foot applies to fabric and feed dogs. It depends on your machine's make & model where & how that pressure is adjusted. Older machines usually have a large skrew or knob at the top of the needle bar that tightens down on a big spring, thus the tighter spring increases the pressure. Newer machines sometimes have a dial usually located on the top left or side of the machine head. (Consult your owner's manual.)
http://makeitsew.biz/presser-foot-pressure
The Best Kept Secret on Your Sewing Machine Sew Daily
Parts of Sewing Machine Pressure Adjustment
Under Pressure Adjusting Presser Foot Pressure
May 25, 2016 | Sewing Machines
I lost my box of pressure foots and the book for my machine, i need info on spaciffic pressure foot replacements,
Search the internet for:
Manufacturer + Model + the word "Manual" or "presser foot"
There are online sewing machine suppliers who will most likely have replacement presser feet for your machine.
Nov 10, 2015 | Singer Sewing Machines
Looking for zip foot for 1948 White sewing machine
check with these sites for parts, call or email
sewvacdoctor.com
a1sewingmachines.com
Feb 26, 2014 | White Sewing Sewing Machines
Need embroidery foot for Brothers Ult2001
Most sewing machine stores that have Brother machines will probably have the embroidery foot. Ask for part XA5500-001. It's available online here for $22: http://www.sewingpartsonline.com/screw-in-embroidery-foot-brother-xa5500001.aspx . Amazon.com also has the embroidery foot: http://www.amazon.com/Screw-Embroidery-Foot-XA5500001-Brother/dp/B0038RAVXI .
I hope this helps.
Feb 20, 2013 | Brother ULT2001
This is a parts identification question. My manual does not identify a part just above the tension part on the top of the machine left edge which is round in appearance about a little smaller than a dime...
Possibilities are:
foot pressure adjustment
tension dial adjustment
stitch elongation
If you can already identify the tension adjustment dial and this device is above the pressure foot, then I would gess it is the first one, foot pressure adjustment.
Many models don't have this but it was standard for many years on all machines, allowing you to control the pressure of the foot onto the needle plate, something you need to vary if you are sewing very heavy coatings or very fine silks, sometimes you just need to finesse the pressure yourself.
Aug 20, 2011 | Euro-Pro 373 Mechanical Sewing Machine
I turned off my machine to change the pressure foot on my Bernina Virtuosa 160. The pressure foot number does not change on the display. Is there something I need to do to change the number?
The machine Knows the foot number buy the small glass part of the foot just on the upper right side of the foot. Check to see if that is not damaged and clean. Also check the sensor on the machine just above the foot for not damage and clean. If that is good make sure your foot is paralel with the stitch plate. Do this buy putting a single hole foot on your machine and make sure the needle is right in the center. If this does not work you will need to take it in. May be a bad sensor or unpulged but that is rare.
Also not all bernina feed have this foot sensor, if this is the case it will not read it
hope this helps
Mar 27, 2011 | Bernina Virtuosa 160
I have a Simplicity Denim Expert sewing machine it's about 5 or six years old but an excellent machine I need to know how to put the foot that holds down the material back on the long iron piece that...
Hi. I believe your machine has a snap-on pressure foot. I've posted pictures of snap-on pressure feet at www.robbiesews.blogspot.com; just look for the 'pressure foot' tag or search the site for pressure feet and you shouldn't have any problem finding that post.
Anyway, there is an adapter (called an 'ankle') at the end of the 'long iron piece that lowers and raises the foot' (excellent description, BTW). The ankle attaches to that piece with a small thumb screw. With the ankle in place, you just lower the ankle onto the catch on the pressure foot.
You can also use regular low-shank feet on your machine. First, remove the ankle. The regular low-shank feet will attach to the raiser bar with that same thumb screw that holds the ankle in place.
You really should get a replacement manual for your machine. I found manuals for Simplicity sewing machines at http://www.sewingpartsonline.com/simplicity-sewing-machine-instruction-manuals.aspx.
Hope this helps!
Robbie
Aug 10, 2010 | Simplicity Sewing Machines
Pfaff Select 4.0 has looping on bottom of fabric, free motion qui
Make sure your are lowering the pressure foot first before you start sewing. With the free motion foot, you still have to lower the pressure foot, this allows tension to be put on the top thread and allows the foot to work properly (when the needle goes down so should the foot and when the needle comes up it should lift the foot up.)
Also make sure your tensions are in a middle setting and that you are threading the machine with the pressure foot up.
The way to insure you will not get your problem is with the foot up, you should be able to pull the thread easily right before the eye of the needle and when you put the foot down you should then feel a fair bit of tension on the top thread.
hope that helps :)
chris
Jun 06, 2010 | Sewing Machines
I have lost my foot pedal and power cables. Where can I get a replacement
Hi. I found a universal foot pedal and power cables that should fit your machine at http://www.sewingpartsonline.com/Brother-929D-Sewing-Machine-Parts.aspx.
Hope this helps!
Robbie
Apr 13, 2010 | Brother 929D Mechanical Sewing Machine
I need a replacement pressure foot release lever for a Simplicity BH600 blind hemmer.
Supposedly, Simplicity is made for Tacony. I would start there to ask about parts.
Is this a presser foot lifter?
I do not recall ever seeing a pressure foot lifter.
Mar 04, 2010 | Simplicity Sewing Machines
Husqvarna Huskystar 207 Sewing Machine Logo
50 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
