Samsung pn42b450b1d has 3 inch black line down left side of screen
SOURCE: Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
I also have the same problem I phoned Samsung today to explain the tv was only 14 months old, they didn't wanna no because it was out of warrenty by 2 months. I am getting a black solid line down the left hand side of the screen. I ended up phoning Dixons were we bought it from, they have told me to get an independent engineers report done & send the report to them within 14 days. Dixon told me it was a known problem with Samsungs. They said they will fix it free of charge if they can if not they will send vouchers to the same value of the television. So beware stay clear of Samsungs.
Posted on Nov 07, 2008
  • 116 Answers
On al the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black lne down the screen. Seeing as the tv is new I would get the warrantee repair on it. There is a possibility that there is a problem with the screen itself but more than likely its the boards.
Posted on Dec 11, 2008
SOURCE: samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Posted on Dec 23, 2008
SOURCE: Vertical black line on the screen of my 42" Magnavox flat panel lcd tv
I wish I could post a solution, but I don't have one. I too have a Magnavox. About 6 months ago, once every 2 weeks or so, the screen would just go black- all but an inch or two on either side. Now, it seems like it's a weekly thing, sometimes every hour or two. As of tonight, it has happened twice in a matter of thirty minutes. It usually repairs itself if I turn it on and then off again but that's just not working anymore. If anyone has a solution, let me know.
Posted on Dec 20, 2009
AndroidLVR
  • 31 Answers
SOURCE: green lines down length of screen on my samsung 40 inch LE40F8
The reason for the green lines are the resolution. I'm assuming you're TV is set at 1080i, not 720p or 1080p correct? What happens is the "i" stands for interlaced, meaning, your TV displays your images with scan-lines. The "p" stands for progressive, meaning, TV displays picture as a whole. You can not visibly see the scan lines when seeing 1080i, but certain TV programs are not outputting their show to the resolution you're at, which will cause you to have the green line up at the top of your TV. SOME TVs might let you adjust the settings to rid yourself of the scanline, but most consumer TVs will not let you without the maintenance code to protect your unit from over calibrating and braking your television. Hope this helps.
Posted on Mar 20, 2010
I have vertical black lines in my Samsung s42ax-yb09 plasma TV. one 3 inch band down the right side and a 9 inch band down the middle a foot from the right of the screen and 15.5 inches from the left
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 29, 2016 | Samsung Televison & Video
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
Samsung 52 Inch LCD 120hz. 3 inch wide vertical line on screen
This is a problem with the LCD panel. If the tv is out of warranty, I would call Samsung and see if they will pay for the panel and you pay for the labor. The panel is not cost effective to repair. If Samsung will not do anything you will need to buy a new tv.
Nov 16, 2008 | Televison & Video
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Aug 09, 2008 | RCA L26WD26D 26 in. LCD TV
Monitor some times gives shades with black
While 50 inch dlp samsung is on, 6 inch black line on left side of screen. This is the second time this has happened. The first time it happened then the lamp blew......do I need to replace the lamp again?
Feb 19, 2008 | Samsung DLP HL-P5663W 56" TV
Feb 03, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
40 inch lcd blue line vertical
The display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Hope ya fix it!
Jan 06, 2008 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
